板子是官方的,代码没修改什么地方,编译下载完后,接上鼠标启动后,出现信息如下:
root@sabreauto_6q:/ # usb 2-1: device not accepting address 9, error -71
hub 2-0:1.0: unable to enumerate USB device on port 1
mxc_hdmi mxc_hdmi: Read EDID again
mxc_hdmi mxc_hdmi: No modes read from edid
mxc_hdmi mxc_hdmi: create default modelist
fbcvt: 1920x1080@60: CVT Name - 2.073M9
ERROR: v4l2 capture: slave not found!
usb 2-1: new low speed USB device number 10 using fsl-ehci
usb 2-1: device descriptor read/64, error -71
usb 2-1: new low speed USB device number 11 using fsl-ehci
usb 2-1: new low speed USB device number 12 using fsl-ehci
usb 2-1: device not accepting address 12, error -71
usb 2-1: new low speed USB device number 13 using fsl-ehci
usb 2-1: device not accepting address 13, error -71
usb 2-1: new low speed USB device number 14 using fsl-ehci
usb 2-1: new low speed USB device number 15 using fsl-ehci
usb 2-1: new low speed USB device number 16 using fsl-ehci
usb 2-1: device not accepting address 16, error -71
usb 2-1: new low speed USB device number 17 using fsl-ehci
usb 2-1: device not accepting address 17, error -71
warning: `zygote' uses 32-bit capabilities (legacy support in use)
period 0 ,timeout is 0, wake up is :0
usb 2-1: new low speed USB device number 18 using fsl-ehci
usb 2-1: new low speed USB device number 19 using fsl-ehci
usb 2-1: new low speed USB device number 20 using fsl-ehci
usb 2-1: device not accepting address 20, error -71
usb 2-1: new low speed USB device number 21 using fsl-ehci
usb 2-1: device not accepting address 21, error -71
request_suspend_state: wakeup (3->0) at 23911712671 (1970-01-02 00:55:21.577410669 UTC)
period 66 ,timeout is 0, wake up is :0
mma enable setting active
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
usb 2-1: new low speed USB device number 22 using fsl-ehci
acc_open
acc_release
求救啊 没有屏,我就想用鼠标在显示器上解个锁而已 |
