大牛 莫拉的论文专辑 (几乎全是IEEE的JSSC)
 楼主| analog100 发表于 2010-5-18 21:09 | 显示全部楼层 |阅读模式
IEEE, TI, TE, AN, ic
只要是莫拉的论文(几乎全是IEEE的JSSC和TRANSACTIONS ON CIRCUITS AND SYSTEMS),质量绝对是不用说,可以学到很多东西。找了好久才聚齐,希望能和大家共同学习。
1. A Low-Voltage, Low Quiescent Current,Low Drop-out Regulator
2. Active Capacitor Multiplier in Miller-Compensated Circuits
3. A Compact 1-30uH, 1-350uF, 5-50mO ESR Compliant, 1.5% Accurate 0.6um CMOS Differential Sigma-Delta Boost DC-DC Converter
4. A Compact Electrical Model for Microscale Fuel Cells Capable of Predicting Runtime and I-V Polarization Performance
5. A Fast, Sigma-Delta Boost DC-DC Converter Tolerant to Wide LC Filter Variations
6. A High Efficiency Linear RF Power Amplifier With a Power-Tracking Dynamically Adaptive Buck-Boost Supply
7. A High Efficiency WCDMA RF Power Amplifier (PA) with Adaptive, Dual-Mode Buck-Boost Supply and Bias-Current Control
8. A High Efficiency, Soft Switching DC-DC Converter with Adaptive Current-Ripple Control for Portable Applications
9. A Low Voltage, Non-Inverting, Dynamic, Synchronous Buck-Boost Converter for Portable Applications
10. A Low Voltage, Rail-to-Rail, Class AB CMOS Amplifier With High Drive and Low Output Impedance Characteristics
11. A Low-Impedance, Sub-Bandgap 0.6um CMOS Reference with 0.84% Trimless 3-sigma Accuracy and -30dB Worst-Case PSRR up to 50MHz
12. A 0.7 um BiCMOS Electrostatic Energy-Harvesting System IC
13. A Programmable 210uV Offset Rail-to-Rail Gm-C filter
14. A strategy for fast and reliable top-level simulation and verification of mixed-signal DC-DC converter ICs
15. Accurate Electrical Battery Model Capable of Predicting Runtime and I-V Performance
16. Accurate, Compact, and Power Efficient Li-Ion Battery Charger Circuit
17. Achieving High Efficiency under Micro-Watt Loads with Switching Buck DC-DC Converters
18. Achieving Less Than 2% 3-s Mismatch with Minimum Channel-Length CMOS Devices
19. A 1.1 V Current-Mode and Piecewise-Linear Curvature Corrected Bandgap Reference
20. An Accurate, Continuous, and Lossless Self-Learning CMOS Current-Sensing Scheme for Inductor-Based DC-DC Converters
21. An Accurate, Low Voltage, CMOS Switching Power Supply with Adaptive On-Time Pulse-Frequency Modulation
22. Cancellation of load regulation in low drop-out regulators
23. Designing 1-V Op Amps Using Standard Digital CMOS Technoloty
24. Electrostatic energy-harvesting and battery-charging CMOS system prototype
25. Energy-harvesting system-in-package (SiP) microsystem
26. Limits of Predictive Current-Ripple Suppression in Switching Power Supply ICs
27. Low Output Impedance 0.6um CMOS Sub-Bandgap Reference
28. Low-Power CMOS Ramp Generator Circuit for DC-DC Converters
29. Optimized Frequency Shaping Circuit Topologies for LDOs
30. Single-Inductor Multiple-Output (SIMO) Switching DC-DC Converters
31. Voltage Shift in Plastic-Packaged Bandgap References
附件
莫拉专辑.part1.rar (5 MB)
莫拉专辑.part2.rar (5 MB)
莫拉专辑.part3.rar (3.75 MB)
bbyeah 发表于 2010-5-19 05:38 | 显示全部楼层
看来还真得注册那个论坛啊...
