- /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technoledge Corp.
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Apr/21/2016
- // File Function: N76E003 APROM program DATAFLASH as EEPROM way
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- #define ADDR_BASE 0x4700
- #define FLASH_L_LOW ADDR_BASE+1
- #define FLASH_L_HIGH ADDR_BASE+2
- #define FLASH_H_LOW ADDR_BASE+3
- #define FLASH_H_HIGH ADDR_BASE+4
- write_DATAFLASH_BYTE :
- user can copy all this subroutine into project, then call this function in main.
- void write_DATAFLASH_BYTE(UINT16 u16_addr,UINT8 u8_data)
- UINT8 looptmp=0,u8_addrl_r;
- unsigned char code *cd_longaddr;
- unsigned char xdata *xd_tmp;
- //Check page start address
- u8_addrl_r = u16_addr;
- if (u8_addrl_r<0x80)
- u8_addrl_r = 0;
- else
- u8_addrl_r = 0x80;
- //Save APROM data to XRAM
- xd_tmp = 0x280;
- cd_longaddr = (u16_addr&0xff00)+u8_addrl_r;
- while (xd_tmp !=0x300)
- *xd_tmp = *cd_longaddr;
- looptmp++;
- xd_tmp++;
- cd_longaddr++;
- // Modify customer data in XRAM
- xd_tmp = u8_addrl_r+0x280;
- else
- xd_tmp = u8_addrl_r+0x200;
- *xd_tmp = u8_data;
- //Erase APROM DATAFLASH page
- IAPAL = u16_addr;
- IAPAH = u16_addr>>8;
- IAPFD = 0xFF;
- set_IAPEN;
- set_APUEN;
- IAPCN = 0x22;
- set_IAPGO;
- //Save changed RAM data to APROM DATAFLASH
- u8_addrl_r =0;
- else
- xd_tmp = 0x280;
- IAPAL = u8_addrl_r;
- set_IAPEN;
- set_APUEN;
- IAPCN = 0x21;
- while (xd_tmp !=0x2FF)
- IAPFD = *xd_tmp;
- set_IAPGO;
- IAPAL++;
- xd_tmp++;
- clr_APUEN;
- clr_IAPEN;
- UINT8 read_APROM_BYTE(UINT16 code *u16_addr)
- UINT8 rdata;
- rdata = *u16_addr>>8;
- return rdata;
- void main (void)
- UINT8 datatemp;
- UINT16 system16highsite;
- /* Dataflash use APROM area, please ALWAYS care the address of you code */
- /* APROM 0x3800~0x38FF demo as dataflash */
- /* Please use Memory window key in C:0x3800 to check earse result */
- InitialUART0_Timer1(115200);
- //call write byte
- write_DATAFLASH_BYTE (0x3802,0x34);
- write_DATAFLASH_BYTE (FLASH_L_LOW,0x55);
- write_DATAFLASH_BYTE (FLASH_L_HIGH,0x56);
- write_DATAFLASH_BYTE (FLASH_H_LOW,0xaa);
- write_DATAFLASH_BYTE (FLASH_H_HIGH,0x66);
- //call read byte
- datatemp = read_APROM_BYTE(0x3802);
- system16highsite = ((read_APROM_BYTE(FLASH_H_HIGH)<<8)+read_APROM_BYTE(FLASH_H_LOW));
- while(1)
- // printf ("\n data temp = 0x%bx", datatemp);
