运行bin2txt.pyw 报错:
root@pite-virtual-machine:/# ./bin2txt.pyw
./bin2txt.pyw: line 34: $'\r': command not found
./bin2txt.pyw: line 35: import: command not found
./bin2txt.pyw: line 36: import: command not found
./bin2txt.pyw: line 38: import: command not found
./bin2txt.pyw: line 40: import: command not found
./bin2txt.pyw: line 41: $'\r': command not found
./bin2txt.pyw: line 43: import: command not found
./bin2txt.pyw: line 45: $'\r': command not found
./bin2txt.pyw: line 46: syntax error near unexpected token `('
'/bin2txt.pyw: line 46: `def Print_Help():
请教各位高手,bin2txt.pyw 这个软件是怎么用的啊,我怎么才能转换bmp文件为c文件,
