[RISC-V MCU 应用开发] 如何使用RISC-V对斐波那契递归算法进行优化
 楼主| 两只袜子 发表于 2023-4-28 09:26 | 显示全部楼层 |阅读模式
因为递归需要的时间很长且重复调用,因此要对其进行优化
如何对以下代码进行优化
优化后仍然是递归算法
a0: parameter, initially n
s0: placeholder for parameter n
s1: fib(n-1)
s2: fib(n-2)
fib部分
fib:
    ##Part 1. Prologue as a callee
    addi  sp,  sp,  -16     #create its stack frame
    sw    ra,  12(sp)       #save the return address to caller
    sw    s0,  8(sp)        #callee saved registers
    sw    s1,  4(sp)
    sw    s2,  0(sp)
    ##Part 2. Main body
    mv    s0,  a2            #addi  s0,  a2,  0  (parameter n saved in s0)
    li    t0,  2            #addi  t0,  x0,  2  (t0 = 2)
    blt   s0,  t0, fib_base #if n < 2, do the base case
    addi   a2,  s0, -1        #compute fib(n-1)
    jal   fib               #jal ra, fib
    mv    s1,  a0            #s1 = fib(n-1)
    addi  a2,  s0,  -2      #compute fib(n-2)
    mv    s2,  a0            #s2 = fib(n-2)
    add   a0,  s1,  s2      #a0 = fib(n-1) + fib(n-2)
    b     fib_ret           #beq  x0, x0, fib_ret
fib_base:
    li    a0,  1
    ##Part 3. Epilogue as a callee
fib_ret:
    lw    ra,  12(sp)        #restore the return address
    lw    s0,  8(sp)        #restore $s0
    lw    s1,  4(sp)        #restore $s1
    lw    s2,  0(sp)        #restore $s2
    addi  sp,  sp,  16      #restore the stack pointer
    jr    ra                #jalr zero, ra, 0
main部分:
main:
    li    a7,  5    #load syscall read_int into a7
    ecall        #make the syscall
    mv    a2,  a0   #move the number read into a2
    jal   fib
    li    a7,  1    #load syscall print_int into $a7
    li    a7,  10   #progam exit system call
    ecall
.include "fib.s"
xdqfc 发表于 2023-5-3 09:43 | 显示全部楼层
啥玩意?这么高大上。
