TIDA-01575
描述This reference design provides a non-invasive and non-disruptive method to monitor and assess motor health and includes both the analog front end (AFE) as well as the embedded application. The embedded application software configures the internal analog-to-digital converter (ADC) to sample the data as well as perform frequency analysis of the data. Additionally, the SimpleLink™ Software Development Kit (SDK) is used in this embedded application to enable both wired and wireless connectivity (Bluetooth® low energy). With the SimpleLink SDK, the user can easily migrate the design to Wi-Fi® and Sub-1G connectivity. This solution of AFE, embedded processing, and wireless connectivity addresses the costly challenge of motor maintenance and is a foundation to implement predictive maintenance systems. By predicting the life of a motor, an operator can optimize maintenance schedules of often costly and large motors and pumps while improving the operational lifetime of the production lines using these motors.
特性- Single solution provides vibration measurement in three axes with MEMS analog accelerometer
- Most precise integrated ADCs capable of capturing vibration with resolution of 0.01g
- Simple software migration between wired serial, wi-fi, bluetooth 5, Sub 1 GHz with SimpleLink platform and with pre-certified RF modules
- Extended multiyear battery life with lowest power integrated ADC and efficient scalable FFT processing
- Edge processing to reduce system power and lower network bandwidth
- Modular BoosterPack™ plug-in module design for easy integration and development with LaunchPad™ development kit ecosystem for prototyping
ExamplesThe example software for this reference design is provided for two LaunchPad™ development kits through the SimpleLink MSP432P4 SDK. The relevant file paths are: - MSP-EXP432P401R: [SimpleLink MSP432P4 SDK]/examples/rtos/MSP_EXP432P401R/demos/tida_01575_serial/
- MSP-EXP432P4111: [SimpleLink MSP432P4 SDK]/examples/rtos/MSP_EXP432P4111/demos/tida_01575_serial/
