Added new 'reset after programming' option to Flash dialog
Fix to Managed linker script for data section
Various fixes/improvements to peripheral descriptions
Debugger fixes for problems related to stepping and viewing variables
Fixed problem with setjmp in C library
Fixed a rare activation issue. Note: Customers who experienced this problem with previous releases may need acquire a new serial number and activation key.
Note: If you are upgrading from a previous installation, we recommend that you install into a new directory. You will be able to use any existing workspaces, and your existing activation code will be used.
