- #include <stdio.h>
- #include <stdlib.h>
- #include <unistd.h> // close()
- #include <string.h> // strcpy, memset(), and memcpy()
- #include <netdb.h> // struct addrinfo
- #include <sys/types.h> // needed for socket(), uint8_t, uint16_t, uint32_t
- #include <sys/socket.h> // needed for socket()
- #include <netinet/in.h> // IPPROTO_ICMP, INET_ADDRSTRLEN
- #include <netinet/ip.h> // struct ip and IP_MAXPACKET (which is 65535)
- #include <netinet/ip_icmp.h> // struct icmp, ICMP_ECHO
- #include <arpa/inet.h> // inet_pton() and inet_ntop()
- #include <sys/ioctl.h> // macro ioctl is defined
- #include <bits/ioctls.h> // defines values for argument "request" of ioctl.
- #include <net/if.h> // struct ifreq
- #include <linux/if_ether.h> // ETH_P_IP = 0x0800, ETH_P_IPV6 = 0x86DD
- #include <linux/if_packet.h> // struct sockaddr_ll (see man 7 packet)
- #include <net/ethernet.h>
- #include <errno.h> // errno, perror()
- #define ETH_P_DEAN 0x8899 //自定义的以太网协议type
- int main (int argc, char **argv)
- int i, datalen,frame_length, sd, bytes;
- char *interface= "ens33";//"enp1s0";;
- uint8_t data[IP_MAXPACKET];
- uint8_t src_mac[6];
- uint8_t dst_mac[6];;
- uint8_t ether_frame[IP_MAXPACKET];
- struct sockaddr_ll device;
- struct ifreq ifr = { 0 };
- // Submit request for a socket descriptor to look up interface.
- if ((sd = socket (PF_PACKET, SOCK_RAW, htons (ETH_P_ALL))) < 0)
- {//第一次创建socket是为了获取本地网卡信息
- perror ("socket() failed to get socket descriptor for using ioctl() ");
- exit (EXIT_FAILURE);
- // Use ioctl() to look up interface name and get its MAC address.
- //memset (&ifr, 0, sizeof (ifr));
- snprintf (ifr.ifr_name, sizeof (ifr.ifr_name), "%s", interface);
- if (ioctl (sd, SIOCGIFHWADDR, &ifr) < 0)
- perror ("ioctl() failed to get source MAC address ");
- return (EXIT_FAILURE);
- close (sd);
- // Copy source MAC address.
- memcpy (src_mac, ifr.ifr_hwaddr.sa_data, 6);
- // Report source MAC address to stdout.
- printf ("MAC address for interface %s is ", interface);
- for (i=0; i<5; i++)
- printf("%02x:", src_mac[i]);
- printf ("%02x\n", src_mac[5]);
- // Find interface index from interface name and store index in
- // struct sockaddr_ll device, which will be used as an argument of sendto().
- memset (&device, 0, sizeof (device));
- if ((device.sll_ifindex = if_nametoindex (interface)) == 0)
- perror ("if_nametoindex() failed to obtain interface index ");
- printf ("Index for interface %s is %i\n", interface, device.sll_ifindex);
- dst_mac[0] = 0x00;//设置目的网卡地址 00:50:56:97:fd:cc //00:0c:29:7b:00:8b
- dst_mac[1] = 0x0c;//0x0c;
- dst_mac[2] = 0x29;//0x29;
- dst_mac[3] = 0x7b;//0x84;
- dst_mac[4] = 0x00;//0xa4;
- dst_mac[5] = 0x8b;//0xa4;
- // Fill out sockaddr_ll.
- device.sll_family = AF_PACKET;
- memcpy (device.sll_addr, src_mac, 6);
- device.sll_halen = htons (6);
- // 发送的data,长度可以任意,但是抓包时看到最小数据长度为46,这是以太网协议规定以太网帧数据域部分最小为46字节,不足的自动补零处理
- datalen = 12;
- data[0] = 'h';
- data[1] = 'e';
- data[2] = 'l';
- data[3] = 'l';
- data[4] = 'o';
- data[5] = ' ';
- data[6] = 'w';
- data[7] = 'o';
- data[8] = 'r';
- data[9] = 'l';
- data[10] = 'd';
- data[11] = '!';
- // Fill out ethernet frame header.
- frame_length = 6 + 6 + 2 + datalen;
- // Destination and Source MAC addresses
- memcpy (ether_frame, dst_mac, 6);
- memcpy (ether_frame + 6, src_mac, 6);
- ether_frame[12] = ETH_P_DEAN / 256;
- ether_frame[13] = ETH_P_DEAN % 256;
- // data
- memcpy (ether_frame + 14 , data, datalen);
- // Submit request for a raw socket descriptor.
- if ((sd = socket (PF_PACKET, SOCK_RAW, htons (ETH_P_DEAN))) < 0)
- {//创建正真发送的socket
- perror ("socket() failed ");
- // Send ethernet frame to socket.
- if ((bytes = sendto (sd, ether_frame, frame_length, 0, (struct sockaddr *) &device, sizeof (device))) <= 0)
- perror ("sendto() failed");
- printf ("send num=%d,read num=%d\n",frame_length,bytes);
- // Close socket descriptor.
- close (sd);
- return (EXIT_SUCCESS);
只能采用其它方式。
