[资料分享] 求助帖
 楼主| 换专业的娃 发表于 2019-3-13 11:19 | 显示全部楼层 |阅读模式
第九届彩灯控制器,题目要求稍微改了一下,换成不同按键控制,这样可以稍微简单一点,但是发现在进入设置界面时,mode的自加只加到一,time显示不正确,请诸位看看怎么回事?
ps:目前还是小白,感觉不怎么进门
#include "STC15F2K60S2.h"
#include "intrins.h"
#define a0 unsigned char
sbit buzzer=P0^6;
sbit relay=P0^4;
a0 code duan[]={0x3f,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x00}; //0-9
a0 code  wei[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
#define KEY P3
#define NO_KEY  0xff
#define KEY_STATE0  0
#define KEY_STATE1  1
#define KEY_STATE2  2
unsigned char Key_Scan()
        static unsigned char key_state=KEY_STATE0;
        a0 key_value=0,key_temp;
        a0 key1,key2;
        P30=0;P31=0;P32=0;P33=0;P34=1;P35=1;P42=1;P44=1;
        if(P44==0)        key1=0x70;
        if(P42==0)        key1=0xb0;
        if(P35==0)        key1=0xd0;
        if(P34==0)        key1=0xe0;
        if((P34==1)&&(P35==1)&&(P42==1)&&(P44==1))        key1=0xf0;
   P30=1;P31=1;P32=1;P33=1;P34=0;P35=0;P42=0;P44=0;
        if(P30==0)        key2=0x0e;
        if(P31==0)        key2=0x0d;
        if(P32==0)        key2=0x0b;
        if(P33==0)        key2=0x07;
        if((P30==1)&&(P31==1)&&(P32==1)&&(P33==1))        key2=0x0f;
        key_temp=key1|key2;
        switch(key_state)
                case KEY_STATE0:
                if(key_temp!=NO_KEY) key_state=KEY_STATE1;
                break;
                case KEY_STATE1:
                if(key_temp==NO_KEY) key_state=KEY_STATE0;
    else
                        switch(key_temp)
                                case 0x77: key_value=4;break;
                                case 0x7b: key_value=5;break;
                                case 0x7d: key_value=6;break;
                                case 0x7e: key_value=7;break;
                                case 0xb7: key_value=8;break;
                                case 0xbb: key_value=9;break;
                                case 0xbd: key_value=10;break;
                                case 0xbe: key_value=11;break;
                                case 0xd7: key_value=12;break;
                                case 0xdb: key_value=13;break;
                                case 0xdd: key_value=14;break;
                                case 0xde: key_value=15;break;
                                case 0xe7: key_value=16;break;
                                case 0xeb: key_value=17;break;
                                case 0xed: key_value=18;break;
                                case 0xee: key_value=19;break;
                        key_state=KEY_STATE2;
                break;
                case KEY_STATE2:
                break;
        return key_value;
void Timer0Init(void)                //1ms@11.0592MHz
        AUXR &= 0x7F;
        TMOD &= 0xF0;
        TL0 = 0x66;
        TH0 = 0xFC;
        TF0 = 0;
        TR0 = 1;
        ET0=1;
        EA=1;
void Delay500ms()                //@11.0592MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 22;
        j = 3;
        k = 227;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
bit key_flag;
a0 set_display[8];
a0 anjian_index;
a0 mode=0;
a0 time=400;
a0 s7_count=0;
a0 shuzu[8];
a0 modee=0;
void main()
          a0 key_val=NO_KEY;
          P2=0xa0;P0=0x00;P2=0x00;
          P2=0x80;P0=0xff;P2=0x00;
          Timer0Init();
           while(1)
         set_display[0]=0x40;
                     set_display[1]=duan[mode];
                     set_display[2]=0x40;;
                     set_display[3]=0x00;
                     set_display[4]=0x00;;
                     set_display[5]=duan[time/100];
                     set_display[6]=duan[time/10];
                     set_display[7]=duan[time%10];
                           shuzu[0]=0x40;
                           shuzu[1]=duan[modee];
                           shuzu[2]=0x40;
                           shuzu[3]=0x40;
                           shuzu[4]=0x40;
                           shuzu[5]=0x40;
                           shuzu[6]=0x40;
                           shuzu[7]=0x40;
          if(mode==1)
                  unsigned char i;
                  while(1)
             P2=0x80;
                   P0=~(0x01<<i);//?è×óò????ùè?·'??×?oóê?óòò?
                   P2=0X00;
                   i++;
                   if(i==8) i=0;
                   Delay500ms();
          if(mode==2)
                   unsigned char i;
                   while(1)
              P2=0x80;
                    P0=~(0x80>>i);//?èóòò????ùè?·'??×?oóê?×óò?
                    P2=0X00;
                    i++;
                    if(i==8) i=0;
                    Delay500ms();
          if(mode==3)
            P2=0x80; P0=0x7e;P2=0x00;//1 8
                  Delay500ms();
                  P2=0x80; P0=0xbd;P2=0x00;//2 7
                  Delay500ms();
                  P2=0x80; P0=0xdb;P2=0x00;//3 6
                  Delay500ms();
                  P2=0x80; P0=0xe7;P2=0x00;//4 5
                  Delay500ms();
                  Delay500ms();
                        if(mode==4)
                  Delay500ms();
                  Delay500ms();
                  P2=0x80; P0=0xbd;P2=0x00;// 2 7
                  Delay500ms();
                  Delay500ms();
                  P2=0x80; P0=0xe7;P2=0x00;// 4 5
                  Delay500ms();
        if(key_flag)
                                    key_flag=0;
                                          key_val=Key_Scan();
                                          switch(key_val)
                                                        case 4: mode++;
        if(mode==5)
        mode=1;
        break;
                                                        case 5:        mode--;
        if(mode==0)
        mode=4;
        break;
                                                        case 6: anjian_index++;
        if(anjian_index==2)
        anjian_index=0;
        break;
                                                        case 7: s7_count++;
        if(s7_count==2)
        s7_count=0;
        break;
                                                        case 8: time=time+100;
        if(time>1200)
        time=1200;
        break;
                                                        case 9: time=time-100;
        if(time<400)
        time=400;
        break;
                                                        case 10:break;
                                                        case 11:break;
                                                        case 12:break;
                                                        case 13:break;
                                                        case 14:break;
                                                        case 15:break;
                                                        case 16:break;
                                                        case 17:break;
                                                        case 18:break;
                                                        case 19:break;
void timer0() interrupt 1  using 1
    static int key_count=0,smg_count=0,i=0,time_count=0,blink_count=0;
          key_count++;smg_count++;time_count++;blink_count++;
          if(key_count==1)
                   key_count=0;
                         key_flag=1;
          if(smg_count==3)
                  smg_count=0;
                        P2=0xc0;P0=0X00;P2=0X00;
                        if(anjian_index)
                          P2=0xe0;P0=~set_display[i];P2=0x00;
                        else
                          P2=0xe0;P0=~shuzu[i];P2=0x00;
                        P2=0xc0;P0=wei[i];P2=0X00;
                          i++;
                          if(i==8) i=0;
零三翟邢止胃 发表于 2019-3-13 12:53 | 显示全部楼层
伴你顶住啊!!!
