今天移植代码发现rtc的这个函数,在设置年月日的时候成功,但是时分秒一直无法设置成功
- void RTC_InitTime( UINT16 y, UINT16 mon, UINT16 d, UINT16 h, UINT16 m, UINT16 s )
- UINT32 t;
- UINT16 year, month, day, sec2, t32k;
- UINT8V clk_pin;
- year = y;
- month = mon;
- day = 0;
- while ( year > BEGYEAR )
- day += YearLength( year-1 );
- year--;
- while ( month > 1 )
- day += monthLength( IsLeapYear( y ), month-2 );
- month--;
- day += d-1;
- sec2 = (h%24)*1800+m*30+s/2;
- t32k = (s&1)?(0x8000):(0);
- t = sec2;
- t = t<<16 | t32k;
- do{
- clk_pin = (R8_CK32K_CONFIG&RB_32K_CLK_PIN);
- }while( (clk_pin != (R8_CK32K_CONFIG&RB_32K_CLK_PIN)) || (!clk_pin) );
- R8_SAFE_ACCESS_SIG = SAFE_ACCESS_SIG1;
- R8_SAFE_ACCESS_SIG = SAFE_ACCESS_SIG2;
- R32_RTC_TRIG = day;
- R8_RTC_MODE_CTRL |= RB_RTC_LOAD_HI;
- R32_RTC_TRIG = t;
- R8_RTC_MODE_CTRL |= RB_RTC_LOAD_LO;
- R8_SAFE_ACCESS_SIG = 0;
经过测试,发现在设置时分秒之前,重新开关一下
能够解决该异常.
修改如下图所示:
