[开发工具] HC32F460的启动文件
 楼主| nizhenyuchina 发表于 2020-10-9 14:44 | 显示全部楼层 |阅读模式
                MODULE  ?cstartup
                ;; Forward declaration of sections.
                SECTION CSTACK:DATA:NOROOT(3)
                SECTION .intvec:CODE:NOROOT(2)
                EXTERN  __iar_program_start
                EXTERN  SystemInit
                PUBLIC  __vector_table
                SECTION .intvec:CODE:NOROOT(8)
                DATA
__vector_table
                DCD     sfe(CSTACK)               ; Top of Stack
                DCD     Reset_Handler             ; Reset
                DCD     NMI_Handler               ; NMI
                DCD     HardFault_Handler         ; Hard Fault
                DCD     MemManage_Handler         ; MemManage Fault
                DCD     BusFault_Handler          ; Bus Fault
                DCD     UsageFault_Handler        ; Usage Fault
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     SVC_Handler               ; SVCall
                DCD     DebugMon_Handler          ; Debug Monitor
                DCD     0                         ; Reserved
                DCD     PendSV_Handler            ; PendSV
                DCD     SysTick_Handler           ; SysTick
; Numbered IRQ handler vectors
; Note: renaming to device dependent ISR function names are done in
;       ddl.h (section "IRQ name definition for all type MCUs")
                DCD     IRQ000_Handler
                DCD     IRQ001_Handler
                DCD     IRQ002_Handler
                DCD     IRQ003_Handler
                DCD     IRQ004_Handler
                DCD     IRQ005_Handler
                DCD     IRQ006_Handler
                DCD     IRQ007_Handler
                DCD     IRQ008_Handler
                DCD     IRQ009_Handler
                DCD     IRQ010_Handler
                DCD     IRQ011_Handler
                DCD     IRQ012_Handler
                DCD     IRQ013_Handler
                DCD     IRQ014_Handler
                DCD     IRQ015_Handler
                DCD     IRQ016_Handler
                DCD     IRQ017_Handler
                DCD     IRQ018_Handler
                DCD     IRQ019_Handler
                DCD     IRQ020_Handler
                DCD     IRQ021_Handler
                DCD     IRQ022_Handler
                DCD     IRQ023_Handler
                DCD     IRQ024_Handler
                DCD     IRQ025_Handler
                DCD     IRQ026_Handler
                DCD     IRQ027_Handler
                DCD     IRQ028_Handler
                DCD     IRQ029_Handler
                DCD     IRQ030_Handler
                DCD     IRQ031_Handler
                DCD     IRQ032_Handler
                DCD     IRQ033_Handler
                DCD     IRQ034_Handler
                DCD     IRQ035_Handler
                DCD     IRQ036_Handler
                DCD     IRQ037_Handler
                DCD     IRQ038_Handler
                DCD     IRQ039_Handler
                DCD     IRQ040_Handler
                DCD     IRQ041_Handler
                DCD     IRQ042_Handler
                DCD     IRQ043_Handler
                DCD     IRQ044_Handler
                DCD     IRQ045_Handler
                DCD     IRQ046_Handler
                DCD     IRQ047_Handler
                DCD     IRQ048_Handler
                DCD     IRQ049_Handler
                DCD     IRQ050_Handler
                DCD     IRQ051_Handler
                DCD     IRQ052_Handler
                DCD     IRQ053_Handler
                DCD     IRQ054_Handler
                DCD     IRQ055_Handler
                DCD     IRQ056_Handler
                DCD     IRQ057_Handler
                DCD     IRQ058_Handler
                DCD     IRQ059_Handler
                DCD     IRQ060_Handler
                DCD     IRQ061_Handler
                DCD     IRQ062_Handler
                DCD     IRQ063_Handler
                DCD     IRQ064_Handler
                DCD     IRQ065_Handler
                DCD     IRQ066_Handler
                DCD     IRQ067_Handler
                DCD     IRQ068_Handler
                DCD     IRQ069_Handler
                DCD     IRQ070_Handler
                DCD     IRQ071_Handler
                DCD     IRQ072_Handler
                DCD     IRQ073_Handler
                DCD     IRQ074_Handler
                DCD     IRQ075_Handler
                DCD     IRQ076_Handler
                DCD     IRQ077_Handler
                DCD     IRQ078_Handler
                DCD     IRQ079_Handler
                DCD     IRQ080_Handler
                DCD     IRQ081_Handler
                DCD     IRQ082_Handler
                DCD     IRQ083_Handler
                DCD     IRQ084_Handler
                DCD     IRQ085_Handler
                DCD     IRQ086_Handler
                DCD     IRQ087_Handler
                DCD     IRQ088_Handler
                DCD     IRQ089_Handler
                DCD     IRQ090_Handler
                DCD     IRQ091_Handler
                DCD     IRQ092_Handler
                DCD     IRQ093_Handler
                DCD     IRQ094_Handler
                DCD     IRQ095_Handler
                DCD     IRQ096_Handler
                DCD     IRQ097_Handler
                DCD     IRQ098_Handler
                DCD     IRQ099_Handler
                DCD     IRQ100_Handler
                DCD     IRQ101_Handler
                DCD     IRQ102_Handler
                DCD     IRQ103_Handler
                DCD     IRQ104_Handler
                DCD     IRQ105_Handler
                DCD     IRQ106_Handler
                DCD     IRQ107_Handler
                DCD     IRQ108_Handler
                DCD     IRQ109_Handler
                DCD     IRQ110_Handler
                DCD     IRQ111_Handler
                DCD     IRQ112_Handler
                DCD     IRQ113_Handler
                DCD     IRQ114_Handler
                DCD     IRQ115_Handler
                DCD     IRQ116_Handler
                DCD     IRQ117_Handler
                DCD     IRQ118_Handler
                DCD     IRQ119_Handler
                DCD     IRQ120_Handler
                DCD     IRQ121_Handler
                DCD     IRQ122_Handler
                DCD     IRQ123_Handler
                DCD     IRQ124_Handler
                DCD     IRQ125_Handler
                DCD     IRQ126_Handler
                DCD     IRQ127_Handler
                DCD     IRQ128_Handler
                DCD     IRQ129_Handler
                DCD     IRQ130_Handler
                DCD     IRQ131_Handler
                DCD     IRQ132_Handler
                DCD     IRQ133_Handler
                DCD     IRQ134_Handler
                DCD     IRQ135_Handler
                DCD     IRQ136_Handler
                DCD     IRQ137_Handler
                DCD     IRQ138_Handler
                DCD     IRQ139_Handler
                DCD     IRQ140_Handler
                DCD     IRQ141_Handler
                DCD     IRQ142_Handler
                DCD     IRQ143_Handler
                THUMB
; Dummy Exception Handlers (infinite loops which can be modified)
                PUBWEAK Reset_Handler
                SECTION .text:CODE:NOROOT:REORDER(4)
Reset_Handler
;SetSRAM3Wait
;SRAM等待控制保护寄存器地址40050804将0x77写入SRAM_WTPR中
                LDR     R0, =0x40050804
                MOV     R1, #0x77
                STR     R1, [R0]
;SRAM校验控制保护寄存器地址4005080C将0x77写入SRAM_CKPR中
                LDR     R0, =0x4005080C
                MOV     R1, #0x77
                STR     R1, [R0]
;SRAM等待控制寄存器地址40050800将0x1100写入SRAM_WTCR中
;设定SRAM3的读写周期都为2周期
                LDR     R0, =0x40050800
                MOV     R1, #0x1100
                STR     R1, [R0]
;关闭SRAM_WTPR当中的使能位
                LDR     R0, =0x40050804
                MOV     R1, #0x76
                STR     R1, [R0]
;关闭SRAM_CKPR当中的使能位
                LDR     R0, =0x4005080C
                MOV     R1, #0x76
                STR     R1, [R0]
;先执行系统初始化设定时钟
                LDR     R0, =SystemInit
                BLX     R0
;在执行IAR中的
                LDR     R0, =__iar_program_start
                BX      R0
                PUBWEAK NMI_Handler
                SECTION .text:CODE:NOROOT:REORDER(1)
NMI_Handler
                B       NMI_Handler
                PUBWEAK HardFault_Handler
HardFault_Handler
                B       HardFault_Handler
                PUBWEAK MemManage_Handler
MemManage_Handler
                B       MemManage_Handler
                PUBWEAK BusFault_Handler
BusFault_Handler
                B       BusFault_Handler
                PUBWEAK UsageFault_Handler
UsageFault_Handler
                B       UsageFault_Handler
                PUBWEAK SVC_Handler
SVC_Handler
                B       SVC_Handler
                PUBWEAK DebugMon_Handler
DebugMon_Handler
                B       DebugMon_Handler
                PUBWEAK PendSV_Handler
PendSV_Handler
                B       PendSV_Handler
                PUBWEAK SysTick_Handler
SysTick_Handler
                B       SysTick_Handler
                PUBWEAK IRQ000_Handler
IRQ000_Handler
                B       IRQ000_Handler
                PUBWEAK IRQ001_Handler
IRQ001_Handler
                B       IRQ001_Handler
                PUBWEAK IRQ002_Handler
IRQ002_Handler
                B       IRQ002_Handler
                PUBWEAK IRQ003_Handler
IRQ003_Handler
                B       IRQ003_Handler
                PUBWEAK IRQ004_Handler
IRQ004_Handler
                B       IRQ004_Handler
                PUBWEAK IRQ005_Handler
IRQ005_Handler
                B       IRQ005_Handler
                PUBWEAK IRQ006_Handler
IRQ006_Handler
                B       IRQ006_Handler
                PUBWEAK IRQ007_Handler
IRQ007_Handler
                B       IRQ007_Handler
                PUBWEAK IRQ008_Handler
IRQ008_Handler
                B       IRQ008_Handler
                PUBWEAK IRQ009_Handler
IRQ009_Handler
                B       IRQ009_Handler
                PUBWEAK IRQ010_Handler
IRQ010_Handler
                B       IRQ010_Handler
                PUBWEAK IRQ011_Handler
IRQ011_Handler
                B       IRQ011_Handler
                PUBWEAK IRQ012_Handler
IRQ012_Handler
                B       IRQ012_Handler
                PUBWEAK IRQ013_Handler
IRQ013_Handler
                B       IRQ013_Handler
                PUBWEAK IRQ014_Handler
IRQ014_Handler
                B       IRQ014_Handler
                PUBWEAK IRQ015_Handler
IRQ015_Handler
                B       IRQ015_Handler
                PUBWEAK IRQ016_Handler
IRQ016_Handler
                B       IRQ016_Handler
                PUBWEAK IRQ017_Handler
IRQ017_Handler
                B       IRQ017_Handler
                PUBWEAK IRQ018_Handler
IRQ018_Handler
                B       IRQ018_Handler
                PUBWEAK IRQ019_Handler
IRQ019_Handler
                B       IRQ019_Handler
                PUBWEAK IRQ020_Handler
IRQ020_Handler
                B       IRQ020_Handler
                PUBWEAK IRQ021_Handler
IRQ021_Handler
                B       IRQ021_Handler
                PUBWEAK IRQ022_Handler
IRQ022_Handler
                B       IRQ022_Handler
                PUBWEAK IRQ023_Handler
IRQ023_Handler
                B       IRQ023_Handler
                PUBWEAK IRQ024_Handler
IRQ024_Handler
                B       IRQ024_Handler
                PUBWEAK IRQ025_Handler
IRQ025_Handler
                B       IRQ025_Handler
                PUBWEAK IRQ026_Handler
IRQ026_Handler
                B       IRQ026_Handler
                PUBWEAK IRQ027_Handler
IRQ027_Handler
                B       IRQ027_Handler
                PUBWEAK IRQ028_Handler
IRQ028_Handler
                B       IRQ028_Handler
                PUBWEAK IRQ029_Handler
IRQ029_Handler
                B       IRQ029_Handler
                PUBWEAK IRQ030_Handler
IRQ030_Handler
                B       IRQ030_Handler
                PUBWEAK IRQ031_Handler
IRQ031_Handler
                B       IRQ031_Handler
                PUBWEAK IRQ032_Handler
IRQ032_Handler
                B       IRQ032_Handler
                PUBWEAK IRQ033_Handler
IRQ033_Handler
                B       IRQ033_Handler
                PUBWEAK IRQ034_Handler
IRQ034_Handler
                B       IRQ034_Handler
                PUBWEAK IRQ035_Handler
IRQ035_Handler
                B       IRQ035_Handler
                PUBWEAK IRQ036_Handler
IRQ036_Handler
                B       IRQ036_Handler
                PUBWEAK IRQ037_Handler
IRQ037_Handler
                B       IRQ037_Handler
                PUBWEAK IRQ038_Handler
IRQ038_Handler
                B       IRQ038_Handler
                PUBWEAK IRQ039_Handler
IRQ039_Handler
                B       IRQ039_Handler
                PUBWEAK IRQ040_Handler
IRQ040_Handler
                B       IRQ040_Handler
                PUBWEAK IRQ041_Handler
IRQ041_Handler
                B       IRQ041_Handler
                PUBWEAK IRQ042_Handler
IRQ042_Handler
                B       IRQ042_Handler
                PUBWEAK IRQ043_Handler
IRQ043_Handler
                B       IRQ043_Handler
                PUBWEAK IRQ044_Handler
IRQ044_Handler
                B       IRQ044_Handler
                PUBWEAK IRQ045_Handler
IRQ045_Handler
                B       IRQ045_Handler
                PUBWEAK IRQ046_Handler
IRQ046_Handler
                B       IRQ046_Handler
                PUBWEAK IRQ047_Handler
IRQ047_Handler
                B       IRQ047_Handler
                PUBWEAK IRQ048_Handler
IRQ048_Handler
                B       IRQ048_Handler
                PUBWEAK IRQ049_Handler
IRQ049_Handler
                B       IRQ049_Handler
                PUBWEAK IRQ050_Handler
IRQ050_Handler
                B       IRQ050_Handler
                PUBWEAK IRQ051_Handler
IRQ051_Handler
                B       IRQ051_Handler
                PUBWEAK IRQ052_Handler
IRQ052_Handler
                B       IRQ052_Handler
                PUBWEAK IRQ053_Handler
IRQ053_Handler
                B       IRQ053_Handler
                PUBWEAK IRQ054_Handler
IRQ054_Handler
                B       IRQ054_Handler
                PUBWEAK IRQ055_Handler
IRQ055_Handler
                B       IRQ055_Handler
                PUBWEAK IRQ056_Handler
IRQ056_Handler
                B       IRQ056_Handler
                PUBWEAK IRQ057_Handler
IRQ057_Handler
                B       IRQ057_Handler
                PUBWEAK IRQ058_Handler
IRQ058_Handler
                B       IRQ058_Handler
                PUBWEAK IRQ059_Handler
IRQ059_Handler
                B       IRQ059_Handler
                PUBWEAK IRQ060_Handler
IRQ060_Handler
                B       IRQ060_Handler
                PUBWEAK IRQ061_Handler
IRQ061_Handler
                B       IRQ061_Handler
                PUBWEAK IRQ062_Handler
IRQ062_Handler
                B       IRQ062_Handler
                PUBWEAK IRQ063_Handler
IRQ063_Handler
                B       IRQ063_Handler
zeshoufx 发表于 2020-10-9 16:00 | 显示全部楼层
谢谢分享【HC32F460的启动文件】
看别人照片 发表于 2020-10-10 10:15 | 显示全部楼层
IRQ063_Handler
