初下CSS配置下载遇见的困难
 楼主| wangyingy 发表于 2022-8-3 10:54 | 显示全部楼层 |阅读模式
ST, AG, PA, CAN, The, AN
1、they may be broken.
An attempt to scan the JTAG scan-path has failed.
The target's JTAG scan-path appears to be broken
with a stuck-at-ones or stuck-at-zero fault.
(Emulation package 5.1.450.0)
解决:
仿真器的型号设置的不一样造成的。参考网站https://e2echina.ti.com/support/microcontrollers/c2000/f/c2000-microcontrollers-forum/110186/c28xx-error-connecting-to-the-target-error--151-0x0-one-of-the-ftdi-driver-functions-used-during-the-connect-returned-bad-status-or-an-error-the-cause-may-be-one-or-more-of-invalid-xds100-serial-number-blank-xds100-eeprom-mis
2、Error connecting to the target:
(Error -233 @ 0x0)
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken.
解决方法:待找到
