显示xianshi
 楼主| 34af9uc 发表于 2023-11-21 21:37 | 显示全部楼层 |阅读模式
#define        led_wei1                        PC1
#define        led_wei1_out                TRISC1
#define        led_wei2                        PB0
#define        led_wei2_out                TRISB0
#define        led_wei3                        PB2
#define        led_wei3_out                TRISB2
#define        led_a                                PB7
#define        led_a_out                        TRISB7
#define        led_b                                PB4
#define        led_b_out                        TRISB4
#define        led_c                                PB1
#define        led_c_out                        TRISB1
#define        led_d                                PA4
#define        led_d_out                        TRISA4
//#define        led_e                                PA2←←←←←←←←←←
//#define        led_e_out                        TRISA2←←←←←←←←←←
#define        led_e                                PC0
#define        led_e_out                        TRISC0
#define        led_f                                PA3
#define        led_f_out                        TRISA3
#define        led_g                                PB3
#define        led_g_out                        TRISB3
#define        led_h                                PA0
#define        led_h_out                        TRISA0
/*#define        led_1                                PC0
#define        led_1_out                        TRISC0
#define        led_2                                PA7
#define        led_2_out                        TRISA7*/
#define        shuchu                                PA1
#define        shuchu_out                        TRISA1
#define        anj_jia                                PA5
#define        anj_jia_out                        TRISA5
#define        anj_jia_shangla                WPUA |=1 <<5
#define        anj_shezhi                        PA6
#define        anj_shezhi_out                TRISA6
#define        anj_shezhi_shangla        WPUA |=1 <<6
#define        anj_jian                        PB5
#define        anj_jian_out                TRISB5
#define        anj_jian_shangla        WPUB |=1 <<5
void                xianshi_chushihua()                //显示初始化
TIM4EN                =1;                //TIM4 模块时钟
SYSON                =0;                //睡眠模式下,系统时钟控制
T4ARPE                =1;                //计数周期的自动预装载
T4CKS1                =0;                //00=Sysclk
T4CKS0                =0;
T4OPM                =0;                //单脉冲模式关闭
T4URS                =1;                //更新事件中断源计数器上溢
T4UDIS                =0;                //产生更新事件控制0=允许
T4CEN                =1;                //TIM4 计数器使能
T4PSC2                =1;                //Timer4预分频器110 = 64
T4PSC1                =1;
T4PSC0                =0;
//T4CNT                                //Timer4计数值
TIM4ARR                =103;        //预装载值50HZ
//TIM4ARR                =68;        //预装载值75HZ
GIE                        =1;                //全局中断
PEIE                =1;                //外设总中断
T4UIE                =1;                //Timer4 更新事件中断
//T4UG                =1;                //Timer4 更新事件软件中断
//T4UIF
led_wei1                        =1;                //消隐
led_wei2                        =1;
led_wei3                        =1;
led_a                                =0;
led_b                                =0;
led_c                                =0;
led_d                                =0;
led_e                                =0;
led_f                                =0;
led_g                                =0;
led_h                                =0;
led_wei1_out                =0;                //输出模式
led_wei2_out                =0;
led_wei3_out                =0;
led_a_out                        =0;
led_b_out                        =0;
led_c_out                        =0;
led_d_out                        =0;
led_e_out                        =0;
led_f_out                        =0;
led_g_out                        =0;
led_h_out                        =0;
volatile char xianshi_a1 =1;
volatile char xianshi_b1;
void interrupt ISR(void)
#asm;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
#endasm;//系统设置不可以删除和修改
if(T4UIE&&T4UIF)
T4UIF                =1;
if(xianshi_a1 ==1)
        led_wei1                =0;
        led_wei2                =1;
        led_wei3                =1;
        led_a                                =0;
        led_b                                =1;
        led_c                                =1;
        led_d                                =0;
        led_e                                =0;
        led_f                                =0;
        led_g                                =0;
        led_h                                =0;
 楼主| 34af9uc 发表于 2023-11-21 21:39 | 显示全部楼层
#asm;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
        NOP;//系统设置不可以删除和修改
if(T4UIE&&T4UIF)
T4UIF                =1;
if(xianshi_a1 ==1)
    led_wei1                =1;                //消隐
        led_wei2                =1;
        led_wei3                =1;
        led_a                                =0;
        led_b                                =1;
        led_c                                =1;
        led_d                                =0;
        led_e                                =0;
        led_f                                =0;
        led_g                                =0;
        led_h                                =0;
        led_wei1                =0;
        led_wei2                =1;
        led_wei3                =1;
   if(xianshi_a1 ==2)
    led_wei1                =1;
        led_wei2                =1;
        led_wei3                =1;
        led_a                                =1;
        led_b                                =1;
        led_c                                =0;
        led_d                                =1;
        led_e                                =1;
        led_f                                =0;
        led_g                                =1;
        led_h                                =0;
    led_wei1                =1;
        led_wei2                =0;
        led_wei3                =1;
   if(xianshi_a1 ==3)
        led_wei1                =1;
        led_wei2                =1;
        led_wei3                =1;
        led_a                                =1;
        led_b                                =1;
        led_c                                =1;
        led_d                                =1;
        led_e                                =0;
        led_f                                =0;
        led_g                                =1;
        led_h                                =0;
    led_wei1                =1;
        led_wei2                =1;
        led_wei3                =0;
xianshi_a1 ++;
if(xianshi_a1 >3){xianshi_a1 =1;}
319
