因为新版本更改了很多,功能更全了。所以操作上也变了。操作函数也变了。
- -- 18b20 Example
- pin = 2
- ow.setup(pin)
- count = 0
- repeat
- count = count + 1
- addr = ow.reset_search(pin)
- addr = ow.search(pin)
- tmr.wdclr()
- until (addr ~= nil) or (count > 100)
- if addr == nil then
- print("No more addresses.")
- else
- print(addr:byte(1,8))
- crc = ow.crc8(string.sub(addr,1,7))
- if crc == addr:byte(8) then
- if (addr:byte(1) == 0x10) or (addr:byte(1) == 0x28) then
- print("Device is a DS18S20 family device.")
- repeat
- ow.reset(pin)
- ow.select(pin, addr)
- ow.write(pin, 0x44, 1)
- tmr.delay(1000000)
- present = ow.reset(pin)
- ow.write(pin,0xBE,1)
- print("P="..present)
- data = nil
- data = string.char(ow.read(pin))
- for i = 1, 8 do
- data = data .. string.char(ow.read(pin))
- end
- print(data:byte(1,9))
- crc = ow.crc8(string.sub(data,1,8))
- print("CRC="..crc)
- if crc == data:byte(9) then
- t = (data:byte(1) + data:byte(2) * 256) * 625
- t1 = t / 10000
- t2 = t % 10000
- print("Temperature="..t1.."."..t2.."Centigrade")
- end
- tmr.wdclr()
- until false
- else
- print("Device family is not recognized.")
- end
- else
- print("CRC is not valid!")
- end
- end
