五、测试代码
- #include "stdio.h"
- #include <NuMicro.h>
- #include <rtthread.h>
- //配置优先级,栈大小,时间片,设置不对没法运行的。
- #define THREAD_PRIORITY 5
- #define THREAD_STACK_SIZE 256
- #define THREAD_TIMESLICE 10
- void led(void *parameter)
- rt_kprintf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
- rt_kprintf("+-------------------------------------------------+\n");
- rt_kprintf("| PB14(Output) Sample Code |\n");
- rt_kprintf("+-------------------------------------------------+\n\n");
- rt_kprintf("Hello RTT_NANO\n");
- while(1)
- PB14=0;
- rt_thread_mdelay(2000);
- rt_kprintf("\nLED1 is ON\n");
- PB14=1;
- rt_kprintf("\nLED1 is OFF\n");
- /* 导出到 msh 命令列表中 */
- MSH_CMD_EXPORT(led, RT-Thread first led sample);
- void led2(void *parameter)
- while(1)
- PB14=0;
- rt_thread_mdelay(3000);
- rt_kprintf("\nLED2 is ON\n");
- PB14=1;
- rt_kprintf("\nLED2 is OFF\n");
- MSH_CMD_EXPORT(led2, RT-Thread second led sample);
- int led_sample(void)
- static rt_thread_t tid = RT_NULL;
- static rt_thread_t tid2 = RT_NULL;
- /* 创建线程1 */
- tid = rt_thread_create("thread1",
- led, RT_NULL,
- THREAD_STACK_SIZE,
- THREAD_PRIORITY, THREAD_TIMESLICE);
- if (tid != RT_NULL)
- rt_thread_startup(tid);
- /* 创建线程2 */
- tid2 = rt_thread_create("thread2",
- led2, RT_NULL,
- if (tid2 != RT_NULL)
- rt_thread_startup(tid2);
- //该例子共用PB14端口,所以一并在创建线程时候初始化为输出模式
- GPIO_SetMode(PB, BIT14, GPIO_MODE_OUTPUT);
- return 0;
- MSH_CMD_EXPORT(led_sample, RT-Thread sample);
- /* Main Function */
- int32_t main(void)
- led_sample();
- return 0;
