- /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved. */
- /* Website: http://www.nuvoton.com */
- /* E-Mail : MicroC-8bit@nuvoton.com */
- /* Date : June/21/2019 */
- /* File Function: MS51 ADC / Bandgap input demo code */
- #include "MS51_32K.h"
- /* PWM interrupt subroutine */
- void PWM0_ISR (void) interrupt 13
- _push_(SFRS);
- clr_PWM0CON0_PWMF; // clear PWM interrupt flag
- _pop_(SFRS);
- * Main function
- void main(void)
- PWM frequency = Fpwm/((PWMPH,PWMPL) + 1) <Fpwm = Fsys/PWM_CLOCK_DIV>
- = (16MHz/8)/(0x3FF + 1)
- = 2.7KHz
- ENABLE_PWM0_CH2_P05_OUTPUT;
- P05_PUSHPULL_MODE;
- PWM0_CH2_INTERRUPT_SELECT;
- PWM0_CLOCK_DIV_8;
- PWM0PH = 0x03; /*Setting PWM period */
- PWM0PL = 0xFF;
- PWM0C2H = 0x0; /*PWM0 high duty = 1/2 PWM period */
- PWM0C2L = 0xFF;
- ENABLE_PWM0_INTERRUPT; /*Enable PWM interrupt */
- ENABLE_GLOBAL_INTERRUPT;
- set_PWM0CON0_LOAD;
- set_PWM0CON0_PWM0RUN;
- while(1);
