[独创算法] HotCRC内的HexToBase4096()源码(菜农自创邮件编码)
 楼主| hotpower 发表于 2023-9-23 10:42 | 显示全部楼层 |阅读模式
菜农电子淘宝:https://hotcomlock.taobao.com/ 准备出书:http://hotcomlock.com/hotcomlock.html
  1. function HexToBase4096(hexstr) {
  2.         var str,ptr,ch,uncodestr;
  3.         var i, j, num;
  4.         uncodestr = "";
  5.         for(i = 0;i < hexstr.length; i+=6) {//三个字节
  6.             str = hexstr.substr(i, 6);
  7.                         str = StringLeft0(str, 6);
  8.                         ptr = str.substr(2, 1);
  9.                         ptr += str.substr(0, 2);
  10.                         num = hextoint(ptr);
  11.                         num += 0xae00;
  12.                         ptr = inttohex(num, 4);
  13.                         uncodestr += HexToHotCode(ptr);
  14.                         ptr = str.substr(3, 1);
  15.                         ptr += str.substr(4, 2);
  16.                         num = hextoint(ptr);
  17.                         num += 0xae00;
  18.                         ptr = inttohex(num, 4);
  19.                         uncodestr += HexToHotCode(ptr);
  20.         }
  21.         return uncodestr;
  22.         }
个人签名:[url=http://www.21ic.com/tools/HotWC3_V1.23.html]
1460
