- #include "common.h"
- #include "ics.h"
- #include "rtc.h"
- #include "uart.h"
- #include "gpio.h"
- #include "sysinit.h"
- #include "start.h"
- #include "oledfont.h"
- #define OLED_MODE 0
- #define SIZE 8
- #define XLevelL 0x00
- #define XLevelH 0x10
- #define Max_Column 128
- #define Max_Row 64
- #define Brightness 0xFF
- #define X_WIDTH 128
- #define Y_WIDTH 64
- #define OLED_SCLK_Clr() GPIO_PinClear(GPIO_PTE1);
- #define OLED_SCLK_Set() GPIO_PinSet(GPIO_PTE1);
- #define OLED_SDIN_Clr() GPIO_PinClear(GPIO_PTE0);
- #define OLED_SDIN_Set() GPIO_PinSet(GPIO_PTE0);
- #define OLED_CMD 0
- #define OLED_DATA 1
- uint8_t hh=8,mm=30,ss=0;
- void IIC_Start()
- OLED_SCLK_Set();
- OLED_SDIN_Set();
- OLED_SDIN_Clr();
- OLED_SCLK_Clr();
- void IIC_Stop()
- OLED_SCLK_Set();
- OLED_SDIN_Clr();
- OLED_SDIN_Set();
- void IIC_Wait_Ack()
- OLED_SCLK_Set() ;
- OLED_SCLK_Clr();
- void Write_IIC_Byte(unsigned char IIC_Byte)
- unsigned char i;
- unsigned char m,da;
- da=IIC_Byte;
- OLED_SCLK_Clr();
- for(i=0;i<8;i++)
- m=da;
- m=m&0x80;
- if(m==0x80)
- {OLED_SDIN_Set();}
- else OLED_SDIN_Clr();
- da=da<<1;
- OLED_SCLK_Set();
- OLED_SCLK_Clr();
- void Write_IIC_Command(unsigned char IIC_Command)
- IIC_Start();
- Write_IIC_Byte(0x78);
- IIC_Wait_Ack();
- Write_IIC_Byte(0x00);
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Command);
- IIC_Wait_Ack();
- IIC_Stop();
- void Write_IIC_Data(unsigned char IIC_Data)
- IIC_Start();
- IIC_Wait_Ack();
- Write_IIC_Byte(0x40);
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Data);
- IIC_Wait_Ack();
- IIC_Stop();
- void OLED_WR_Byte(unsigned dat,unsigned cmd)
- if(cmd)
- Write_IIC_Data(dat);
- else
- Write_IIC_Command(dat);
- void Delay_50ms(unsigned int Del_50ms)
- unsigned int m;
- for(;Del_50ms>0;Del_50ms--)
- for(m=6245;m>0;m--);
- void Delay_1ms(unsigned int Del_1ms)
- unsigned char j;
- while(Del_1ms--)
- for(j=0;j<123;j++);
- void OLED_Set_Pos(unsigned char x, unsigned char y)
- OLED_WR_Byte(0xb0+y,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f),OLED_CMD);
- void OLED_Display_On(void)
- OLED_WR_Byte(0X8D,OLED_CMD);
- OLED_WR_Byte(0X14,OLED_CMD);
- OLED_WR_Byte(0XAF,OLED_CMD);
- void OLED_Clear(void)
- unsigned char i,n;
- for(i=0;i<8;i++)
- OLED_WR_Byte (0xb0+i,OLED_CMD);
- OLED_WR_Byte (0x00,OLED_CMD);
- OLED_WR_Byte (0x10,OLED_CMD);
- for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
- void OLED_Clearp(void)
- for(i=2;i<6;i++)
- void OLED_ShowChar(unsigned char x,unsigned char y,unsigned char chr,unsigned char Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';
- if(x>Max_Column-1){x=0;y=y+2;}
- if(Char_Size ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
- uint32_t oled_pow(unsigned char m,unsigned char n)
- uint32_t result=1;
- while(n--)result*=m;
- return result;
- void OLED_ShowNum(unsigned char x,unsigned char y,uint32_t num,unsigned char len,unsigned char size2)
- unsigned char t,temp;
- unsigned char enshow=0;
- for(t=0;t<len;t++)
- temp=(num/oled_pow(10,len-t-1))%10;
- if(enshow==0&&t<(len-1))
- if(temp==0)
- OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
- continue;
- }else enshow=1;
- OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
- void OLED_ShowString(unsigned char x,unsigned char y,unsigned char *chr,unsigned char Char_Size)
- unsigned char j=0;
- while (chr[j]!='\0')
- { OLED_ShowChar(x,y,chr[j],Char_Size);
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
- void OLED_ShowCHinese(unsigned char x,unsigned char y,unsigned char no)
- unsigned char t,adder=0;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
- adder+=1;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
- adder+=1;
- void OLED_Init(void)
- //SSD1306
- OLED_SCLK_Set();
- OLED_SDIN_Set();
- Delay_1ms(800);
- OLED_WR_Byte(0xAE,OLED_CMD);
- OLED_WR_Byte(0x00,OLED_CMD);
- OLED_WR_Byte(0x10,OLED_CMD);
- OLED_WR_Byte(0x40,OLED_CMD);
- OLED_WR_Byte(0xB0,OLED_CMD);
- OLED_WR_Byte(0x81,OLED_CMD);
- OLED_WR_Byte(0xFF,OLED_CMD);
- OLED_WR_Byte(0xA1,OLED_CMD);
- OLED_WR_Byte(0xA6,OLED_CMD);
- OLED_WR_Byte(0xA8,OLED_CMD);
- OLED_WR_Byte(0x3F,OLED_CMD);
- OLED_WR_Byte(0xC8,OLED_CMD);
- OLED_WR_Byte(0xD3,OLED_CMD);
- OLED_WR_Byte(0xD5,OLED_CMD);
- OLED_WR_Byte(0x80,OLED_CMD);
- OLED_WR_Byte(0xD8,OLED_CMD);
- OLED_WR_Byte(0x05,OLED_CMD);
- OLED_WR_Byte(0xD9,OLED_CMD);
- OLED_WR_Byte(0xF1,OLED_CMD);
- OLED_WR_Byte(0xDA,OLED_CMD);
- OLED_WR_Byte(0x12,OLED_CMD);
- OLED_WR_Byte(0xDB,OLED_CMD);
- OLED_WR_Byte(0x30,OLED_CMD);
- OLED_WR_Byte(0x8D,OLED_CMD);
- OLED_WR_Byte(0x14,OLED_CMD);
- OLED_WR_Byte(0xAF,OLED_CMD);
- void cd11()
- OLED_Clear();
- OLED_ShowString(24,0,"RTC CLOCK",16);
- OLED_ShowString(24,4,"jinglixixi",16);
- void myDelay (uint32_t ulTime)
- uint32_t i;
- i = 0;
- while (ulTime--)
- for (i = 0; i < 5000; i++);
- int main (void);
- void RTC_Task(void);
- int main (void)
- sysinit();
- cpu_identify();
- RTC_ConfigType sRTCConfig;
- RTC_ConfigType *pRTCConfig = &sRTCConfig;
- pRTCConfig->u16ModuloValue = 9;
- pRTCConfig->bInterruptEn = RTC_INTERRUPT_ENABLE;
- pRTCConfig->bClockSource = RTC_CLKSRC_1KHZ;
- pRTCConfig->bClockPresaler = RTC_CLK_PRESCALER_100;
- RTC_SetCallback(RTC_Task);
- RTC_Init(pRTCConfig);
- GPIO_Init(GPIOB, GPIO_PTE7_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTE0_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTE1_MASK, GPIO_PinOutput);
- OLED_Init();
- OLED_Clear();
- cd11();
- OLED_ShowString(24,6,"2018.6.30",16);
- while (1)
- OLED_ShowNum(24,2,hh,2,16);
- OLED_ShowChar(40,2,':',16);
- OLED_ShowNum(48,2,mm,2,16);
- OLED_ShowChar(64,2,':',16);
- OLED_ShowNum(72,2,ss,2,16);
- if(ss==60)
- ss=0;
- mm=mm+1;
- if(mm==60)
- mm=0;
- hh=hh+1;
- if(hh==24)
- hh=0;
- GPIO_Toggle(GPIOB, GPIO_PTE7_MASK);
- ss++;
