- /* Define to prevent recursive inclusion -------------------------------------*/
- #define __EEPROM_C__
- /* Includes ------------------------------------------------------------------*/
- #include "EEPROM.h"
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- /* Exported variables --------------------------------------------------------*/
- /* Exported function prototypes ----------------------------------------------*/
- * [url=home.php?mod=space&uid=247401]@brief[/url]
- * @param
- * @retval
- * [url=home.php?mod=space&uid=93590]@Attention[/url]
- void _I2C_EEPROM_AckPolling(void)
- uint32_t reg;
- /* wait if bus busy */
- while(I2C_GetFlagStatus(HT_I2C1, I2C_FLAG_BUSBUSY));
- while(1)
- /* send slave address */
- I2C_TargetAddressConfig(HT_I2C1, I2C_EEPROM_DEV_ADDR, I2C_MASTER_WRITE);
- /* check status */
- while(1)
- reg = HT_I2C1->SR;
- if(reg & I2C_FLAG_ADRS)
- return;
- if(reg & I2C_FLAG_RXNACK)
- I2C_ClearFlag(HT_I2C1, I2C_FLAG_RXNACK);
- break;
- * @param
- * @retval
- void I2C_EEPROM_BufferRead(uint8_t* pBuffer, uint8_t ReadAddr, uint16_t NumByteToRead)
- /* check parameters */
- Assert_Param(NumByteToRead > 0);
- /* acknowledge polling */
- _I2C_EEPROM_AckPolling();
- /* set EEPROM address */
- while (!I2C_CheckStatus(HT_I2C1, I2C_MASTER_TX_EMPTY));
- I2C_SendData(HT_I2C1, ReadAddr);
- /* send read command */
- I2C_TargetAddressConfig(HT_I2C1, I2C_EEPROM_DEV_ADDR, I2C_MASTER_READ);
- while(!I2C_CheckStatus( HT_I2C1, I2C_MASTER_SEND_START));
- while(!I2C_CheckStatus( HT_I2C1, I2C_MASTER_RECEIVER_MODE));
- /* enable master receiver ACK */
- if(NumByteToRead > 1)
- I2C_AckCmd(HT_I2C1, ENABLE);
- /* sequential read */
- while(NumByteToRead)
- while(!I2C_CheckStatus(HT_I2C1, I2C_MASTER_RX_NOT_EMPTY));
- *pBuffer++ = I2C_ReceiveData(HT_I2C1);
- if(--NumByteToRead == 1)
- I2C_AckCmd(HT_I2C1, DISABLE);
- /* end of read */
- I2C_GenerateSTOP(HT_I2C1);
- * @brief
- * @param
- * @retval
- * @attention
- void I2C_EEPROM_PageWrite(uint8_t* pBuffer, uint8_t WriteAddr, uint16_t NumByteToWrite)
- Assert_Param((NumByteToWrite > 0) &&
- ((NumByteToWrite <= (I2C_EEPROM_PAGE_SIZE - (WriteAddr & I2C_EEPROM_PAGE_MASK)))));
- while(!I2C_CheckStatus(HT_I2C1, I2C_MASTER_TX_EMPTY));
- I2C_SendData(HT_I2C1, WriteAddr);
- /* page write */
- while(NumByteToWrite--)
- I2C_SendData(HT_I2C1, *pBuffer++);
- /* end of write */
- * @brief
- * @param
- * @retval
- * @attention
- void I2C_EEPROM_BufferWrite(uint8_t* pBuffer, uint8_t WriteAddr, uint16_t NumByteToWrite)
- uint16_t Byte2Wr, AvailableByte;
- Assert_Param(NumByteToWrite <= I2C_EEPROM_CAPACITY);
- /* sequential write */
- while (NumByteToWrite)
- AvailableByte = I2C_EEPROM_PAGE_SIZE - (WriteAddr & I2C_EEPROM_PAGE_MASK);
- Byte2Wr = (NumByteToWrite > AvailableByte)?(AvailableByte):(NumByteToWrite);
- I2C_EEPROM_PageWrite(pBuffer, WriteAddr, Byte2Wr);
- pBuffer += Byte2Wr;
- WriteAddr = (WriteAddr + Byte2Wr) & I2C_EEPROM_ADDR_MASK;
- NumByteToWrite -= Byte2Wr;
- * @brief
- * @param
- * @retval
- * @attention
- void EEPROM_Init(void)
- I2C_InitTypeDef I2C_InitStructure;
- CKCU_PeripClockConfig_TypeDef CKCUClock = {{0}};
- CKCUClock.Bit.PB = 1;
- CKCUClock.Bit.PC = 1;
- CKCUClock.Bit.I2C1 = 1;
- CKCUClock.Bit.AFIO = 1;
- CKCU_PeripClockConfig(CKCUClock, ENABLE);
- AFIO_GPxConfig(GPIO_PB, AFIO_PIN_15, AFIO_FUN_I2C);
- AFIO_GPxConfig(GPIO_PC, AFIO_PIN_0, AFIO_FUN_I2C);
- I2C_InitStructure.I2C_GeneralCall = I2C_GENERALCALL_DISABLE;
- I2C_InitStructure.I2C_AddressingMode = I2C_ADDRESSING_7BIT;
- I2C_InitStructure.I2C_Acknowledge = I2C_ACK_DISABLE;
- I2C_InitStructure.I2C_OwnAddress = 0x00;
- I2C_InitStructure.I2C_Speed = 400000; //---400k
- I2C_InitStructure.I2C_SpeedOffset = 0;
- I2C_Init(HT_I2C1, &I2C_InitStructure);
- I2C_Cmd(HT_I2C1, ENABLE);
- * @brief
- * @param
- * @retval
- * @attention
- void EEPROM_Demo(void)
- uint8_t wBuffer[I2C_EEPROM_PAGE_SIZE];
- uint8_t rBuffer[I2C_EEPROM_PAGE_SIZE];
- for(uint32_t j = 0; j < (I2C_EEPROM_CAPACITY / I2C_EEPROM_PAGE_SIZE); j++)
- memset(rBuffer, 0, sizeof(rBuffer));
- memset(wBuffer, 0, sizeof(wBuffer));
- for(uint32_t i = 0; i < I2C_EEPROM_PAGE_SIZE; i++)
- wBuffer[i] = rand();
- I2C_EEPROM_BufferWrite((uint8_t *)wBuffer, I2C_EEPROM_PAGE_SIZE * j, I2C_EEPROM_PAGE_SIZE);
- printf("\r\nEEPROM Write...[Page%d]", j+1);
- if((i % 10) == 0) printf("\r\n");
- printf("0x%02x ", wBuffer[i]);
- I2C_EEPROM_BufferRead((uint8_t *)rBuffer, I2C_EEPROM_PAGE_SIZE * j, I2C_EEPROM_PAGE_SIZE);
- printf("\r\nEEPROM Read....[Page%d]", j+1);
- printf("0x%02x ", rBuffer[i]);
- if(rBuffer[i] != wBuffer[i])
- printf("\r\n\r\nEEPROM Read & Write Test Failed!!!"); while(1);
- printf("\t\tCompare Success : %d%%\r\n", (int)((j + 1) * 100) / (I2C_EEPROM_CAPACITY / I2C_EEPROM_PAGE_SIZE));
- printf("\r\n\r\nEEPROM Read & Write Test Pass!!!");
- #define __SPI_FLASH_C__
- #include "SPI_FLASH.h"
- #include <sfud.h>
- #define SFUD_DEMO_BUFFER_SIZE (512)
- uint8_t sfud_demo_buf[SFUD_DEMO_BUFFER_SIZE];
- * @brief SFUD demo for the first flash device test
- * @param addr flash start address
- * @param size test flash size
- * @param size test flash data buffer
- * @retval
- * @attention
- void sfud_demo(uint32_t addr, size_t size, uint8_t *data)
- sfud_err result = SFUD_SUCCESS;
- const sfud_flash *flash = sfud_get_device_table() + 0;
- size_t i;
- /* prepare write data */
- for(i = 0; i < size; i++)
- data[i] = i;
- /* erase test */
- result = sfud_erase(flash, addr, size);
- if(result == SFUD_SUCCESS)
- printf("\r\nErase the %s flash data finish. Start from 0x%08X, size is %d.\r\n", flash->name, addr, size);
- else
- printf("\r\nErase the %s flash data failed.\r\n", flash->name);
- return;
- /* write test */
- result = sfud_write(flash, addr, size, data);
- printf("\r\nWrite the %s flash data finish. Start from 0x%08X, size is %d.\r\n", flash->name, addr, size);
- else
- printf("\r\nWrite the %s flash data failed.\r\n", flash->name);
- return;
- /* read test */
- result = sfud_read(flash, addr, size, data);
- printf("\r\nRead the %s flash data success. Start from 0x%08X, size is %d. The data is:\r\n", flash->name, addr, size);
- printf("Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F\r\n");
- if((i % 16) == 0)
- printf("[%08X] ", addr + i);
- printf("%02X ", data[i]);
- if(((i + 1) % 16 == 0) || (i == size - 1))
- printf("\r\n");
- printf("\r\n");
- else
- printf("\r\nRead the %s flash data failed.\r\n", flash->name);
- /* data check */
- if(data[i] != i % 256)
- printf("\r\nRead and check write data has an error. Write the %s flash data failed.\r\n", flash->name);
- break;
- if(i == size)
- printf("\r\nThe %s flash test is success.\r\n", flash->name);
- * @brief
- * @param
- * @retval
- * @attention
- void SPI_FLASH_Init(void)
- printf("\r\n");
- if(sfud_init() == SFUD_SUCCESS)
- sfud_demo(0, sizeof(sfud_demo_buf), sfud_demo_buf);
- #include <sfud.h>
- #include <stdarg.h>
- #include "config.h"
- static char log_buf[256];
- void sfud_log_debug(const char *file, const long line, const char *format, ...);
- * SPI write data then read data
- static sfud_err spi_write_read(const sfud_spi *spi, const uint8_t *write_buf, size_t write_size, uint8_t *read_buf,
- size_t read_size) {
- uint8_t send_data, read_data;
- if (write_size) {
- SFUD_ASSERT(write_buf);
- if (read_size) {
- SFUD_ASSERT(read_buf);
- * add your spi write and read code
- GPIO_ClearOutBits(HT_GPIOA, GPIO_PIN_8);
- for (size_t i = 0; i < (write_size + read_size); i++) {
- if (i < write_size) {
- send_data = *write_buf++;
- } else {
- send_data = SFUD_DUMMY_DATA;
- while(!SPI_GetFlagStatus(HT_SPI1, SPI_FLAG_TXBE));
- SPI_SendData(HT_SPI1, send_data);
- while(!SPI_GetFlagStatus(HT_SPI1, SPI_FLAG_RXBNE));
- read_data = SPI_ReceiveData(HT_SPI1);
- if (i >= write_size) {
- *read_buf++ = read_data;
- GPIO_SetOutBits(HT_GPIOA, GPIO_PIN_8);
- return result;
- #ifdef SFUD_USING_QSPI
- * read flash data by QSPI
- static sfud_err qspi_read(const struct __sfud_spi *spi, uint32_t addr, sfud_qspi_read_cmd_format *qspi_read_cmd_format,
- uint8_t *read_buf, size_t read_size) {
- * add your qspi read flash data code
- return result;
- #endif /* SFUD_USING_QSPI */
- static void rcc_initialize(void) {
- CKCUClock.Bit.PA = 1;
- CKCUClock.Bit.SPI1 = 1;
- static void gpio_initialize(void) {
- AFIO_GPxConfig(GPIO_PA, GPIO_PIN_8, AFIO_FUN_GPIO);
- AFIO_GPxConfig(GPIO_PA, GPIO_PIN_15, AFIO_FUN_SPI);
- AFIO_GPxConfig(GPIO_PB, GPIO_PIN_6, AFIO_FUN_SPI);
- AFIO_GPxConfig(GPIO_PC, GPIO_PIN_3, AFIO_FUN_SPI);
- GPIO_DirectionConfig(HT_GPIOA, GPIO_PIN_8, GPIO_DIR_OUT);
- static void spi_device_initialize(void) {
- SPI_InitTypeDef SPI_InitStructure;
- SPI_InitStructure.SPI_Mode = SPI_MASTER;
- SPI_InitStructure.SPI_FIFO = SPI_FIFO_DISABLE;
- SPI_InitStructure.SPI_DataLength = SPI_DATALENGTH_8;
- SPI_InitStructure.SPI_SELMode = SPI_SEL_SOFTWARE;
- SPI_InitStructure.SPI_SELPolarity = SPI_SELPOLARITY_LOW;
- SPI_InitStructure.SPI_FirstBit = SPI_FIRSTBIT_MSB;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_HIGH;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_SECOND;
- SPI_InitStructure.SPI_RxFIFOTriggerLevel = 0;
- SPI_InitStructure.SPI_TxFIFOTriggerLevel = 0;
- #if (LIBCFG_MAX_SPEED > 48000000)
- SPI_InitStructure.SPI_ClockPrescaler = 4;
- #else
- SPI_InitStructure.SPI_ClockPrescaler = 2;
- #endif
- SPI_Init(HT_SPI1, &SPI_InitStructure);
- SPI_SELOutputCmd(HT_SPI1, ENABLE);
- SPI_Cmd(HT_SPI1, ENABLE);
- static void spi_lock(const sfud_spi *spi) {
- __disable_irq();
- static void spi_unlock(const sfud_spi *spi) {
- __enable_irq();
- static void retry_delay_100us(void) {
- uint32_t delay = 120;
- while (delay--);
- sfud_err sfud_spi_port_init(sfud_flash *flash) {
- * add your port spi bus and device object initialize code like this:
- * 1. rcc initialize
- * 2. gpio initialize
- * 3. spi device initialize
- * 4. flash->spi and flash->retry item initialize
- * flash->spi.wr = spi_write_read; //Required
- * flash->spi.qspi_read = qspi_read; //Required when QSPI mode enable
- * flash->spi.lock = spi_lock;
- * flash->spi.unlock = spi_unlock;
- * flash->spi.user_data = &spix;
- * flash->retry.delay = null;
- * flash->retry.times = 10000; //Required
- switch (flash->index) {
- case SFUD_FLASH_DEVICE_INDEX:
- rcc_initialize();
- gpio_initialize();
- spi_device_initialize();
- flash->spi.wr = spi_write_read;
- flash->spi.qspi_read = qspi_read;
- flash->spi.lock = spi_lock;
- flash->spi.unlock = spi_unlock;
- flash->spi.user_data = NULL;
- flash->retry.delay = retry_delay_100us;
- flash->retry.times = 60 * 10000;
- break;
- default: break;
- return result;
- * This function is print debug info.
- * @param file the file which has call this function
- * @param line the line number which has call this function
- * @param format output format
- * @param ... args
- void sfud_log_debug(const char *file, const long line, const char *format, ...) {
- va_list args;
- /* args point to the first variable parameter */
- va_start(args, format);
- printf("[SFUD](%s:%ld) ", file, line);
- /* must use vprintf to print */
- vsnprintf(log_buf, sizeof(log_buf), format, args);
- printf("%s\r\n", log_buf);
- va_end(args);
- * This function is print routine info.
- * @param ... args
- void sfud_log_info(const char *format, ...) {
- va_list args;
- printf("[SFUD]");
- va_end(args);
运行结果
软件工程源代码
Project.zip
(896.97 KB, 下载次数: 10)
