安装CCS3.1后用的是仿真器连接不上出现SEED510,芯片2812
Error connecting to the target:
Error 0x80000240/-2092
Fatal Error during: Initialization, OCS,
Device driver: Emulation Connection Loss Detected on Target CPU.
It is recommended to RESET EMULATOR. This will disconnect each
target from the emulator. The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
Sequence ID: 0
Error Code: -2092
Error Class: 0x80000240
I/O Port = 240 |
