[国民技术] 国民技术芯片N32A455的定时器使用
 楼主| 76282 发表于 2024-12-19 10:34 | 显示全部楼层 |阅读模式
本文用TIM6创建1毫秒定时器为例子,讲解定时器的用法。
#define BTIM_INT                             TIM6
#define BTIM_INT_IRQn                   TIM6_IRQn
#define BTIM_INT_IRQHandler         TIM6_IRQHandler
#define BTIM_INT_CLK_ENABLE()  do{ RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_TIM6, ENABLE); }while(0)  /* 时钟使能 */
* @brief       基本定时器TIMX定时中断初始化函数
* @note
*              基本定时器的时钟来自APB1, 当PRES ≥ 2分频的时候
*              基本定时器的时钟为APB1时钟的2倍, 而APB1为36M, 所以定时器时钟 = 72Mhz
*              定时器溢出时间计算方法: Tout = ((u16Arr + 1) * (u16Psc + 1)) / Ft us.
*               Freq = Ft / ((u16Arr+1) * (u16Psc + 1)) => 72000000 / (72 * 1000) = 1000Hz
*              Ft=定时器工作频率,单位:Mhz
* @param       u16Psc : 时钟预分频数
* @param       u16Arr : 自动重装值
* @retval      无
void BTIM_Init(U16 u16Psc, U16 u16Arr)
    NVIC_InitType NVIC_InitStructure;
    TIM_TimeBaseInitType TIM_TimeBaseStructure;
    /* PCLK1 = HCLK/4 */
    RCC_ConfigPclk1(RCC_HCLK_DIV4);
    /* TIMx clock enable */
    BTIM_INT_CLK_ENABLE();
    /* Enable the TIMx global Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel                   = BTIM_INT_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    /* Time base configuration */
    TIM_InitTimBaseStruct(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.Period    = u16Arr;
    TIM_TimeBaseStructure.Prescaler = u16Psc;
    TIM_TimeBaseStructure.ClkDiv    = 0;
    TIM_TimeBaseStructure.CntMode   = TIM_CNT_MODE_UP;
    TIM_InitTimeBase(BTIM_INT, &TIM_TimeBaseStructure);
    /* Prescaler configuration */
    TIM_ConfigPrescaler(BTIM_INT, u16Psc, TIM_PSC_RELOAD_MODE_IMMEDIATE);
    /* TIMx enable update irq */
    TIM_ConfigInt(BTIM_INT, TIM_INT_UPDATE, ENABLE);
    /* TIMx enable counter */
    TIM_Enable(BTIM_INT, ENABLE);
原文链接:https://blog.csdn.net/xbzjackey/article/details/142731566
