MPLAB X IDE 软件字体变小了,如何变大,谢谢
 楼主| ersha4877 发表于 2020-8-10 10:47 | 显示全部楼层 |阅读模式
WIN10的系统不知道怎么回事,安装了就变这样了,有解决方法吗
 楼主| ersha4877 发表于 2020-8-10 10:49 | 显示全部楼层
字体变小了,看起来很难受,费眼睛
hu9jj 发表于 2020-8-10 14:18 | 显示全部楼层
在编辑窗口中可以按下Alt键同时滚动鼠标滚轮放大或缩小窗口内的字体。
jiekou001 发表于 2020-8-10 23:59 | 显示全部楼层
滚动鼠标轮试试,按ALT ,如果不行换Ctrl
CoolSilicon 发表于 2020-8-11 09:51 | 显示全部楼层
Windows==>Reset Windows, 试试?
mintspring 发表于 2020-8-11 16:00 | 显示全部楼层
滚动鼠标轮好用吗
奔波儿熊 发表于 2020-8-11 16:57 | 显示全部楼层
如果只是代码字体大小, ctrl+滚轮就行, 如果是界面的字体,需要调分辨率
 楼主| ersha4877 发表于 2020-8-12 19:11 | 显示全部楼层
整个界面的字体都变小,所以郁闷
xuanhuanzi 发表于 2020-8-12 19:56 | 显示全部楼层
要设置系统的显示设置吧
xuanhuanzi 发表于 2020-8-12 19:57 | 显示全部楼层
修改这个试试。
 楼主| ersha4877 发表于 2020-8-15 12:35 | 显示全部楼层
谢谢楼上,我去试试
zlzilla 发表于 2020-8-19 09:38 | 显示全部楼层
如果屏幕是高分屏,可以参照Guide设置一下就好了,MPLAB X IDE->Help->Release Note->Release Notes for MPLAB X IDE->3 Monitor Support
When using MPLAB X IDE on high DPI (Dots per inch) / UHD (Ultra High Definition) monitors, there may be issues.
Because MPLAB X IDE is based on the NetBeans platform, some issues may stem from the way NetBeans works on the high DPI monitors:
https://netbeans.org/bugzilla/show_bug.cgi?id=252452
https://stackoverflow.com/questions/23651486/netbeans-ide-scaling-on-windows-8-10
Also, system graphics drivers and even the JRE could be part of the issue.
See some solutions below.
3.1      Change Interface Settings
If the MPLAB X IDE desktop looks “fuzzy”, modify the interface behavior.
To change default options:
Find the mplab_ide.conf file under <MPLAB X IDE install directory>\mplab_platform\etc.
Open the file in an editor and find default_options=.
Insert -J-Dsun.java2d.dpiaware=false into the string and save.
Restart MPLAB X IDE.
To override scaling behavior:
Right click on a shortcut (such as the desktop icon) or an executable file (mplab_ide.exe or mplab_ide64.exe) and select “Properties”. Find the IDE executables under <MPLAB X IDE install directory>\mplab_platform\bin.
Click on the “Compatibility” tab of the “Properties” dialog.
In the “Settings” section, select an option worded as “Override High DPI scaling behavior”.
3.2      Change Font Size
To set the basic font size: Use the following executable option: –-fontsize=size, where size is in points. See also: http://wiki.netbeans.org/FaqFontSize.
To clear font settings: Erase, rename or move the Cache and/or User directories (see Help>About for locations). Then restart MPLAB X IDE.
评分
参与人数 1威望 +10 收起 理由
bellstudio + 10 很给力!
查看全部评分
 楼主| ersha4877 发表于 2020-8-22 13:00 | 显示全部楼层
如果屏幕是高分屏,可以参照Guide设置一下就好了,MPLAB X IDE->Help->Release Note->Release Notes for MP ...
谢谢,我去试试
