[AVR单片机] 二进制转十进制(BCD)码汇编算法(适用汇编初学者)
highgear 发表于 2010-8-3 21:20 | 显示全部楼层
转换原理以及 C 演示代码, 很容易转到汇编。
The Basic Idea
To do the conversion faster, what we'll do is look at our binary number as a base 16 number and then do the conversion in terms of the base 16 digits. Consider a 16 bit number n. This can be broken into 4 fields of 4 bits each, the base 16 digits; call them n3, n2, n1 and n0.
                    n
    |_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _|
    |_|_|_|_|_|_|_|_|_|_|_|_|_|_|_|_|
    |   n   |   n   |   n   |   n   |
         3       2       1       0
The value of the number can be expressed in terms of these 4 fields as follows:
n = 4096 n3 + 256 n2 + 16 n1 + 1 n0
In the same way, if the value of n, expressed in decimal, is d4d3d2d1d0, where each of d4, d3, d2, d1 and d0 are decimal digits, the value of n can be expressed as:
n = 10000 d4 + 1000 d3 + 100 d2 + 10 d1 + 1 d0
Our problem then, is to compute the di from the ni without dealing directly with the larger number n.
To do this, we first note that the factors used in combining the values of ni can themselves be expressed as sums of multiples of powers of 10. Therefore, we can rewrite the original expression as:
n =
  n3( 4×1000 + 0×100 + 9×10 + 6×1 ) +
  n2( 2×100 + 5×10 + 6×1 ) +
  n1( 1×10 + 6×1 ) +
  n0( 1×1 )
If distribute the ni over the expressions for each factor, then factor out the multiples of 100, we get the following:
n =
  1000 (4n3) +
  100 (0n3 + 2n2) +
  10 (9n3 + 5n2 + 1n1) +
  1 (6n3 + 6n2 + 6n1 + 1n0)
We can use this to arrive at first approximations ai for d3 through d0:
a3 = 4 n3
a2 = 0 n3 + 2 n2
a1 = 9 n3 + 5 n2 + 1 n1
a0 = 6 n3 + 6 n2 + 6 n1 + 1 n0
The values of ai are not proper decimal digits because they are not properly bounded in the range 0 < ai < 9. Instead, given that each of ni is bounded in the range 0 < ni < 15, the ai are bounded as follows:
0 < a3 < 60
0 < a2 < 30
0 < a1 < 225
0 < a0 < 285
This is actually quite promising because a3 through a1 are less than 256 and may therefore be computed using an 8 bit ALU, and even a0 may be computed in 8 bits if we can use the carry-out bit of the ALU to hold the high bit. Furthermore, if our interest is 2's complement arithmetic where the high bit is the sign bit, the first step in the output process is to print a minus sign and then negate, so the constraint on n3 becomes 0 < n3 < 8 and we can conclude naively that
0 < a0 < 243
Note that we said n3 < 8 and not n3 < 8; this is because of the one negative number in the 2's complement system that cannot be properly negated, -32768. If we exclude this number from the range of legal values, the upper bound is reduced to 237; in fact, this is the overall upper bound, because in the one case where n3 is 8, all of the other ni are zero, so we can assert globally that
0 < a0 < 237
Even with our naive bound, however, it is easy to see that we can safely use 8 bit arithmetic to accumulate all of the ai.
Given that we have computed the ai, we can push them into the correct ranges by a series of 8-bit divisions and one 9-bit division, as follows:
c1 = a0 / 10
d0 = a0 mod 10
c2 = (a1 + c1) / 10
d1 = (a1 + c1) mod 10
c3 = (a2 + c2) / 10
d2 = (a2 + c2) mod 10
c4 = (a3 + c3) / 10
d3 = (a3 + c3) mod 10
d4 = c4
In the above, the ci terms represent carries propagated from one digit position to the next. The upper bounds on each of the ci can be computed from the bounds given above for the ai:
c1 < 28 [ = 285 / 10 ]
c2 < 25 [ = (28 + 225) / 10 = 253 / 10 ]
c3 < 5 [ = (25 + 30) / 10 = 55 / 10 ]
c4 < 6 [ = (5 + 60) / 10 = 65 / 10 ]
In computing the bound on c2, we came within 2 of to 255, the maximum that can be represented in 8 bits, so an 8 bit ALU is just barely sufficient for this computation. Again, if we negate any negative numbers prior to output, so that the maximum value of n3 is 8, the bound on c1 becomes 23 instead of 28.
有 8-bit 硬件除法
void putdec( uint16_t n )
        uint8_t d4, d3, d2, d1, q;
        uint16_t d0;
        d0 = n       & 0xF;
        d1 = (n>>4)  & 0xF;
        d2 = (n>>8)  & 0xF;
        d3 = (n>>12) & 0xF;
        d0 = 6*(d3 + d2 + d1) + d0;
        q = d0 / 10;
        d0 = d0 % 10;
        d1 = q + 9*d3 + 5*d2 + d1;
        q = d1 / 10;
        d1 = d1 % 10;
        d2 = q + 2*d2;
        q = d2 / 10;
        d2 = d2 % 10;
        d3 = q + 4*d3;
        q = d3 / 10;
        d3 = d3 % 10;
        d4 = q;
        putchar( d4 + '0' );
        putchar( d3 + '0' );
        putchar( d2 + '0' );
        putchar( d1 + '0' );
        putchar( d0 + '0' );
有 8-bit 硬件乘法:
    void putdec( int16_t n )
        uint8_t d4, d3, d2, d1, d0, q;
        if (n < 0) {
            putchar( '-' );
            n = -n;
        d1 = (n>>4)  & 0xF;
        d2 = (n>>8)  & 0xF;
        d3 = (n>>12) & 0xF;
        d0 = 6*(d3 + d2 + d1) + (n & 0xF);
        q = (d0 * 0xCD) >> 11;
        d0 = d0 - 10*q;
        q = (d1 * 0xCD) >> 11;
        d1 = d1 - 10*q;
        d2 = q + 2*d2;
        q = (d2 * 0x1A) >> 8;
        d2 = d2 - 10*q;
        d3 = q + 4*d3;
        d4 = (d3 * 0x1A) >> 8;
        d3 = d3 - 10*d4;
评分
参与人数 1威望 +1 收起 理由
xuyiyi + 1
查看全部评分
xuyiyi 发表于 2010-8-4 12:03 | 显示全部楼层
highgear大师思路清晰,尽管俺没学过e文,但大师的**写的非常整齐规范,连看带猜都能理解其精华和含义,是目前二姨家论说数制转换原理最经典的**,非常适合菜鸟学习。
赞一个,顶一把!
粉丝 发表于 2010-8-4 12:30 | 显示全部楼层
不懂装懂的,服了22楼!
 楼主| 宇宙飞船 发表于 2010-8-4 12:51 | 显示全部楼层
大部分MCU没有除法,一些MCU没有乘法指令,21楼的算法不能在MCU中用汇编实现。
因此,粉丝说得有道理。
xuyiyi 发表于 2010-8-4 14:10 | 显示全部楼层
飞船到底是大师级的,实在太谦虚了,谦虚的俺无语 。 :o
highgear老师思路清晰,俺不懂汇编的,按其思路,随手就能举一反三,不用乘法或除法,写出二进制转十进制(BCD)码汇编代码出来。
要不要试一试?俺写出来,你正斑竹别争啦,坐二斑竹算啦!
潜艇8421 发表于 2010-8-4 15:07 | 显示全部楼层
楼上,谁都知你早投到老顽童账下。
论坛游客 发表于 2010-8-4 15:24 | 显示全部楼层
老许不去从政  真是可惜了
粉丝 发表于 2010-8-14 16:15 | 显示全部楼层
25 楼这些天贴了不少的汇编源码上来,但是却没有真正点化人。
123jj 发表于 2010-8-14 17:09 | 显示全部楼层
贴汇编源码,是严格按照执行 飞船斑竹 的要求,
打造最强单片机“汇编”与“C”的混编论坛,让世人重新定位8位单片机---> AVR
您 粉丝 本事大,从不写这些低挡的代码,也只有俺跟着师兄学着写了。
关于“一句话”点化“一群人”的本事俺没有,只有请 飞船大仙 出山了。
xuyiyi 发表于 2010-8-14 17:57 | 显示全部楼层
**中俺也会BCD码,可惜就差在AVR汇编上实现了,很是可惜~~~
http://www.google.com.hk/search?hl=zh-CN&source=hp&q=BCD+HotPower&aq=f&aqi=&aql=&oq=&gs_rfai=
hotpower 发表于 2010-8-1 02:38
大叔的 PIC之BCD调整宏定义  不错,俺拜读收下了,谢谢!
xuyiyi 发表于 2010-8-14 17:58 | 显示全部楼层
偶只听说过HOT  C++很N
123jj 发表于 2010-8-3 15:41
现在看来大叔的汇编也很NB,  哈哈!
hotpower 发表于 2010-8-14 18:37 | 显示全部楼层
123jj 发表于 2010-8-15 09:04 | 显示全部楼层
学习了,大叔的汇编玩的真棒!
hotpower 发表于 2010-8-16 11:45 | 显示全部楼层
可惜俺在AVR上清一色的C++。
无法参战…
现做AVR汇编菜鸟有些不合时局。
郁闷之中…
123jj 发表于 2010-8-16 12:12 | 显示全部楼层
大叔的汇编玩的够NB
某些人号称是AVR汇编超级大神,至今只会转贴一点外国人的源代码,偶还没看到其写过一句AVR汇编,只看见整天喊口号忽悠。
xuyiyi 发表于 2010-8-16 14:16 | 显示全部楼层
哈哈! ;P
hotpower 发表于 2010-8-16 22:42 | 显示全部楼层
大叔的汇编玩的够NB某些人号称是AVR汇编超级大神,至今只会转贴一点外国人的源代码,偶还没看到其写过一句AVR汇编,只看见整天喊口号忽悠。123jj 发表于 2010-8-16 12:12
没发现吧,跳转标号都不知在何处,也许俺的手机屏幕太小了。
hotpower 发表于 2010-8-16 22:44 | 显示全部楼层
123jj 发表于 2010-8-17 08:55 | 显示全部楼层
呵呵!
跳转标号怎么会没有呢?
一定是大叔的手机屏幕太小了!
