[BB方案]——编码实现
 楼主| Peonys 发表于 2017-9-29 10:43 | 显示全部楼层 |阅读模式
编码实现
首先是PHP,作为接收命令的起始点,我使用URL参数来接收要通过红外线发送的数据串:
  • <html>
  • <head>
  • <title>Test Pipe Page</title>
  • </head>
  • <body>
  • <?php
  •         $str = $_REQUEST['str'];
  •   $fp = @fopen("////tmp//irfifo", 'w');
  •         echo $fp;
  •         echo nl2br("\n");
  •         $num  = 0x5a;
  •   $data = pack("H2", "5a");
  •   echo @fwrite($fp, $data);
  •         echo nl2br("\n");
  •   $data = pack("C1", strlen($str)/2);
  •   echo @fwrite($fp, $data);//д
  •         echo nl2br("\n");
  •   $data = pack("H*", $str);
  •   echo @fwrite($fp,$data);//д
  •         echo nl2br("\n");
  •   fclose($fp);
  •         echo nl2br("\n");
  •         print("Hello World!");
  •         echo nl2br("\n");
  •         print("sjtitr");
  •         echo nl2br("\n");
  • <br><br>
  • <a href="test_pipe.php?str=00ff48b7"><-</a><br><br>
  • <a href="test_pipe.php?str=00ff4ab5">-></a><br><br>
  • </body>
  • </html>
[color=rgb(51, 102, 153) !important]复制代码
使用的时候,就像这样咯:test_pipe.php?str=00ff48b7
这样一来,C程序也很简单,目标是处理管道文件,然后启动pru:
  • #include <sys/types.h>
  • #include <sys/stat.h>
  • #include <errno.h>
  • #include <fcntl.h>
  • #include <stdio.h>
  • #include <stdlib.h>
  • #include <string.h>
  • #include <prussdrv.h>
  • #include <pruss_intc_mapping.h>
  • #define PRU_NUM 0
  • #define FIFO "/tmp/irfifo"
  • void prurun(char *buf)
  •     unsigned int ret;
  •     tpruss_intc_initdata pruss_intc_initdata = PRUSS_INTC_INITDATA;
  •     prussdrv_init ();//Initialize the PRU
  •     if (prussdrv_open(PRU_EVTOUT_0))//Open PRU Interrupt
  •         printf("prussdrv_open open failed");
  •         return;
  •     prussdrv_pruintc_init(&pruss_intc_initdata);
  •         prussdrv_pru_write_memory(PRUSS0_PRU0_DATARAM, 0, buf, buf[0]+1);
  •     prussdrv_exec_program (PRU_NUM, "./prucode.bin");//Execute example on PRU
  •     prussdrv_pru_wait_event (PRU_EVTOUT_0);//Waiting for this instruction: MOV r31.b0, PRU0_ARM_INTERRUPT+16
  •     prussdrv_pru_clear_event (PRU0_ARM_INTERRUPT,0);
  •     prussdrv_pru_disable (PRU_NUM);//Disable PRU and close memory mapping
  •     prussdrv_exit ();
  • int main(int argc, char** argv)
  •         char buf[64];
  •         int fd;
  •         int nread;
  •         if((mkfifo(FIFO, O_CREAT|O_EXCL)<0) && (errno!=EEXIST))
  •                 printf("cannot create fifo\n");
  •         fd = open(FIFO, O_RDONLY);
  •         if(fd==-1)
  •                 printf("cannot open fifo\n");
  •                 exit(1);
  •         while(1)
  •                 int i = 0;
  •                 memset(buf, 0, sizeof(buf));
  •                 read(fd, buf, 1);
  •                 if(buf[0]!=0x5A)
  •                 //        printf("%X,", buf[0]);
  •                         continue;
  •                 read(fd, buf, 1);
  •                 if(buf[0] == 0)
  •                         break;
  •                 read(fd, &buf[1], buf[0]);
  •                 printf("%d: ", buf[0]);
  •                 while(i < buf[0])
  •                         i++;
  •                         printf("%X,",buf);
  •                 printf("\n");
  •                 prurun(buf);
  •         unlink(FIFO);
  •         exit(0);
最后是PRU程序,使用汇编语言完成,根据给下来的数据,执行红外编码的时序:
  • //prucode.p
  • .origin 0
  • .entrypoint START
  • //Refer to this mapping in the file - prussdrvincludepruss_intc_mapping.h
  • #define PRU0_ARM_INTERRUPT      19
  • #define CONST_PRUCFG            C4
  • //Refer to AM335X Technical Reference Manual & BBB SRM
  • #define GPIO1 0x4804c000
  • #define GPIO_CLEARDATAOUT 0x190
  • #define GPIO_SETDATAOUT 0x194
  • START:
  •     // Enable OCP master port
  •     LBCO      r0, CONST_PRUCFG, 4, 4
  •     CLR       r0, r0, 4         // Clear SYSCFG[STANDBY_INIT] to enable OCP master port
  •     SBCO      r0, CONST_PRUCFG, 4, 4
  •     MOV r5, 0
  •     LBBO r4, r5, 0, 1
  •     AND r4, r4, 255
  • LEADER:
  •     MOV r1, 340
  •     CALL WAV_S
  •     MOV r0, 450000
  • LEADER_T:
  •     SUB r0, r0, 1
  •     QBNE LEADER_T, r0, 0
  • NEXT_BYTE:
  •     ADD r5, r5, 1
  •     LBBO r6, r5, 0, 1
  •     MOV r7, 8
  • NEXT_BIT:
  •     MOV r1, 21
  •     CALL WAV_S
  •     AND r0, r6, 1<<7
  •     QBNE BIT_1, r0, 0
  • BIT_0:
  •     MOV r0, 56500
  •     JMP BIT_T
  • BIT_1:
  •     MOV r0, 169000
  • BIT_T:
  •     SUB r0, r0, 1
  •     QBNE BIT_T, r0, 0
  •     LSL r6, r6, 1
  •     SUB r7, r7, 1
  •     QBNE NEXT_BIT, r7, 0
  • BYTE_OK:
  •     SUB r4, r4, 1
  •     QBNE NEXT_BYTE, r4, 0
  • STOP_S:
  •     MOV r1, 21
  •     CALL WAV_S
  •     MOV r0, 5000000
  • STOP_T:
  •     SUB r0, r0, 1
  •     QBNE STOP_T, r0, 0
  •     // Send notification to Host for program completion
  •     MOV       r31.b0, PRU0_ARM_INTERRUPT+16
  •     // Halt the processor
  •     HALT
  • WAV_S:
  •     MOV r2, 1<<12
  •     MOV r3, GPIO1 | GPIO_SETDATAOUT
  •     SBBO r2, r3, 0, 4
  •     MOV r0, 850
  • WAV_1:
  •     SUB r0, r0, 1
  •     QBNE WAV_1, r0, 0
  •     MOV r2, 1<<12
  •     MOV r3, GPIO1 | GPIO_CLEARDATAOUT
  •     SBBO r2, r3, 0, 4
  •     MOV r0, 1800
  • WAV_0:
  •     SUB r0, r0, 1
  •     QBNE WAV_0, r0, 0
  •     SUB r1, r1, 1
  •     QBNE WAV_S, r1, 0
  •     RET
