- #ifndef __UCOMLIB_H__
- #define __UCOMLIB_H__
- /////////////////////////// error code ///////////////////////////////
- #define ERR_TARGET_NULL -10
- #define ERR_DATA_EXCESSIVE -11
- #define ERR_ID_EXIST -12
- #define ERR_MSG_TOO_LONG -13
- #define ERR_MSG_BUF_FULL -14
- #define ERR_MSG_NOT_EXIST -15
- /////////////////////////////// TIMER ////////////////////////////////
- #define MAX_TIMEER_COUNT 10
- //////////////////////////// event type //////////////////////////////
- #define EV_TIMEOUT 1
- /////////////////////////// user implementation //////////////////////
- typedef int (*EVENT_HANDLER)(const int event,const int msgId);
- int CRITICAL_INIT();
- void ENTER_CRITICAL();
- void EXIT_CRITICAL();
- int CRITICAL_DEINIT();
- /////////////////////////////////// debug ////////////////////////////
- //#define __DEBUG__
- #ifdef __DEBUG__
- #define DEBUG(format,...) printf("File: "__FILE__", Line: %05d: "format"/n", __LINE__, ##__VA_ARGS__)
- #else
- #endif
- /*example*/
- // char str[]="Hello World";
- // DEBUG("A ha, check me: %s",str);
- #define MAX_ASYNC_MSG_NUM 10
- ///////////////////////////// API ////////////////////////////////////
- int CommuInit(void);
- int CommSetEventHandler(EVENT_HANDLER ev);
- int CommSaveMsg(const int msgId,const char *msgData,unsigned int dataLen);
- int CommGetMsg(const int msgId,char *msgData,unsigned int* pDataLen);
- int OnTimer();
- #endif
使用实例(linux):
- //#include "Communication.h"
- //#include "Timer.h"
- #include <stdio.h>
- //#include "list.h"
- #define __DEBUG__
- #include "ucomlib.h"
- #include <pthread.h>
- #include <string.h>
- pthread_mutex_t g_mutex;
- int flag = 1;
- int handler(const int event,const int msgId)
- int ret,len;
- char ms[100];
- char *msg2 = "123456789123456789";
- switch (event) {
- case EV_TIMEOUT:
- printf("ev_timeout\n");
- if(flag){
- ret = CommGetMsg(11,ms,&len);
- ms[len+1]=0;
- printf("get ret:%d len:%d m:%s\n",ret,len,ms);
- } else {
- printf("save ret:%d\n",CommSaveMsg(11,msg2,strlen(msg2)));
- flag = !flag;
- break;
- default:
- DEBUG("undefine event");
- break;
- pthread_mutex_lock(&g_mutex);
- pthread_mutex_unlock(&g_mutex);
- pthread_mutex_init(&g_mutex, NULL);
- pthread_mutex_destroy(&g_mutex);
- void *thread_timer(void* arg)
- printf("new thread,thread is :%u,pid:%d\n",pthread_self(),getpid());
- while(1) {
- sleep(2);
- OnTimer();
- //pthread_exit(NULL);
- char *msg1 = "12345678901234567";
- char *msg2 = "Time out,-edit!";
- void *thread_run1(void* arg)
- char ms[100];
- int ret,len;
- CommSaveMsg(11,msg2,strlen(msg2));
- while(1) {
- sleep(5);
- printf("len:%d save ret:%d\n",strlen(msg1),CommSaveMsg(10,msg1,strlen(msg1)));
- sleep(5);
- ret = CommGetMsg(10,ms,&len);
- ms[len+1]=0;
- printf("get ret:%d len:%d ms:%s\n",ret,len,ms);
- void *thread_run2(void* arg)
- char ms[100];
- int ret,len;
- while(1) {
- sleep(3);
- printf("get ret:%d len:%d\n",ret,len);
- int main()
- CommuInit();
- CommSetEventHandler(handler);
- pthread_t tid_timer,tid_run1,tid_run2;
- pthread_create(&tid_timer,NULL,thread_timer,NULL);
- pthread_create(&tid_run1,NULL,thread_run1,NULL);
- //pthread_create(&tid_run2,NULL,thread_run2,NULL);
- while(1){
- sleep(10);
- return 0;
在mcu下,可以在定时器里面调用:OnTimer(),来实现超时机制。
超时后的处理在类似:
