- /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved. */
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Jan/21/2017
- // File Function: N76E003 SPI in Master mode demo code
- #include "N76E003.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- #include "Common.h"
- #include "Delay.h"
- // Application: SPI Function
- // Master send 0x90 and recevie 0x4E
- // Master send 0x01 and recevie 0x55
- // Master send 0x02 and recevie 0x56
- // Master send 0x03 and recevie 0x4F
- // Master send 0x04 and recevie 0x54
- // Master recevie 0x4E and 0x4F form slave after transmitting
- // Output : P1.4 & P2.1 flash when SPI pass
- // UART show result on hyper-terminal
- // P0.7 flash when SPI error
- #if 0
- //* For ADC INIT setting
- //#define SPICLK_DIV2 clr_SPR0;clr_SPR1
- //#define SPICLK_DIV4 set_SPR0;clr_SPR1
- //#define SPICLK_DIV8 clr_SPR0;set_SPR1
- //#define SPICLK_DIV16 set_SPR0;set_SPR1
- //#define Enable_SPI_Interrupt set_ESPI;set_EA
- //#define SS P15
- #endif
- void SPI_Error(void)
- printf ("\nSPI error.\n");
- while(1) // SPI error and P0.7 flash/
- P07 = 1;
- Timer0_Delay1ms(500);
- P07 = 0;
- void SPI_Initial(void)
- P15_Quasi_Mode; // P15 (SS) Quasi mode
- P10_Quasi_Mode; // P10(SPCLK) Quasi mode
- P00_Quasi_Mode; // P00 (MOSI) Quasi mode
- P01_Quasi_Mode; // P22 (MISO) Quasi mode
- set_DISMODF; // SS General purpose I/O ( No Mode Fault )
- clr_SSOE;
- clr_LSBFE; // MSB first
- clr_CPOL; // The SPI clock is low in idle mode
- set_CPHA; // The data is sample on the second edge of SPI clock
- set_MSTR; // SPI in Master mode
- SPICLK_DIV2; // Select SPI clock
- Enable_SPI_Interrupt; // Enable SPI interrupt
- set_SPIEN; // Enable SPI function
- void Start_Sending_SPI(UINT8 *pu8MID,UINT8 *pu8DID)
- SS = 0;
- SPDR = 0x90; // Send 0x90 to Slave
- PCON |= SET_BIT0; // Enter idle mode
- if(SPDR != 0x4E) // Receive slave 1st DATA
- SPI_Error();
- printf ("\nSlave Return %c!\n",SPDR);
- SPDR = 0x01; // Send 0x01 to Slave
- if(SPDR != 0x55) // Receive slave 2nd DATA
- SPI_Error();
- SPDR = 0x02; // Send 0x02 to Slave
- if(SPDR != 0x56) // Receive slave 3rd DATA
- SPI_Error();
- SPDR = 0x03; // Send 0x03 to Slave
- if(SPDR != 0x4F) // Receive slave 4th DATA
- SPI_Error();
- SPDR = 0x04; // Send 0x04 to Slave
- if(SPDR != 0x54) // Receive slave 5th DATA
- SPI_Error();
- SPDR = 0x4F;
- *pu8MID = SPDR; // Receive Slave 1st DATA fron Slave
- SPDR = 0x4E;
- *pu8DID = SPDR; // Receive Slave 2nd DATA from Slave
- SS = 1;
- void main(void)
- UINT8 u8MID,u8DID;
- Set_All_GPIO_Quasi_Mode;
- InitialUART0_Timer1(115200); /* 115200 Baud Rate*/
- SPI_Initial();
- printf ("\nSPI Start Transmit...\n");
- Start_Sending_SPI(&u8MID,&u8DID);
- if((u8MID != 0x4F)&&(u8DID != 0x4E))
- SPI_Error();
- printf ("\nSPI Test OK!\n");
- while(1) // SPI transmission finish
- P12 = 1;
- P12 = 0;
- void SPI_ISR(void) interrupt 9 // Vecotr [url=home.php?mod=space&uid=72445]@[/url] 0x4B
- clr_SPIF;
- Timer3_Delay10us(1);
