在int main() { }前面添加自定义改变PWM参数的函数
- /* USER CODE BEGIN PV */
- uint8_t duty_cycle=0;
- /* USER CODE END PV */
- /* USER CODE BEGIN 0 */
- void Set_PWM_DUTYCYCLE(uint8_t duty_cycle)
- TIM_OC_InitTypeDef sConfigOC;
- sConfigOC.OCMode = TIM_OCMODE_PWM1;
- sConfigOC.Pulse = duty_cycle;
- sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
- sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
- if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
- Error_Handler();
- HAL_TIM_MspPostInit(&htim3);
- HAL_TIM_PWM_Start(&htim3,TIM_CHANNEL_4);
- /* USER CODE END 0 */
