收藏0 举报
查看全部评分
static uint8_t OLED_WriteData(uint8_t Data) { I2C_Start(); I2C_SendByte(I2C_OLED); if(I2C_WaitAck()) return 1; I2C_SendByte(0x40); if(I2C_WaitAck()) return 2; I2C_SendByte(Data); if(I2C_WaitAck()) return 3; I2C_Stop(); return 0; } static uint8_t OLED_SetXY(uint8_t x,uint8_t y) { OLED_WriteCmd(0xb0|y);//y OLED_WriteCmd(((0xf0&x)>>4))|0x10);//设置x高4位 OLED_WriteCmd(((0x0f&x)>>4))|0x01);//设置x低4位 } uint8_t OLED_Clear(void) { uint8_t x,y; OLED_SetXY(0,0); for(y=0;y<OLED_HIGH/8;y++) { if(OLED_SetXY(0,y)) return 1; for(x=0;x<OLED_WIDTH;x++) { if(OLED_WriteData(0x00)) return 2; } } return 0; } uint8_t OLED_Init(void) { // 延时一下 再初始化 OLED_Delay(100000); if(OLED_WriteCmd(0xae)) return 1;//--turn off oled panel if(OLED_WriteCmd(0x00)) return 2;//---set low column address if(OLED_WriteCmd(0x10)) return 3;//---set high column address if(OLED_WriteCmd(0x40)) return 4;//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F) if(OLED_WriteCmd(0x81)) return 5;//--set contrast control register if(OLED_WriteCmd(Brightness)) return 6; // Set SEG Output Current Brightness if(OLED_WriteCmd(0xa1)) return 7;//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常 if(OLED_WriteCmd(0xc8)) return 8;//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常 if(OLED_WriteCmd(0xa6)) return 9;//--set normal display if(OLED_WriteCmd(0xa8)) return 10;//--set multiplex ratio(1 to 64) if(OLED_WriteCmd(0x3f)) return 11;//--1/64 duty if(OLED_WriteCmd(0xd3)) return 12;//-set display offset Shift Mapping RAM Counter (0x00~0x3F) if(OLED_WriteCmd(0x00)) return 13;//-not offset if(OLED_WriteCmd(0xd5)) return 14;//--set display clock divide ratio/oscillator frequency if(OLED_WriteCmd(0x80)) return 15;//--set divide ratio, Set Clock as 100 Frames/Sec if(OLED_WriteCmd(0xd9)) return 16;//--set pre-charge period if(OLED_WriteCmd(0xf1)) return 17;//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock if(OLED_WriteCmd(0xda)) return 18;//--set com pins hardware configuration if(OLED_WriteCmd(0x12)) return 19; if(OLED_WriteCmd(0xdb)) return 20;//--set vcomh if(OLED_WriteCmd(0x40)) return 21;//Set VCOM Deselect Level if(OLED_WriteCmd(0x20)) return 22;//-Set Page Addressing Mode (0x00/0x01/0x02) if(OLED_WriteCmd(0x02)) return 23;// if(OLED_WriteCmd(0x8d)) return 24;//--set Charge Pump enable/disable if(OLED_WriteCmd(0x14)) return 25;//--set(0x10) disable if(OLED_WriteCmd(0xa4)) return 26;// Disable Entire Display On (0xa4/0xa5) if(OLED_WriteCmd(0xa6)) return 27;// Disable Inverse Display On (0xa6/a7) if(OLED_WriteCmd(0xaf)) return 28;//--turn on oled panel if(OLED_Clear(0x00)) return 29; //初始清屏 if(OLED_SetXY(0,0)) return 30; return 0; }
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
时间类勋章
29
164
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
