我想用 TIMER14 CH0 触发 ADC(扫描转换模式),就怎么触发不了。高手帮我看看哪错了
#include "gd32e23x_adc.h"
#include "gd32e23x_dma.h"
#include "gd32e23x_gpio.h"
#include "gd32e23x_timer.h"
static volatile uint16_t data[4];
static void rcuConfig();
static void adcConfig();
static void dmaConfig();
static void portConfig();
static void timerConfig();
void main() {
rcuConfig();
timerConfig();
portConfig();
dmaConfig();
adcConfig();
timer_enable(TIMER14);
gpio_bit_set(GPIOB, GPIO_PIN_4);
while (1)
void rcuConfig() {
rcu_periph_clock_enable(RCU_GPIOA);
rcu_periph_clock_enable(RCU_GPIOB);
rcu_periph_clock_enable(RCU_ADC);
rcu_periph_clock_enable(RCU_DMA);
rcu_periph_clock_enable(RCU_TIMER14);
rcu_adc_clock_config(RCU_ADCCK_AHB_DIV3);
void adcConfig() {
adc_special_function_config(ADC_SCAN_MODE, ENABLE);
adc_dma_mode_enable();
adc_channel_length_config(ADC_REGULAR_CHANNEL, 4U);
adc_regular_channel_config(1U, ADC_CHANNEL_3, ADC_SAMPLETIME_1POINT5);
adc_regular_channel_config(2U, ADC_CHANNEL_4, ADC_SAMPLETIME_1POINT5);
adc_regular_channel_config(3U, ADC_CHANNEL_8, ADC_SAMPLETIME_1POINT5);
adc_regular_channel_config(4U, ADC_CHANNEL_9, ADC_SAMPLETIME_1POINT5);
adc_external_trigger_config(ADC_REGULAR_CHANNEL, ENABLE);
adc_external_trigger_source_config(ADC_REGULAR_CHANNEL,
ADC_EXTTRIG_REGULAR_T14_CH0);
adc_enable();
for (uint16_t i = 0; i < 1000; ++i)
adc_calibration_enable();
void dmaConfig() {
dma_parameter_struct initParam;
initParam.periph_addr = 0x4001244CU; // ADC_RDATA
initParam.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
initParam.memory_addr = (uint32_t)data;
initParam.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
initParam.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
initParam.memory_width = DMA_MEMORY_WIDTH_16BIT;
initParam.direction = DMA_PERIPHERAL_TO_MEMORY;
initParam.number = 4U;
initParam.priority = DMA_PRIORITY_HIGH;
dma_init(DMA_CH0, &initParam);
dma_circulation_enable(DMA_CH0);
dma_interrupt_enable(DMA_CH0, DMA_INT_FTF);
dma_interrupt_flag_clear(DMA_CH0, DMA_INT_FLAG_FTF);
nvic_irq_enable(DMA_Channel0_IRQn, 1);
dma_channel_enable(DMA_CH0);
void portConfig() {
gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_3);
gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_4);
gpio_mode_set(GPIOB, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_0);
gpio_mode_set(GPIOB, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_1);
gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_4); // LED
void timerConfig() {
timer_parameter_struct initParam;
initParam.prescaler = 71;
initParam.alignedmode = TIMER_COUNTER_EDGE;
initParam.counterdirection = TIMER_COUNTER_UP;
initParam.period = 99;
initParam.clockdivision = TIMER_CKDIV_DIV1;
initParam.repetitioncounter = 0U;
timer_init(TIMER14, &initParam);
timer_oc_parameter_struct ocParam;
ocParam.outputstate = TIMER_CCX_ENABLE;
ocParam.ocpolarity = TIMER_OC_POLARITY_HIGH;
timer_channel_output_config(TIMER14, TIMER_CH_0, &ocParam);
timer_channel_output_pulse_value_config(TIMER14, TIMER_CH_0, 2U);
timer_channel_output_mode_config(TIMER14, TIMER_CH_0, TIMER_OC_MODE_PWM1);
void DMA_Channel0_IRQHandler() {
static uint32_t i = 0;
if (dma_interrupt_flag_get(DMA_CH0, DMA_INT_FLAG_FTF)) {
++i;
if (i == 10000) {
i = 0;
gpio_bit_toggle(GPIOB, GPIO_PIN_4);
