AT32F403A.cfg 配置文件如下
- #CMSIS DAP-HS
- source [find interface/atlink.cfg]
- # adapter driver cmsis-dap
- #SWD
- # transport select swd
- #MCU
- source [find target/at32f4xx.cfg]
- #10M
- adapter speed 5000
- # 不使用复位接口
- reset_config none
CLion 实际运行的命令如下- D:\DevelopTools\OpenOCD_V2.0.0\bin\openocd.exe
- -s D:\DevelopTools\OpenOCD_V2.0.0\share\openocd\scripts
- -f D:\Documents\AT32workspace\Develop\AT32F403A.cfg
- -c "tcl_port disabled" -c "gdb_port disabled" -c "tcl_port disabled"
- -c "program "D:/Documents/AT32workspace/Develop/cmake-build-debug/Develop.elf""
- -c reset -c shutdown
报错如下(仍旧是flash driver 'at32f4x' not found)
- Open On-Chip Debugger 0.10.0+dev-snapshot (2021-12-17-16:55)
- Licensed under GNU GPL v2
- For bug reports, read
- http://openocd.org/doc/doxygen/bugs.html
- adapter speed: 5000 kHz
- Error: flash driver 'at32f4x' not found
