SIM: Subscriber Identity Module
UART: Universal Asynchronous Receiver/Transmitter
SPI: Serial Port Interface
LCD: Liquid Crystal Display
GPIO: General Purpose Input/Output
GPT: General Purpose Timer
RTC: Real Time Clock
WDT: Watch Dog Timer
PWM: Pulse Width Modulation
PMIC: Power Management IC
BMT: Battery Charging Management task
AUX task: Auxiliary task
ADC Sched.: Analog to Digital Converter Scheduler
USB task: The USB 1.1 protocol and driver
IrDA task: The IrDA and driver
Camera: Camera driver for integrating with 3rd party camera module
MSDC: Memory card driver, supporting SD, MMC cards and Memory Stick
JPEG Decoder: Software for controlling hardware JPEG decoder
FMI Feature rich MM
ATCI: AT Command Interpreter
L4A: L4 adaptation Layer, MMI与L4A通过消息通信
L4C: L4 Control entity, 处理所有的应用程序请求和响应
UEM: User equipments adaptation, 驱动相关的适配层
SMU: SIM management Unit
CSM: Circuit switching protocol stack management电路交换协议栈管理
RAC: Registration access control
SMSAL: Short message service application layer
TCM: Terminal context management
NVRAM : Nor-volatile RAM, 是MMI到Flash的一个适配层, 保存一些默认设置
SIM : Subscriber identity module. Handle SIM behavior as ETSI 11.11 description
CC :Circuit-switched call control 电路交换呼叫控制
SS : supplementary service 附加服务
SMS: short message service 短消息服务
SM : session management 会话管理
MM/GMM : mobility management 移动性能管理
SNDCP : sub-network dependent convergence protocol
LLC : Logical link control 逻辑连接控制
RR : Radio resource management
RLC: Radio link control protocol
MAC: Medium access control protocol
PPP : Point to Point protocol layer,客户端点对点协议
APE : Application Processor Engine
AEC: Auto Exposure Control
AWB : Auto White Balance
CCP2: Compact Camera Port 2
EMC : Electro Magnetic Compatibility
HWA : hardware Accelerator
I2C : Inter ICbus
IF : Interface
IO : Input/Output
ISP : Image Signal Processor
SMIA: Standard Mobile Imaging Architecture
FPD : Flat Panel Display 平板显示器
LCD: Liquid Crystal Display 液晶显示器
STN: Super Twisted Nematic 超扭曲向列
TFT : Thin Film Transistor 薄膜晶体管
OLED: Organic Light Emitting Display 有机发光显示屏
CIF: Common Intermediate Format, 352 x 288.
VGA: Video Graphics Array, 640 x 480.
SXGA: Super Extended Graphics Array, 1280 x 1024.
UXGA: Ultra Extended Graphics Array, 1600 x 1200.
RGU: Reset Generation Unit
L2C: Data cache controller
GCU: GPRS Crypto Unit
SWDBG: Software Debug
NFI: NAND Flash Interface
SCCB: Serial Camera Control Bus
PWM: Pulse Width Modulator
CHE :Cipher Hash Engine
MMC: Multi-Media Card
B2PSI: Baseband to PMIC Serious Interface
RTC: Real Time Clock unit
BSI: Baseband Serial Interface
BPI :Baseband Parallel Interface
BFE :Base-band Front End
GMC :Graphics Memory Controller
SAIC: Single Antenna Interference Cancellation
DMA: Direct Memory Access
DAI: Digital Audio Interface
APC: Automatic power control
EMI: External Memory Interface.
EMC:External Memory Controller
FSC: Frame Check Sequence. |
