- /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved. */
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // File Function: ML51 simple GPIO toggle out demo code
- #include "ML51.h"
- * [url=home.php?mod=space&uid=247401]@brief[/url] PWM output run under low power run mode
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] Initial all PWM output, setting PWM
- void main (void)
- /* Setting Multi function pin setting for GPIO toggle
- * include gipo.c in Common for GPIO mode setting */
- ALL_GPIO_QUASI_MODE;
- PWM0_ClockSource(PWM_FSYS,1); // define PWM0 clock source is FSYS, since this time .
- MFP_P05_PWM0_CH0; // multi function pin define P0.5 as PWM0 channel 0 output
- P05_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(0,Independent,EdgeAligned,0x6FF,10); // setting PWM channel 0 as 10% duty high of 0x6FF PWM period = 0x00B3
- MFP_P24_PWM0_CH1; // multi function pin define P2.4 as PWM0 channel 1 output
- P24_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(1,Independent,EdgeAligned,0x6FF,20); // setting PWM channel 1 as 20% duty high of 0x6FF PWM period = 0x0166
- MFP_P03_PWM0_CH2; // multi function pin define P0.3 as PWM0 channel 2 output
- P03_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(2,Independent,EdgeAligned,0x6FF,30); // setting PWM channel 2 as 30% duty high of 0x6FF PWM period = 0x0219
- MFP_P22_PWM0_CH3; // multi function pin define P2.2 as PWM0 channel 3
- P22_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(3,Independent,EdgeAligned,0x6FF,40); // setting PWM channel 3 as 40% duty high of 0x6FF PWM period = 0x02CC
- MFP_P01_PWM0_CH4; // multi function pin define P0.1 as PWM0 channel 4
- P01_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(4,Independent,EdgeAligned,0x6FF,50); // setting PWM channel 4 as 50% duty high of 0x6FF PWM period = 0x037F
- MFP_P20_PWM0_CH5; // multi function pin define P0.5 as PWM0 channel 0
- P20_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(5,Independent,EdgeAligned,0x6FF,60); // setting PWM channel 5 as 60% duty high of 0x6FF PWM period = 0x0432
- /* Enable Low power run mode */
- FsysSelect(FSYS_LIRC);
- PWM0_RUN();
- set_PCON_LPR;
- while(1);
