[技术问题解答] Freeing init memory: 252KEXT4-fs (mmcblk0p7): re-mounted. (已解决)
 楼主| xiaoholmes 发表于 2014-9-10 16:59 | 显示全部楼层 |阅读模式
1、imx6板子运行到Freeing init memory: 252K就down掉了,但是不是每次都运行不了,多次android能够启动,大概连续10次有2到3次运行不了。Freeing init memory: 252K后面是挂载硬盘驱动的地方吗?板子上没有连接硬盘。
2、另外板子运行会出现EXT4-fs (mmcblk0p7): re-mounted,这里消耗时间很长,正常启动应该是没有
注:以下是部分信息,附件中是全部信息
DVFSdriver module loaded
regulator_init_complete:VDDD: incomplete constraints, leaving on
regulator_init_complete:VDDIO: incomplete constraints, leaving on
regulator_init_complete:VDDA: incomplete constraints, leaving on
snvs_rtcsnvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Freeinginit memory: 252K
init:cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
android_usb:already disabled
mtp_bind_config
adb_bind_config
adb_open
root@android:/# android_work: sent uevent USB_STATE=DISCONNECTED
android_work:sent uevent USB_STATE=CONNECTED
android_work:sent uevent USB_STATE=DISCONNECTED
EXT4-fs(mmcblk0p7): re-mounted. Opts: (null)
root@android:/ #android_work: sent uevent USB_STATE=DISCONNECTED
android_work: sent ueventUSB_STATE=CONNECTED
android_work: sent ueventUSB_STATE=DISCONNECTED
(正常启动没有红色这几行,非正常启动里面有这几行)
mcu_input_drv_opendo nothing inode:d1227690, file:d53fb460
android_work: sent uevent USB_STATE=CONNECTED
(正常启动有红色这几行,非正常启动里面没有这几行)
------------[cut here ]------------
WARNING:at arch/arm/plat-mxc/clock.c:63 clk_disable+0x44/0x8c()
clockenable/disable mismatch! clk  ipu1_clk
Moduleslinked in:
[<c0054e84>](unwind_backtrace+0x0/0x138) from [<c008f5dc>](warn_slowpath_common+0x4c/0x64)
[<c008f5dc>](warn_slowpath_common+0x4c/0x64) from [<c008f688>](warn_slowpath_fmt+0x30/0x40)
[<c008f688>](warn_slowpath_fmt+0x30/0x40) from [<c0070fa8>] (clk_disable+0x44/0x8c)
[<c0070fa8>](clk_disable+0x44/0x8c) from [<c02e6cfc>] (mxcfb_set_par+0x688/0x820)
[<c02e6cfc>](mxcfb_set_par+0x688/0x820) from [<c02d5420>] (fb_set_var+0x124/0x290)
[<c02d5420>](fb_set_var+0x124/0x290) from [<c02d5898>] (do_fb_ioctl+0x30c/0x5d0)
[<c02d5898>](do_fb_ioctl+0x30c/0x5d0) from [<c0140ba0>] (do_vfs_ioctl+0x80/0x54c)
[<c0140ba0>](do_vfs_ioctl+0x80/0x54c) from [<c01410a4>] (sys_ioctl+0x38/0x5c)
[<c01410a4>](sys_ioctl+0x38/0x5c) from [<c004d900>] (ret_fast_syscall+0x0/0x30)
---[ endtrace 08cc01c35d331764 ]---
panelsize = 800 x 480
pixel clk= 27000000
usespecial clk parent
panelsize = 1280 x 720
pixelclk = 74250000
tryipu internal clk
tryipu ext di clk
imx-ipuv3imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
ERROR:v4l2 capture: slave not found!
ERROR: v4l2 capture: slave not found!
ERROR: HDMI is not ready!
asoc: can't open platform imx-hdmi-soc-audio.0
panel size = 1280 x 720
pixel clk = 74250000
try ipu internal clk
try ipu ext di clk
(正常启动有红色这几行,非正常启动里面在上面)
[ep9851_task] EP9851: Signal Valid
[ep9851_task] EP9851: HDMI
[ep9851_task] EP9851: AVI Chg
EXT4-fs (mmcblk0p7): re-mounted. Opts:(null)
//重新挂载,消耗时间很长,正常启动没有这条
[ep9851_task] EP9851: VMute Dsb
warning: `zygote' uses 32-bit capabilities (legacy support inuse)
//在此等待的时间大约有8
request_suspend_state:wakeup (3->0) at 26857698672 (1970-01-02 00:00:10.923768334 UTC)
cpufreq_interactive_input_connect:connect to imx-uart-input
cpufreq_interactive_input_connect:connect to max11801_ts
acc_open
acc_release
ehci_fsl_bus_resumebegins, Host 1
ehci_fsl_bus_resume ends, Host 1
in test mode, but singlestep NOT on
ehci_fsl_bus_resumebegins, DR
ehci_fsl_bus_resume begins, DR
init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
(正常启动有上面这几行,非正常启动里面没有这几行)
ehci_fsl_bus_suspendbegins, Host 1
ehci_fsl_bus_suspendends, Host 1
init: sys_prop:permission denied uid:1003 name:service.bootanim.exit
(正常启动没有红色这一行,非正常启动里面有这一行)
root@android:/#
android正常启动.pdf
128.69 KB, 下载次数: 38
 楼主| xiaoholmes 发表于 2014-9-12 08:53 | 显示全部楼层
在线等,为啥在Freeinginit memory: 252K,只要过了这个信息点就可以启动,虽然有时候能过去,但是也有时候却down在这个地方,然后就启动不了,搞不懂了,这个地方是挂载硬盘的地方吗?
FSL_TICS_Rita 发表于 2014-9-28 14:33 | 显示全部楼层
楼主你好,你还建了另外的帖子吧,我已经给你回复了,请注意查看哈~~
mini1986 发表于 2015-4-17 15:32 | 显示全部楼层
关注中,我的遇到了Freeing init memory不能往下执行的情况,能说下你怎么解决的么?......
