ZET6支持SDRAM吗,请问?急谢谢
 楼主| cq_ric 发表于 2009-3-26 15:37 | 显示全部楼层 |阅读模式
ARM 32-bit Cortex-M3 Microcontroller, 72MHz, 512kB Flash, 64kB SRAM,
External Memory Interface (EMI) for SDRAM, SRAM, Flash, ROM,
PLL, Embedded Internal RC 8MHz and 32kHz, Real-Time Clock,
Nested Interrupt Controller, Power Saving Modes, JTAG and SWD,
4 Synch. 16-bit Timers with Input Capture, Output Compare and PWM,
2 16-bit Advanced Timer, 2 16-bit Basic Timer, 2 16-bit Watchdog Timers,
SysTick Timer, 3 SPI/I2S, 2 I2C, 5 USART, USB 2.0 Full Speed Interface,
CAN 2.0B Active, 3 12-bit 16-ch A/D Converter, 2 12-bit D/A Converter,
SDIO, Fast I/O Ports
上面是我在KEIL  device描述里考出来的。请问要支持SDRAM不?
pb486 发表于 2009-3-26 16:48 | 显示全部楼层
肯定不能用SDRAM,描述有错误,
hz_richard 发表于 2009-3-26 16:58 | 显示全部楼层
看来只能看技术资料了呢,
香水城 发表于 2009-3-26 17:51 | 显示全部楼层
STM32F103ZET6不支持SDRAM
楼主抄的这段话是错的,请以ST的数据手册为准。
