[MSP430] 蜂鸣器演唱音乐
 楼主| mnmjmkml 发表于 2019-2-27 18:17 | 显示全部楼层 |阅读模式
修改自51单片机,launchpad的P10连接蜂鸣器,蜂鸣器演奏《八月桂花》
  1. #include "msp430g2553.h"
  2. unsigned char n=0;  //n为节拍常数变量
  3. unsigned char  music_tab[] ={
  4. 0x18, 0x30, 0x1C , 0x10, //格式为: 频率常数, 节拍常数, 频率常数, 节拍常数,
  5. 0x20, 0x40, 0x1C , 0x10,
  6. 0x18, 0x10, 0x20 , 0x10,
  7. 0x1C, 0x10, 0x18 , 0x40,
  8. 0x1C, 0x20, 0x20 , 0x20,
  9. 0x1C, 0x20, 0x18 , 0x20,
  10. 0x20, 0x80, 0xFF , 0x20,
  11. 0x30, 0x1C, 0x10 , 0x18,
  12. 0x20, 0x15, 0x20 , 0x1C,
  13. 0x20, 0x20, 0x20 , 0x26,
  14. 0x40, 0x20, 0x20 , 0x2B,
  15. 0x20, 0x26, 0x20 , 0x20,
  16. 0x20, 0x30, 0x80 , 0xFF,
  17. 0x20, 0x20, 0x1C , 0x10,
  18. 0x18, 0x10, 0x20 , 0x20,
  19. 0x26, 0x20, 0x2B , 0x20,
  20. 0x30, 0x20, 0x2B , 0x40,
  21. 0x20, 0x20, 0x1C , 0x10,
  22. 0x18, 0x10, 0x20 , 0x20,
  23. 0x26, 0x20, 0x2B , 0x20,
  24. 0x30, 0x20, 0x2B , 0x40,
  25. 0x20, 0x30, 0x1C , 0x10,
  26. 0x18, 0x20, 0x15 , 0x20,
  27. 0x1C, 0x20, 0x20 , 0x20,
  28. 0x26, 0x40, 0x20 , 0x20,
  29. 0x2B, 0x20, 0x26 , 0x20,
  30. 0x20, 0x20, 0x30 , 0x80,
  31. 0x20, 0x30, 0x1C , 0x10,
  32. 0x20, 0x10, 0x1C , 0x10,
  33. 0x20, 0x20, 0x26 , 0x20,
  34. 0x2B, 0x20, 0x30 , 0x20,
  35. 0x2B, 0x40, 0x20 , 0x15,
  36. 0x1F, 0x05, 0x20 , 0x10,
  37. 0x1C, 0x10, 0x20 , 0x20,
  38. 0x26, 0x20, 0x2B , 0x20,
  39. 0x30, 0x20, 0x2B , 0x40,
  40. 0x20, 0x30, 0x1C , 0x10,
  41. 0x18, 0x20, 0x15 , 0x20,
  42. 0x1C, 0x20, 0x20 , 0x20,
  43. 0x26, 0x40, 0x20 , 0x20,
  44. 0x2B, 0x20, 0x26 , 0x20,
  45. 0x20, 0x20, 0x30 , 0x30,
  46. 0x20, 0x30, 0x1C , 0x10,
  47. 0x18, 0x40, 0x1C , 0x20,
  48. 0x20, 0x20, 0x26 , 0x40,
  49. 0x13, 0x60, 0x18 , 0x20,
  50. 0x15, 0x40, 0x13 , 0x40,
  51. 0x18, 0x80, 0x00
  52. };
  53. void delay (unsigned char m)   //控制频率延时
  54. {
  55.     unsigned i=3*m;
  56.     while(--i);
  57. }
  58. void delaymms(unsigned int a)  //毫秒延时子程序
  59. {
  60. unsigned int t;
  61. while(--a)
  62. for(t=0;t<200;t++);
  63. }
  64. void main(void)
  65. {
  66. unsigned char p,m;   //m为频率常数变量
  67. unsigned char i=0;
  68. WDTCTL = WDTPW + WDTHOLD;     // 停止看门狗
  69. P1DIR = 0Xff;
  70. P2DIR = 0Xff;
  71. CCTL0 |= CCIE;                             // CCR0 interrupt enabled
  72. CCR0 = 10000;                         //10ms
  73. TACTL = TASSEL_2 ;                  // SMCLK, contmode
  74. _EINT();
  75. while(1)
  76. {
  77.    p=music_tab[i];
  78.    if(p==0x00)
  79.    {
  80.      i=0;
  81.      delaymms(1000);
  82.      continue;;
  83.    }     //如果碰到结束符,延时1秒,回到开始再来一遍
  84.    else if(p==0xff)
  85.    {
  86.      i=i+1;
  87.      delaymms(100);
  88.      TACTL &=~MC_1;
  89.      continue;
  90.    }  //若碰到休止符,延时100ms,继续取下一音符
  91.    else
  92.    {
  93.      m=music_tab[i++];
  94.      n=music_tab[i++];
  95.    }  //取频率常数 和 节拍常数
  96.    TACTL |= MC_1+TACLR;                                           //开定时器
  97.    while(n!=0) P1OUT ^= BIT0,delay(m);                         //等待节拍完成
  98.    TACTL &=~MC_1;                                           //关定时器
  99.    }
  100. }
  101. // Timer A0 interrupt service routine
  102. #pragma vector=TIMER0_A0_VECTOR
  103. __interrupt void Timer_A (void)
  104. {
  105. n--;
  106. }
zhangmangui 发表于 2019-2-27 22:40 | 显示全部楼层
最好编辑一下    看着比较乱
 楼主| mnmjmkml 发表于 2019-2-28 18:59 | 显示全部楼层
最好编辑一下    看着比较乱
已经编辑好了,实在抱歉,发的比较着急。
