中断函数里通常会调用HAL_TIM_IRQHandler(&Input_Handle);这个函数来区分是哪一种中断
- * @brief This function handles TIM interrupts requests.
- * @param htim TIM handle
- * @retval None
- void HAL_TIM_IRQHandler(TIM_HandleTypeDef *htim)
- /* Capture compare 1 event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC1) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC1) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC1);
- htim->Channel = HAL_TIM_ACTIVE_CHANNEL_1;
- /* Input capture event */
- if((htim->Instance->CCMR1 & TIM_CCMR1_CC1S) != 0x00U)
- HAL_TIM_IC_CaptureCallback(htim);
- /* Output compare event */
- else
- HAL_TIM_OC_DelayElapsedCallback(htim);
- HAL_TIM_PWM_PulseFinishedCallback(htim);
- htim->Channel = HAL_TIM_ACTIVE_CHANNEL_CLEARED;
- /* Capture compare 2 event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC2) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC2) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC2);
- htim->Channel = HAL_TIM_ACTIVE_CHANNEL_2;
- if((htim->Instance->CCMR1 & TIM_CCMR1_CC2S) != 0x00U)
- else
- /* Capture compare 3 event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC3) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC3) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC3);
- htim->Channel = HAL_TIM_ACTIVE_CHANNEL_3;
- if((htim->Instance->CCMR2 & TIM_CCMR2_CC3S) != 0x00U)
- else
- /* Capture compare 4 event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC4) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC4) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_CC4);
- htim->Channel = HAL_TIM_ACTIVE_CHANNEL_4;
- if((htim->Instance->CCMR2 & TIM_CCMR2_CC4S) != 0x00U)
- else
- /* TIM Update event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_UPDATE) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_UPDATE) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_UPDATE);
- HAL_TIM_PeriodElapsedCallback(htim);
- /* TIM Break input event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_BREAK) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_BREAK) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_BREAK);
- HAL_TIMEx_BreakCallback(htim);
- /* TIM Trigger detection event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_TRIGGER) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_TRIGGER) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_IT_TRIGGER);
- HAL_TIM_TriggerCallback(htim);
- /* TIM commutation event */
- if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_COM) != RESET)
- if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_COM) !=RESET)
- __HAL_TIM_CLEAR_IT(htim, TIM_FLAG_COM);
- HAL_TIMEx_CommutationCallback(htim);
