[经验分享] C语言的排序算法有哪些?
 楼主| Haizangwang 发表于 2025-6-11 22:03 | 显示全部楼层 |阅读模式
C语言的排序算法有很多种,以下是一些常见的排序算法及其实现示例代码:
冒泡排序(Bubble Sort)
void bubbleSort(int arr[], int n) {
    int i, j;
    for (i = 0; i < n - 1; i++) {
        for (j = 0; j < n - i - 1; j++) {
            if (arr[j] > arr[j + 1]) {
                int temp = arr[j];
                arr[j] = arr[j + 1];
                arr[j + 1] = temp;
选择排序(Selection Sort)
void selectionSort(int arr[], int n) {
    int i, j, minIndex;
        minIndex = i;
        for (j = i + 1; j < n; j++) {
            if (arr[j] < arr[minIndex]) {
                minIndex = j;
        if (minIndex != i) {
            int temp = arr[i];
            arr[i] = arr[minIndex];
            arr[minIndex] = temp;
插入排序(Insertion Sort)
void insertionSort(int arr[], int n) {
    int i, j, temp;
    for (i = 1; i < n; i++) {
        temp = arr[i];
        j = i - 1;
        while (j >= 0 && arr[j] > temp) {
            arr[j + 1] = arr[j];
            j--;
        arr[j + 1] = temp;
快速排序(Quick Sort)
int partition(int arr[], int low, int high) {
    int pivot = arr[high];
    int i = low - 1;
    int j, temp;
    for (j = low; j < high; j++) {
        if (arr[j] < pivot) {
            i++;
            temp = arr[i];
            arr[i] = arr[j];
            arr[j] = temp;
    temp = arr[i + 1];
    arr[i + 1] = arr[high];
    arr[high] = temp;
    return i + 1;
void quickSort(int arr[], int low, int high) {
    if (low < high) {
        int pi = partition(arr, low, high);
        quickSort(arr, low, pi - 1);
        quickSort(arr, pi + 1, high);
归并排序(Merge Sort)
void merge(int arr[], int left, int mid, int right) {
    int i, j, k;
    int n1 = mid - left + 1;
    int n2 = right - mid;
    int L[n1], R[n2];
    for (i = 0; i < n1; i++) {
        L[i] = arr[left + i];
    for (j = 0; j < n2; j++) {
        R[j] = arr[mid + 1 + j];
    i = 0;
    j = 0;
    k = left;
    while (i < n1 && j < n2) {
        if (L[i] <= R[j]) {
            arr[k] = L[i];
            i++;
        } else {
            arr[k] = R[j];
            j++;
        k++;
    while (i < n1) {
        arr[k] = L[i];
        i++;
        k++;
    while (j < n2) {
        arr[k] = R[j];
        j++;
        k++;
void mergeSort(int arr[], int left, int right) {
    if (left < right) {
        int mid = left + (right - left) / 2;
        mergeSort(arr, left, mid);
        mergeSort(arr, mid + 1, right);
        merge(arr, left, mid, right);
堆排序(Heap Sort)
void heapify(int arr[], int n, int i) {
    int largest = i;
    int left = 2 * i + 1;
    int right = 2 * i + 2;
    int temp;
    if (left < n && arr[left] > arr[largest]) {
        largest = left;
    if (right < n && arr[right] > arr[largest]) {
        largest = right;
    if (largest != i) {
        temp = arr[i];
        arr[i] = arr[largest];
        arr[largest] = temp;
        heapify(arr, n, largest);
void heapSort(int arr[], int n) {
    int i, temp;
    for (i = n / 2 - 1; i >= 0; i--) {
        heapify(arr, n, i);
    for (i = n - 1; i >= 0; i--) {
        temp = arr[0];
        arr[0] = arr[i];
        arr[i] = temp;
        heapify(arr, i, 0);
以上是常见的一些C语言排序算法及其实现示例代码,每一种算法都有自己的特点和适用场景。
原文链接:https://blog.csdn.net/shufawangzhang/article/details/130859090
chenqianqian 发表于 2025-6-11 22:15 来自手机 | 显示全部楼层
冒泡法排序比较常用,也是大学C语言教程里面的例子。
