按遥控器发射红外信号程序进入中断后会一直卡在 while (IRIN); //等 IR 变为低电平 是不是单片机检测不到红外接收头发出的低电平啊 还是什么原因 求大神解释
//void Clock_Init();
void LCD_write_str(unsigned char x,unsigned char y,unsigned char *s);
void LCD_write_char(unsigned char x,unsigned char y,unsigned char data);
void LCD_init(void);
void Port_init();
#define RS_CLR P1OUT &= ~0x01 //RS置低P1.0 = 0
#define RS_SET P1OUT |= 0x01 //RS置高P1.0 = 1
#define RW_CLR P1OUT &= ~0x08 //RW置低
#define RW_SET P1OUT |= 0x08 //RW置高
#define EN_CLR P1OUT &= ~0x04 //E置低
#define EN_SET P1OUT |= 0x04
#define DataPort P2OUT
typedef unsigned char uchar;
typedef unsigned int uint;
#define CPU_F ((double)1000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define IR_DIR_IN P1DIR&=~BIT1 //红外接收头P1.1设置为输入,
#define IRIN (P1IN&BIT1) //红外接收头输入值
char data[4]; //保存地址码,地址反码,数据码,数据反码
char m;
void xianshi();
unsigned char num_char_table[]={"0123456789"};
unsigned char temp;
系统初始化
void InitSys()
WDTCTL = WDTPW + WDTHOLD; //关闭看门狗
DCOCTL=CALDCO_1MHZ;
BCSCTL1=CALBC1_1MHZ;
P1IE|=BIT1; //P1.1中断功能打开
P1IES|=BIT1; //P1.1下降沿触发中断
IR_DIR_IN; //P1.1设置为输入
_EINT(); //打开全局中断控制
int main( void )
InitSys(); //初始化
Port_init();
//delay_ms(100);
LCD_init();
LCD_clear();
while(1)
xianshi();
void xianshi()
LCD_write_str(0,0,"temperature:");
LCD_write_char(0,1,num_char_table[temp/100]);
LCD_write_char(1,1,num_char_table[temp%100/10]);
LCD_write_char(2,1,'.');
LCD_write_char(3,1,num_char_table[temp%10]);
//LCD_write_char(4,1,num_char_table[0]);
LCD_write_str(5,1,"'C");
端口1中断函数
#pragma vector=PORT1_VECTOR
__interrupt void Port1()
char i,j,k=0,m=1;
if((P1IFG&BIT1) == BIT1)
P1IFG &= ~BIT1; //清除P1.1中断标志
P1IE &=~BIT1; //关闭P1.1中断功能
for (i=0;i<8;i++) //等待9ms引导码,在9ms内出现高电平则退出解码
delay_ms(1);
if (IRIN==1) m=0;
while(!IRIN); //等 IR 变为高电平
delay_ms(4); //等待4.5ms结果码
if(m==1)
for(k=0;k<4;k++)
for (j=0;j<8;j++)
delay_us(500); //等待560us低电平
while (!IRIN); //等 IR 变为高电平
char n=0;
while (IRIN) //计算IR高电平时长
delay_us(140);
n++;
data[k]=data[k]>>1;
if (n<7) {data[k]&=0x7f;}
else
if(n>=7&&n<13)
{data[k]|=0x80;}
else
if (n>=13)
P1IE|=BIT1;
temp=data[2];
P1IE|=BIT1;
void Port_init()
P2SEL = 0x00;
P2DIR = 0xFF; // 设置为输出状态
P1SEL = 0x00;
//P2DIR |= BIT5 + BIT6 + BIT7;//为什么呢? RS/RW/EN赋值是给P2.0—P2.2的,
P1DIR |= BIT0 + BIT3 + BIT2; //P2口德567位设置为输出 01234作为输入
//控制口设置为输出模式
//显示屏命令写入函数
void LCD_write_com(unsigned char com)
RS_CLR;//P2.0 = 0
RW_CLR;//P2.1 = 0
EN_SET;//P2.2 = 1 允许写入数据
DataPort = com; //写入的命令
delay_ms(5);
EN_CLR;//写入结束,P2.2 = 0;关闭写入
//显示屏数据写入函数
void LCD_write_data(unsigned char data)
RS_SET;//P2.0 = 1;
RW_CLR;//P2.1 = 0;
EN_SET;//P2.2 = 1;
DataPort = data; //??????
delay_ms(5);
EN_CLR;//P2.2 = 0;
// 显示屏清空显示
void LCD_clear(void)
LCD_write_com(0x01); //清屏幕显示
delay_ms(5);
// 显示屏字符串写入函数
if (y == 0)
LCD_write_com(0x80 + x); //第一行显示
else
LCD_write_com(0xC0 + x); //第二行显示
while (*s)
LCD_write_data( *s);
s++;
// 显示屏单字符写入函数
if (y == 0)
else
LCD_write_data( data);
// 显示屏初始化函数
void LCD_init(void)
LCD_write_com(0x38); //显示模式设置
delay_ms(5);
LCD_write_com(0x08); //显示关闭
delay_ms(5);
LCD_write_com(0x01); //显示清屏
delay_ms(5);
LCD_write_com(0x06); //显示光标移动设置
delay_ms(5);
LCD_write_com(0x0C); //显示开机光标设置
delay_ms(5);
