(1)进行配置内核时,报错如下:
*** Unable to find the ncurses libraries or the
*** required header files.
*** 'make menuconfig' requires the ncurses libraries.
*** Install ncurses (ncurses-devel) and try again.
make[1]: *** [scripts/kconfig/dochecklxdialog] Error 1
make: *** [menuconfig] Error 2
(2)解决措施:
执行命令: sudo apt-get install ncurses-dev即可!
出现以下问题:
Do you want to continue [Y/n]? y
Err http://us.archive.ubuntu.com/ubuntu/ oneiric/main libtinfo-dev i386 5.9-1ubuntu5
Something wicked happened resolving 'us.archive.ubuntu.com:http' (-5 - No address associated with hostname)
Err http://us.archive.ubuntu.com/ubuntu/ oneiric/main libncurses5-dev i386 5.9-1ubuntu5
Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/n/ncurses/libtinfo-dev_5.9-1ubuntu5_i386.deb Something wicked happened resolving 'us.archive.ubuntu.com:http' (-5 - No address associated with hostname)
Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/n/ncurses/libncurses5-dev_5.9-1ubuntu5_i386.deb Something wicked happened resolving 'us.archive.ubuntu.com:http' (-5 - No address associated with hostname)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
原因:ubuntu 无法连接到internet,能上网之后就可以更新安装。 |
