2.6. Instruction set The processor does not support ARM instructions.
The processor supports all ARMv6 Thumb instructions except those listed in Table 2.4.
Table 2.4. Nonsupported Thumb instructions
Instruction Action if executed BLX(1) Branch with link and exchange BLX(1) always faults. SETEND Set endianness SETEND always faults. A configuration pin selects Cortex-M3 endianness.
The processor supports the Thumb-2 instructions listed in Table 2.5.
Table 2.5. Supported Thumb-2 instructions
Instruction type Size Instructions Data operations 16 ADC, ADD, AND, ASR, BIC, CMN, CMP, CPY, EOR, LSL, LSR, MOV, MUL, MVN, NEG, ORR, ROR, SBC, SUB, TST, REV, REVH, REVSH, SXTB, SXTH, UXTB, and UXTH. Branches 16 B<cond>, B, BL, BX, and BLX. Note, no BLX with immediate. Load-store single 16 LDR, LDRB, LDRH, LDRSB, LDRSH, STR, STRB, STRH. Load-store multiple 16 LDMIA, POP, PUSH, and STMIA. Exception generating 16 BKPT stops in debug if debug enabled, fault if debug disabled. SVC faults to the SVCall handler. Data operations with immediate 32 ADC{S}. ADD{S}, CMN, RSB{S}, SBC{S}, SUB{S}, CMP, AND{S}, TST, BIC{S}, EOR{S}, TEQ, ORR{S}, MOV{S}, ORN{S}, and MVN{S}. Data operations with large immediate 32 MOVW, MOVT, ADDW, and SUBW.
MOVW and MOVT have a 16-bit immediate. This means they can replace literal loads from memory.
ADDW and SUBW have a 12-bit immediate. This means they can replace many from memory literal loads. Bit-field operations 32 BFI, BFC, UBFX, and SBFX. These are bitwise operations enabling control of position and size in bits. These both support C/C++ bit fields, in structs, in addition to many compare and some AND/OR assignment expressions. Data operations with three registers 32 ADC{S}. ADD{S}, CMN, RSB{S}, SBC{S}, SUB{S}, CMP, AND{S}, TST, BIC{S}, EOR{S}, TEQ, ORR{S}, MOV{S}, ORN{S}, and MVN{S}. No PKxxx instructions. Shift operations 32 ASR{S}, LSL{S}, LSR{S}, RRX {S}, and ROR {S}. Miscellaneous 32 REV, REVH, REVSH, RBIT, CLZ, SXTB, SXTH, UXTB, and UXTH.
Extension instructions same as corresponding v6 16-bit instructions. Table branch 32 TBB and TBH table branches for switch/case use. These are LDR with shifts and then branch. Multiply 32 MUL, MLA, and MLS. Multiply with 64-bit result 32 UMULL, SMULL, UMLAL, and SMLAL. Load-store addressing 32 Supports Format PC+/-imm12, Rbase+imm12, Rbase+/-imm8, and adjusted register including shifts.
T variants used when in Privilege mode. Load-store single 32 LDR, LDRB, LDRSB, LDRH, LDRSH, STR, STRB, STRH, and T variants. PLD and PLI are both hints and so act as a NOP. Load-store multiple 32 STM, LDM, LDRD, and STRD. Load-store exclusive 32 LDREX, STREX, LDREXB, LDREXH, STREXB, STREXH, CLREX.
Fault if no local monitor. This is IMP DEF.
LDREXD and STREXD are not included in this profile. Branches 32 B, BL, and B<cond>. No BLX (1) because always changes state. No BXJ. System 32 MSR(2) and MRS(2) replace MSR/MRS but also do more. These access the other stacks and also the status registers.
CPSIE/CPSID 32-bit forms are not supported.
No RFE or SRS. System 16 CPSIE and CPSID are quick versions of MSR(2) instructions and use the standard Thumb-2 encodings, but only permit use of i and f and not a. Extended32 32 NOP (all forms), Coprocessor (MCR, MCR2, MCRR, MRC, MRC2, and MRRC), and YIELD (hinted NOP). Note, no MRS(1), MSR(1), or SUBS (PC return link). Combined branch 16 CBZ and CBNZ (Compare and Branch if register is Zero or Non-Zero). Extended 16 IT and NOP. This includes YIELD. Divide 32 SDIV and UDIV. 32/32 divides both signed and unsigned with 32-bit quotient result, no remainder, it can be derived by subtraction. Early out is permitted. Sleep 16, 32 WFI, WFE, and SEV are in the class of hinted NOP instructions that control sleep behavior. Barriers 32 ISB, DSB, and DMB are barrier instructions that ensure certain actions have taken place before the next instruction is executed. Saturation 32 SSAT and USAT perform saturation on a register. They perform the following:
Normalize the value using shift test for overflow from a selected bit position, the Q value.
Set the xPSR Q bit if so, saturate the value if overflow detected.
Saturation refers to the largest unsigned value or the largest/smallest signed value for the size selected
