- * ili9488.h
- * Created on: Dec 14, 2021
- * Author: timagr615
- #ifndef INC_ILI9488_H_
- #define INC_ILI9488_H_
- #include <math.h>
- #include <stdbool.h>
- #include "main.h"
- #include <stdlib.h>
- #include <stdio.h>
- #include <string.h>
- #define RST_A() HAL_GPIO_WritePin(TFT_RST_GPIO_Port,TFT_RST_Pin,GPIO_PIN_RESET)
- #define RST_D() HAL_GPIO_WritePin(TFT_RST_GPIO_Port,TFT_RST_Pin,GPIO_PIN_SET)
- #define CS_A() HAL_GPIO_WritePin(TFT_CS_GPIO_Port,TFT_CS_Pin,GPIO_PIN_RESET)
- #define CS_D() HAL_GPIO_WritePin(TFT_CS_GPIO_Port,TFT_CS_Pin,GPIO_PIN_SET)
- #define DC_COMMAND() HAL_GPIO_WritePin(TFT_DC_GPIO_Port,TFT_DC_Pin,GPIO_PIN_RESET)
- #define DC_DATA() HAL_GPIO_WritePin(TFT_DC_GPIO_Port,TFT_DC_Pin,GPIO_PIN_SET)
- #define ILI9488_TFTWIDTH 320
- #define ILI9488_TFTHEIGHT 480
- #define ILI9488_PIXEL_COUNT ILI9488_TFTWIDTH * ILI9488_TFTHEIGHT
- #define ILI9488_NOP 0x00
- #define ILI9488_SWRESET 0x01
- #define ILI9488_RDDID 0x04
- #define ILI9488_RDDST 0x09
- #define ILI9488_SLPIN 0x10
- #define ILI9488_SLPOUT 0x11
- #define ILI9488_PTLON 0x12
- #define ILI9488_NORON 0x13
- #define ILI9488_RDMODE 0x0A
- #define ILI9488_RDMADCTL 0x0B
- #define ILI9488_RDPIXFMT 0x0C
- #define ILI9488_RDIMGFMT 0x0D
- #define ILI9488_RDSELFDIAG 0x0F
- #define ILI9488_INVOFF 0x20
- #define ILI9488_INVON 0x21
- #define ILI9488_GAMMASET 0x26
- #define ILI9488_DISPOFF 0x28
- #define ILI9488_DISPON 0x29
- #define ILI9488_CASET 0x2A
- #define ILI9488_PASET 0x2B
- #define ILI9488_RAMWR 0x2C
- #define ILI9488_RAMRD 0x2E
- #define ILI9488_PTLAR 0x30
- #define ILI9488_MADCTL 0x36
- #define ILI9488_PIXFMT 0x3A
- #define ILI9488_FRMCTR1 0xB1
- #define ILI9488_FRMCTR2 0xB2
- #define ILI9488_FRMCTR3 0xB3
- #define ILI9488_INVCTR 0xB4
- #define ILI9488_DFUNCTR 0xB6
- #define ILI9488_PWCTR1 0xC0
- #define ILI9488_PWCTR2 0xC1
- #define ILI9488_PWCTR3 0xC2
- #define ILI9488_PWCTR4 0xC3
- #define ILI9488_PWCTR5 0xC4
- #define ILI9488_VMCTR1 0xC5
- #define ILI9488_VMCTR2 0xC7
- #define ILI9488_RDID1 0xDA
- #define ILI9488_RDID2 0xDB
- #define ILI9488_RDID3 0xDC
- #define ILI9488_RDID4 0xDD
- #define ILI9488_GMCTRP1 0xE0
- #define ILI9488_GMCTRN1 0xE1
- #define ILI9488_PWCTR6 0xFC
- // Color definitions
- #define ILI9488_BLACK 0x0000 /* 0, 0, 0 */
- #define ILI9488_NAVY 0x000F /* 0, 0, 128 */
- #define ILI9488_DARKGREEN 0x03E0 /* 0, 128, 0 */
- #define ILI9488_DARKCYAN 0x03EF /* 0, 128, 128 */
- #define ILI9488_MAROON 0x7800 /* 128, 0, 0 */
- #define ILI9488_PURPLE 0x780F /* 128, 0, 128 */
- #define ILI9488_OLIVE 0x7BE0 /* 128, 128, 0 */
- #define ILI9488_LIGHTGREY 0xC618 /* 192, 192, 192 */
- #define ILI9488_DARKGREY 0x7BEF /* 128, 128, 128 */
- #define ILI9488_BLUE 0x001F /* 0, 0, 255 */
- #define ILI9488_GREEN 0x07E0 /* 0, 255, 0 */
- #define ILI9488_CYAN 0x07FF /* 0, 255, 255 */
- #define ILI9488_RED 0xF800 /* 255, 0, 0 */
- #define ILI9488_MAGENTA 0xF81F /* 255, 0, 255 */
- #define ILI9488_YELLOW 0xFFE0 /* 255, 255, 0 */
- #define ILI9488_WHITE 0xFFFF /* 255, 255, 255 */
- #define ILI9488_ORANGE 0xFD20 /* 255, 165, 0 */
- #define ILI9488_GREENYELLOW 0xAFE5 /* 173, 255, 47 */
- #define ILI9488_PINK 0xF81F
- #define TFT9341_BLACK 0x0000
- #define TFT9341_BLUE 0x001F
- #define TFT9341_RED 0xF800
- #define TFT9341_GREEN 0x07E0
- #define TFT9341_CYAN 0x07FF
- #define TFT9341_MAGENTA 0xF81F
- #define TFT9341_YELLOW 0xFFE0
- #define TFT9341_WHITE 0xFFFF
- #define MADCTL_MY 0x80
- #define MADCTL_MX 0x40
- #define MADCTL_MV 0x20
- #define MADCTL_ML 0x10
- #define MADCTL_RGB 0x00
- #define MADCTL_BGR 0x08
- #define MADCTL_MH 0x04
- #define swap(a, b) { int16_t t = a; a = b; b = t; }
- #define pgm_read_byte(addr) (*(const unsigned char *)(addr))
- #define min(a,b) (((a)<(b))?(a):(b))
- //***** Functions prototypes *****//
- //1. Write Command to LCD
- void ILI9341_SendCommand(uint8_t com);
- //2. Write data to LCD
- void ILI9341_SendData(uint8_t data);
- //2.2 Write multiple/DMA
- void ILI9488_SendData_Multi(uint8_t *buff, size_t buff_size);
- //void ILI9488_Init(SPI_HandleTypeDef *spiLcdHandle, GPIO_TypeDef *csPORT, uint16_t csPIN, GPIO_TypeDef *dcPORT, uint16_t dcPIN, GPIO_TypeDef *resetPORT, uint16_t resetPIN);
- void ILI9488_Init();
- void setAddrWindow(uint16_t x0, uint16_t y0, uint16_t x1, uint16_t y1);
- void setScrollArea(uint16_t topFixedArea, uint16_t bottomFixedArea);
- void scroll(uint16_t pixels);
- void pushColor(uint16_t color);
- void pushColors(uint16_t *data, uint8_t len, uint8_t first);
- void drawImage(const uint8_t* img, uint16_t x, uint16_t y, uint16_t w, uint16_t h);
- void fillScreen(uint16_t color);
- void drawPixel(int16_t x, int16_t y, uint16_t color);
- void drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color);
- void drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color);
- void drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1,uint16_t color);
- void writeLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1,uint16_t color);
- void fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color);
- void setRotation(uint8_t r);
- void invertDisplay(uint8_t i);
- uint16_t color565(uint8_t r, uint8_t g, uint8_t b);
- void drawChar(int16_t x, int16_t y, unsigned char c, uint16_t color, uint16_t bg, uint8_t size);
- void ILI9488_printText(char text[], int16_t x, int16_t y, uint16_t color, uint16_t bg, uint8_t size);
- void write16BitColor(uint16_t color);
- void testLines(uint8_t color);
- #endif /* INC_ILI9488_H_ */
2、添加ili9488.c代码如下:
- * ili9488.c
- * Created on: Nov 12, 2023
- * Author: liujianhua
- #include "ili9488.h"
- #include "FONT.H"
- extern SPI_HandleTypeDef hspi1;
- extern UART_HandleTypeDef huart1;
- static uint8_t rotationNum=1;
- static bool _cp437 = false;
- static SPI_HandleTypeDef lcdSPIhandle;
- //Chip Select pin
- static GPIO_TypeDef *tftCS_GPIO;
- static uint16_t tftCS_PIN;
- //Data Command pin
- static GPIO_TypeDef *tftDC_GPIO;
- static uint16_t tftDC_PIN;
- //Reset pin
- static GPIO_TypeDef *tftRESET_GPIO;
- static uint16_t tftRESET_PIN;
- //uint8_t frm_buf[65536] = {0};
- uint16_t width;
- uint16_t height;
- static //Text simple font array (You can your own font)
- const unsigned char font1[] = {
- 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x3E, 0x5B, 0x4F, 0x5B, 0x3E,
- 0x3E, 0x6B, 0x4F, 0x6B, 0x3E,
- 0x1C, 0x3E, 0x7C, 0x3E, 0x1C,
- 0x18, 0x3C, 0x7E, 0x3C, 0x18,
- 0x1C, 0x57, 0x7D, 0x57, 0x1C,
- 0x1C, 0x5E, 0x7F, 0x5E, 0x1C,
- 0x00, 0x18, 0x3C, 0x18, 0x00,
- 0xFF, 0xE7, 0xC3, 0xE7, 0xFF,
- 0x00, 0x18, 0x24, 0x18, 0x00,
- 0xFF, 0xE7, 0xDB, 0xE7, 0xFF,
- 0x30, 0x48, 0x3A, 0x06, 0x0E,
- 0x26, 0x29, 0x79, 0x29, 0x26,
- 0x40, 0x7F, 0x05, 0x05, 0x07,
- 0x40, 0x7F, 0x05, 0x25, 0x3F,
- 0x5A, 0x3C, 0xE7, 0x3C, 0x5A,
- 0x7F, 0x3E, 0x1C, 0x1C, 0x08,
- 0x08, 0x1C, 0x1C, 0x3E, 0x7F,
- 0x14, 0x22, 0x7F, 0x22, 0x14,
- 0x5F, 0x5F, 0x00, 0x5F, 0x5F,
- 0x06, 0x09, 0x7F, 0x01, 0x7F,
- 0x00, 0x66, 0x89, 0x95, 0x6A,
- 0x60, 0x60, 0x60, 0x60, 0x60,
- 0x94, 0xA2, 0xFF, 0xA2, 0x94,
- 0x08, 0x04, 0x7E, 0x04, 0x08,
- 0x10, 0x20, 0x7E, 0x20, 0x10,
- 0x08, 0x08, 0x2A, 0x1C, 0x08,
- 0x08, 0x1C, 0x2A, 0x08, 0x08,
- 0x1E, 0x10, 0x10, 0x10, 0x10,
- 0x0C, 0x1E, 0x0C, 0x1E, 0x0C,
- 0x30, 0x38, 0x3E, 0x38, 0x30,
- 0x06, 0x0E, 0x3E, 0x0E, 0x06,
- 0x00, 0x00, 0x5F, 0x00, 0x00,
- 0x00, 0x07, 0x00, 0x07, 0x00,
- 0x14, 0x7F, 0x14, 0x7F, 0x14,
- 0x24, 0x2A, 0x7F, 0x2A, 0x12,
- 0x23, 0x13, 0x08, 0x64, 0x62,
- 0x36, 0x49, 0x56, 0x20, 0x50,
- 0x00, 0x08, 0x07, 0x03, 0x00,
- 0x00, 0x1C, 0x22, 0x41, 0x00,
- 0x00, 0x41, 0x22, 0x1C, 0x00,
- 0x2A, 0x1C, 0x7F, 0x1C, 0x2A,
- 0x08, 0x08, 0x3E, 0x08, 0x08,
- 0x00, 0x80, 0x70, 0x30, 0x00,
- 0x08, 0x08, 0x08, 0x08, 0x08,
- 0x00, 0x00, 0x60, 0x60, 0x00,
- 0x20, 0x10, 0x08, 0x04, 0x02,
- 0x3E, 0x51, 0x49, 0x45, 0x3E,
- 0x00, 0x42, 0x7F, 0x40, 0x00,
- 0x72, 0x49, 0x49, 0x49, 0x46,
- 0x21, 0x41, 0x49, 0x4D, 0x33,
- 0x18, 0x14, 0x12, 0x7F, 0x10,
- 0x27, 0x45, 0x45, 0x45, 0x39,
- 0x3C, 0x4A, 0x49, 0x49, 0x31,
- 0x41, 0x21, 0x11, 0x09, 0x07,
- 0x36, 0x49, 0x49, 0x49, 0x36,
- 0x46, 0x49, 0x49, 0x29, 0x1E,
- 0x00, 0x00, 0x14, 0x00, 0x00,
- 0x00, 0x40, 0x34, 0x00, 0x00,
- 0x00, 0x08, 0x14, 0x22, 0x41,
- 0x14, 0x14, 0x14, 0x14, 0x14,
- 0x00, 0x41, 0x22, 0x14, 0x08,
- 0x02, 0x01, 0x59, 0x09, 0x06,
- 0x3E, 0x41, 0x5D, 0x59, 0x4E,
- 0x7C, 0x12, 0x11, 0x12, 0x7C,
- 0x7F, 0x49, 0x49, 0x49, 0x36,
- 0x3E, 0x41, 0x41, 0x41, 0x22,
- 0x7F, 0x41, 0x41, 0x41, 0x3E,
- 0x7F, 0x49, 0x49, 0x49, 0x41,
- 0x7F, 0x09, 0x09, 0x09, 0x01,
- 0x3E, 0x41, 0x41, 0x51, 0x73,
- 0x7F, 0x08, 0x08, 0x08, 0x7F,
- 0x00, 0x41, 0x7F, 0x41, 0x00,
- 0x20, 0x40, 0x41, 0x3F, 0x01,
- 0x7F, 0x08, 0x14, 0x22, 0x41,
- 0x7F, 0x40, 0x40, 0x40, 0x40,
- 0x7F, 0x02, 0x1C, 0x02, 0x7F,
- 0x7F, 0x04, 0x08, 0x10, 0x7F,
- 0x3E, 0x41, 0x41, 0x41, 0x3E,
- 0x7F, 0x09, 0x09, 0x09, 0x06,
- 0x3E, 0x41, 0x51, 0x21, 0x5E,
- 0x7F, 0x09, 0x19, 0x29, 0x46,
- 0x26, 0x49, 0x49, 0x49, 0x32,
- 0x03, 0x01, 0x7F, 0x01, 0x03,
- 0x3F, 0x40, 0x40, 0x40, 0x3F,
- 0x1F, 0x20, 0x40, 0x20, 0x1F,
- 0x3F, 0x40, 0x38, 0x40, 0x3F,
- 0x63, 0x14, 0x08, 0x14, 0x63,
- 0x03, 0x04, 0x78, 0x04, 0x03,
- 0x61, 0x59, 0x49, 0x4D, 0x43,
- 0x00, 0x7F, 0x41, 0x41, 0x41,
- 0x02, 0x04, 0x08, 0x10, 0x20,
- 0x00, 0x41, 0x41, 0x41, 0x7F,
- 0x04, 0x02, 0x01, 0x02, 0x04,
- 0x40, 0x40, 0x40, 0x40, 0x40,
- 0x00, 0x03, 0x07, 0x08, 0x00,
- 0x20, 0x54, 0x54, 0x78, 0x40,
- 0x7F, 0x28, 0x44, 0x44, 0x38,
- 0x38, 0x44, 0x44, 0x44, 0x28,
- 0x38, 0x44, 0x44, 0x28, 0x7F,
- 0x38, 0x54, 0x54, 0x54, 0x18,
- 0x00, 0x08, 0x7E, 0x09, 0x02,
- 0x18, 0xA4, 0xA4, 0x9C, 0x78,
- 0x7F, 0x08, 0x04, 0x04, 0x78,
- 0x00, 0x44, 0x7D, 0x40, 0x00,
- 0x20, 0x40, 0x40, 0x3D, 0x00,
- 0x7F, 0x10, 0x28, 0x44, 0x00,
- 0x00, 0x41, 0x7F, 0x40, 0x00,
- 0x7C, 0x04, 0x78, 0x04, 0x78,
- 0x7C, 0x08, 0x04, 0x04, 0x78,
- 0x38, 0x44, 0x44, 0x44, 0x38,
- 0xFC, 0x18, 0x24, 0x24, 0x18,
- 0x18, 0x24, 0x24, 0x18, 0xFC,
- 0x7C, 0x08, 0x04, 0x04, 0x08,
- 0x48, 0x54, 0x54, 0x54, 0x24,
- 0x04, 0x04, 0x3F, 0x44, 0x24,
- 0x3C, 0x40, 0x40, 0x20, 0x7C,
- 0x1C, 0x20, 0x40, 0x20, 0x1C,
- 0x3C, 0x40, 0x30, 0x40, 0x3C,
- 0x44, 0x28, 0x10, 0x28, 0x44,
- 0x4C, 0x90, 0x90, 0x90, 0x7C,
- 0x44, 0x64, 0x54, 0x4C, 0x44,
- 0x00, 0x08, 0x36, 0x41, 0x00,
- 0x00, 0x00, 0x77, 0x00, 0x00,
- 0x00, 0x41, 0x36, 0x08, 0x00,
- 0x02, 0x01, 0x02, 0x04, 0x02,
- 0x3C, 0x26, 0x23, 0x26, 0x3C,
- 0x1E, 0xA1, 0xA1, 0x61, 0x12,
- 0x3A, 0x40, 0x40, 0x20, 0x7A,
- 0x38, 0x54, 0x54, 0x55, 0x59,
- 0x21, 0x55, 0x55, 0x79, 0x41,
- 0x22, 0x54, 0x54, 0x78, 0x42,
- 0x21, 0x55, 0x54, 0x78, 0x40,
- 0x20, 0x54, 0x55, 0x79, 0x40,
- 0x0C, 0x1E, 0x52, 0x72, 0x12,
- 0x39, 0x55, 0x55, 0x55, 0x59,
- 0x39, 0x54, 0x54, 0x54, 0x59,
- 0x39, 0x55, 0x54, 0x54, 0x58,
- 0x00, 0x00, 0x45, 0x7C, 0x41,
- 0x00, 0x02, 0x45, 0x7D, 0x42,
- 0x00, 0x01, 0x45, 0x7C, 0x40,
- 0x7D, 0x12, 0x11, 0x12, 0x7D,
- 0xF0, 0x28, 0x25, 0x28, 0xF0,
- 0x7C, 0x54, 0x55, 0x45, 0x00,
- 0x20, 0x54, 0x54, 0x7C, 0x54,
- 0x7C, 0x0A, 0x09, 0x7F, 0x49,
- 0x32, 0x49, 0x49, 0x49, 0x32,
- 0x3A, 0x44, 0x44, 0x44, 0x3A,
- 0x32, 0x4A, 0x48, 0x48, 0x30,
- 0x3A, 0x41, 0x41, 0x21, 0x7A,
- 0x3A, 0x42, 0x40, 0x20, 0x78,
- 0x00, 0x9D, 0xA0, 0xA0, 0x7D,
- 0x3D, 0x42, 0x42, 0x42, 0x3D,
- 0x3D, 0x40, 0x40, 0x40, 0x3D,
- 0x3C, 0x24, 0xFF, 0x24, 0x24,
- 0x48, 0x7E, 0x49, 0x43, 0x66,
- 0x2B, 0x2F, 0xFC, 0x2F, 0x2B,
- 0xFF, 0x09, 0x29, 0xF6, 0x20,
- 0xC0, 0x88, 0x7E, 0x09, 0x03,
- 0x20, 0x54, 0x54, 0x79, 0x41,
- 0x00, 0x00, 0x44, 0x7D, 0x41,
- 0x30, 0x48, 0x48, 0x4A, 0x32,
- 0x38, 0x40, 0x40, 0x22, 0x7A,
- 0x00, 0x7A, 0x0A, 0x0A, 0x72,
- 0x7D, 0x0D, 0x19, 0x31, 0x7D,
- 0x26, 0x29, 0x29, 0x2F, 0x28,
- 0x26, 0x29, 0x29, 0x29, 0x26,
- 0x30, 0x48, 0x4D, 0x40, 0x20,
- 0x38, 0x08, 0x08, 0x08, 0x08,
- 0x08, 0x08, 0x08, 0x08, 0x38,
- 0x2F, 0x10, 0xC8, 0xAC, 0xBA,
- 0x2F, 0x10, 0x28, 0x34, 0xFA,
- 0x00, 0x00, 0x7B, 0x00, 0x00,
- 0x08, 0x14, 0x2A, 0x14, 0x22,
- 0x22, 0x14, 0x2A, 0x14, 0x08,
- 0x55, 0x00, 0x55, 0x00, 0x55,
- 0xAA, 0x55, 0xAA, 0x55, 0xAA,
- 0xFF, 0x55, 0xFF, 0x55, 0xFF,
- 0x00, 0x00, 0x00, 0xFF, 0x00,
- 0x10, 0x10, 0x10, 0xFF, 0x00,
- 0x14, 0x14, 0x14, 0xFF, 0x00,
- 0x10, 0x10, 0xFF, 0x00, 0xFF,
- 0x10, 0x10, 0xF0, 0x10, 0xF0,
- 0x14, 0x14, 0x14, 0xFC, 0x00,
- 0x14, 0x14, 0xF7, 0x00, 0xFF,
- 0x00, 0x00, 0xFF, 0x00, 0xFF,
- 0x14, 0x14, 0xF4, 0x04, 0xFC,
- 0x14, 0x14, 0x17, 0x10, 0x1F,
- 0x10, 0x10, 0x1F, 0x10, 0x1F,
- 0x14, 0x14, 0x14, 0x1F, 0x00,
- 0x10, 0x10, 0x10, 0xF0, 0x00,
- 0x00, 0x00, 0x00, 0x1F, 0x10,
- 0x10, 0x10, 0x10, 0x1F, 0x10,
- 0x10, 0x10, 0x10, 0xF0, 0x10,
- 0x00, 0x00, 0x00, 0xFF, 0x10,
- 0x10, 0x10, 0x10, 0x10, 0x10,
- 0x10, 0x10, 0x10, 0xFF, 0x10,
- 0x00, 0x00, 0x00, 0xFF, 0x14,
- 0x00, 0x00, 0x1F, 0x10, 0x17,
- 0x00, 0x00, 0xFC, 0x04, 0xF4,
- 0x14, 0x14, 0x17, 0x10, 0x17,
- 0x14, 0x14, 0xF4, 0x04, 0xF4,
- 0x00, 0x00, 0xFF, 0x00, 0xF7,
- 0x14, 0x14, 0xF7, 0x00, 0xF7,
- 0x14, 0x14, 0x14, 0x17, 0x14,
- 0x14, 0x14, 0x14, 0xF4, 0x14,
- 0x00, 0x00, 0x1F, 0x10, 0x1F,
- 0x00, 0x00, 0x00, 0x1F, 0x14,
- 0x00, 0x00, 0x00, 0xFC, 0x14,
- 0x00, 0x00, 0xF0, 0x10, 0xF0,
- 0x10, 0x10, 0xFF, 0x10, 0xFF,
- 0x14, 0x14, 0x14, 0xFF, 0x14,
- 0x10, 0x10, 0x10, 0x1F, 0x00,
- 0x00, 0x00, 0x00, 0xF0, 0x10,
- 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
- 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
- 0xFF, 0xFF, 0xFF, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0xFF, 0xFF,
- 0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
- 0x38, 0x44, 0x44, 0x38, 0x44,
- 0xFC, 0x4A, 0x4A, 0x4A, 0x34,
- 0x7E, 0x02, 0x02, 0x06, 0x06,
- 0x02, 0x7E, 0x02, 0x7E, 0x02,
- 0x63, 0x55, 0x49, 0x41, 0x63,
- 0x38, 0x44, 0x44, 0x3C, 0x04,
- 0x40, 0x7E, 0x20, 0x1E, 0x20,
- 0x06, 0x02, 0x7E, 0x02, 0x02,
- 0x99, 0xA5, 0xE7, 0xA5, 0x99,
- 0x1C, 0x2A, 0x49, 0x2A, 0x1C,
- 0x4C, 0x72, 0x01, 0x72, 0x4C,
- 0x30, 0x4A, 0x4D, 0x4D, 0x30,
- 0x30, 0x48, 0x78, 0x48, 0x30,
- 0xBC, 0x62, 0x5A, 0x46, 0x3D,
- 0x3E, 0x49, 0x49, 0x49, 0x00,
- 0x7E, 0x01, 0x01, 0x01, 0x7E,
- 0x2A, 0x2A, 0x2A, 0x2A, 0x2A,
- 0x44, 0x44, 0x5F, 0x44, 0x44,
- 0x40, 0x51, 0x4A, 0x44, 0x40,
- 0x40, 0x44, 0x4A, 0x51, 0x40,
- 0x00, 0x00, 0xFF, 0x01, 0x03,
- 0xE0, 0x80, 0xFF, 0x00, 0x00,
- 0x08, 0x08, 0x6B, 0x6B, 0x08,
- 0x36, 0x12, 0x36, 0x24, 0x36,
- 0x06, 0x0F, 0x09, 0x0F, 0x06,
- 0x00, 0x00, 0x18, 0x18, 0x00,
- 0x00, 0x00, 0x10, 0x10, 0x00,
- 0x30, 0x40, 0xFF, 0x01, 0x01,
- 0x00, 0x1F, 0x01, 0x01, 0x1E,
- 0x00, 0x19, 0x1D, 0x17, 0x12,
- 0x00, 0x3C, 0x3C, 0x3C, 0x3C,
- void ILI9488_SendCommand(uint8_t com)
- //*(__IO uint8_t *)(0x60000000) = com;
- uint8_t tmpCmd = com;
- DC_COMMAND();
- CS_A();
- //Write byte using SPI
- HAL_SPI_Transmit(&hspi1, &tmpCmd, 1, 1);
- CS_D();
- void ILI9488_SendData(uint8_t data)
- uint8_t tmpCmd = data;
- DC_DATA();
- CS_A();
- CS_D();
- void ILI9488_SendData_Multi(uint8_t *buff, size_t buff_size){
- DC_DATA();
- CS_A();
- while (buff_size > 0){
- uint16_t chunk_size = buff_size > 32768 ? 32768 : buff_size;
- HAL_SPI_Transmit(&hspi1, buff, chunk_size, HAL_MAX_DELAY);
- buff += chunk_size;
- buff_size -= chunk_size;
- CS_D();
- CS_D();
- RST_A();
- HAL_Delay(10);
- RST_D();
- width=ILI9488_TFTWIDTH;
- height=ILI9488_TFTHEIGHT;
- //CS_A();
- ILI9488_SendCommand(0xE0);
- ILI9488_SendData(0x00);
- ILI9488_SendData(0x03);
- ILI9488_SendData(0x09);
- ILI9488_SendData(0x08);
- ILI9488_SendData(0x16);
- ILI9488_SendData(0x0A);
- ILI9488_SendData(0x3F);
- ILI9488_SendData(0x78);
- ILI9488_SendData(0x4C);
- ILI9488_SendData(0x1A);
- ILI9488_SendData(0x0F);
- ILI9488_SendCommand(0XE1);
- ILI9488_SendData(0x19);
- ILI9488_SendData(0x05);
- ILI9488_SendData(0x32);
- ILI9488_SendData(0x45);
- ILI9488_SendData(0x46);
- ILI9488_SendData(0x04);
- ILI9488_SendData(0x0E);
- ILI9488_SendData(0x0D);
- ILI9488_SendData(0x35);
- ILI9488_SendData(0x37);
- ILI9488_SendCommand(0XC0); //Power Control 1
- ILI9488_SendData(0x17); //Vreg1out
- ILI9488_SendData(0x15); //Verg2out
- ILI9488_SendCommand(0xC1); //Power Control 2
- ILI9488_SendData(0x41); //VGH,VGL
- ILI9488_SendCommand(0xC5); //Power Control 3
- ILI9488_SendData(0x12); //Vcom
- ILI9488_SendData(0x80);
- ILI9488_SendCommand(0x36); //Memory Access
- ILI9488_SendData(0x48);
- ILI9488_SendCommand(0x3A); // Interface Pixel Format
- ILI9488_SendData(0x66); //18 bit
- ILI9488_SendCommand(0XB0); // Interface Mode Control
- ILI9488_SendData(0x80); //SDO NOT USE
- ILI9488_SendCommand(0xB1); //Frame rate
- ILI9488_SendData(0xA0); //60Hz
- ILI9488_SendCommand(0xB4); //Display Inversion Control
- ILI9488_SendData(0x02); //2-dot
- ILI9488_SendCommand(0XB6); //Display Function Control RGB/MCU Interface Control
- ILI9488_SendData(0x02); //MCU
- ILI9488_SendData(0x02); //Source,Gate scan dieection
- ILI9488_SendCommand(0XE9); // Set Image Functio
- ILI9488_SendData(0x00); // Disable 24 bit data
- ILI9488_SendCommand(0xF7); // Adjust Control
- ILI9488_SendData(0xA9);
- ILI9488_SendData(0x51);
- ILI9488_SendData(0x2C);
- ILI9488_SendData(0x82); // D7 stream, loose
- ILI9488_SendCommand(ILI9488_SLPOUT); //Exit Sleep
- HAL_Delay(120);
- ILI9488_SendCommand(ILI9488_DISPON); //Display on
- /*ILI9488_SendCommand(ILI9488_CASET); // Column addr set
- ILI9488_SendData(x0 >> 8);
- ILI9488_SendData(x0 & 0xFF); // XSTART
- ILI9488_SendData(x1 >> 8);
- ILI9488_SendData(x1 & 0xFF); // XEND
- ILI9488_SendCommand(ILI9488_PASET); // Row addr set
- ILI9488_SendData(y0 >> 8);
- ILI9488_SendData(y0 & 0xff); // YSTART
- ILI9488_SendData(y1 >> 8);
- ILI9488_SendData(y1 & 0xff); // YEND
- ILI9488_SendCommand(ILI9488_RAMWR); // write to RAM*/
- ILI9488_SendCommand(ILI9488_CASET); // Column addr set
- uint8_t data[] = {(x0 >> 8) & 0xFF, x0 & 0xFF, (x1 >> 8) & 0xFF, x1 & 0xFF};
- ILI9488_SendData_Multi(data, sizeof(data));
- uint8_t data[] = {(y0 >> 8) & 0xFF, y0 & 0xFF, (y1 >> 8) & 0xFF, y1 & 0xFF};
- ILI9488_SendCommand(0x33); // Vertical scroll definition
- ILI9488_SendData(topFixedArea >> 8);
- ILI9488_SendData(topFixedArea);
- ILI9488_SendData((height - topFixedArea - bottomFixedArea) >> 8);
- ILI9488_SendData(height - topFixedArea - bottomFixedArea);
- ILI9488_SendData(bottomFixedArea >> 8);
- ILI9488_SendData(bottomFixedArea);
- ILI9488_SendCommand(0x37); // Vertical scrolling start address
- ILI9488_SendData(pixels >> 8);
- ILI9488_SendData(pixels);
- HAL_GPIO_WritePin(tftDC_GPIO, tftDC_PIN, GPIO_PIN_SET);
- HAL_GPIO_WritePin(tftCS_GPIO, tftCS_PIN, GPIO_PIN_RESET);
- write16BitColor(color);
- HAL_GPIO_WritePin(tftCS_GPIO, tftCS_PIN, GPIO_PIN_SET);
- uint16_t color;
- uint8_t buff[len * 3 + 1];
- uint16_t count = 0;
- uint8_t lencount = len;
- if (first == 1) {
- while (lencount--)
- color = *data++;
- buff[count] = (((color & 0xF800) >> 11) * 255) / 31;
- count++;
- buff[count] = (((color & 0x07E0) >> 5) * 255) / 63;
- count++;
- buff[count] = ((color & 0x001F) * 255) / 31;
- count++;
- HAL_SPI_Transmit(&lcdSPIhandle, buff, len * 3, 100);
- if ((x >= width) || (y >= height))
- return;
- if ((x + w - 1) >= width)
- w = width - x;
- if ((y + h - 1) >= height)
- h = height - y;
- setAddrWindow(x, y, x + w - 1, y + h - 1);
- DC_DATA();
- CS_A();
- //HAL_GPIO_WritePin(tftDC_GPIO, tftDC_PIN, GPIO_PIN_SET);
- //HAL_GPIO_WritePin(tftCS_GPIO, tftCS_PIN, GPIO_PIN_RESET);
- uint8_t linebuff[w * 3 + 1];
- uint32_t count = 0;
- for (uint16_t i = 0; i < h; i++) {
- uint16_t pixcount = 0;
- for (uint16_t o = 0; o < w; o++) {
- uint8_t b1 = img[count];
- count++;
- uint8_t b2 = img[count];
- count++;
- uint16_t color = b1 << 8 | b2;
- linebuff[pixcount] = (((color & 0xF800) >> 11) * 255)
- / 31;
- pixcount++;
- linebuff[pixcount] = (((color & 0x07E0) >> 5) * 255)
- / 63;
- pixcount++;
- linebuff[pixcount] = ((color & 0x001F) * 255) / 31;
- pixcount++;
- HAL_SPI_Transmit(&lcdSPIhandle, linebuff, w * 3, 100);
- CS_D();
- //HAL_GPIO_WritePin(tftCS_GPIO, tftCS_PIN, GPIO_PIN_SET);
- if ((x < 0) || (x >= width) || (y < 0) || (y >= height))
- return;
- setAddrWindow(x, y, x + 1, y + 1);
- DC_DATA();
- CS_A();
- CS_D();
- return;
- h = height - y;
- setAddrWindow(x, y, x, y + h - 1);
- DC_DATA();
- CS_A();
- while (h--) {
- CS_D();
- return;
- w = width - x;
- setAddrWindow(x, y, x + w - 1, y);
- DC_DATA();
- CS_A();
- while (w--)
- CS_D();
- void drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color)
- if (x0 == x1) {
- if (y0 > y1)
- swap(y0, y1);
- drawFastVLine(x0, y0, y1 - y0 + 1, color);
- } else if (y0 == y1) {
- if (x0 > x1)
- swap(x0, x1);
- drawFastHLine(x0, y0, x1 - x0 + 1, color);
- } else {
- writeLine(x0, y0, x1, y1, color);
- void writeLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color) {
- int16_t steep = abs(y1 - y0) > abs(x1 - x0);
- if (steep) {
- swap(x0, y0);
- swap(x1, y1);
- if (x0 > x1) {
- swap(x0, x1);
- swap(y0, y1);
- int16_t dx, dy;
- dx = x1 - x0;
- dy = abs(y1 - y0);
- int16_t err = dx / 2;
- int16_t ystep;
- if (y0 < y1) {
- ystep = 1;
- } else {
- ystep = -1;
- for (; x0 <= x1; x0++) {
- if (steep) {
- drawPixel(y0, x0, color);
- } else {
- drawPixel(x0, y0, color);
- err -= dy;
- if (err < 0) {
- y0 += ystep;
- err += dx;
- //6. Fill the entire screen with a background color
- fillRect(0, 0, width, height, color);
- uint32_t i, n, cnt, buf_size;
- return;
- w = width - x;
- h = height - y;
- uint8_t r = (color & 0xF800) >> 11;
- uint8_t g = (color & 0x07E0) >> 5;
- uint8_t b = color & 0x001F;
- r = (r * 255) / 31;
- g = (g * 255) / 63;
- b = (b * 255) / 31;
- n = w*h*3;
- if (n <= 65535){
- cnt = 1;
- buf_size = n;
- else {
- cnt = n/3;
- buf_size = 3;
- uint8_t min_cnt = n/65535+1;
- for (i=min_cnt; i < n/3; i++){
- if(n%i == 0){
- cnt = i;
- buf_size = n/i;
- break;
- uint8_t frm_buf[buf_size];
- for (i=0; i < buf_size/3; i++)
- frm_buf[i*3] = r;
- frm_buf[i*3+1] = g;
- frm_buf[i*3+2] = b;
- DC_DATA();
- CS_A();
- while(cnt>0)
- HAL_SPI_Transmit(&hspi1, frm_buf, buf_size, HAL_MAX_DELAY);
- cnt -= 1;
- CS_D();
- ILI9488_SendCommand(ILI9488_MADCTL);
- uint8_t rotation = r % 4; // can't be higher than 3
- switch (rotation) {
- case 0:
- ILI9488_SendData(MADCTL_MX | MADCTL_BGR);
- width = ILI9488_TFTWIDTH;
- height = ILI9488_TFTHEIGHT;
- break;
- case 1:
- ILI9488_SendData(MADCTL_MV | MADCTL_BGR);
- width = ILI9488_TFTHEIGHT;
- height = ILI9488_TFTWIDTH;
- break;
- case 2:
- ILI9488_SendData(MADCTL_MY | MADCTL_BGR);
- break;
- case 3:
- ILI9488_SendData(MADCTL_MX | MADCTL_MY | MADCTL_MV | MADCTL_BGR);
- break;
- ILI9488_SendCommand(i ? ILI9488_INVON : ILI9488_INVOFF);
- return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
- //11. Text printing functions
- uint8_t font_size;
- font_size = size;
- if(rotationNum == 1 || rotationNum ==3)
- if((x >= ILI9488_TFTWIDTH) || // Clip right
- (y >= ILI9488_TFTHEIGHT) || // Clip bottom
- ((x + 6 * font_size - 1) < 0) || // Clip left
- ((y + 8 * font_size - 1) < 0)) // Clip top
- return;
- else
- if((y >= ILI9488_TFTWIDTH) || // Clip right
- (x >= ILI9488_TFTHEIGHT) || // Clip bottom
- ((y + 6 * font_size - 1) < 0) || // Clip left
- ((x + 8 * font_size - 1) < 0)) // Clip top
- return;
- if(!_cp437 && (c >= 176)) c++; // Handle 'classic' charset behavior
- for (int8_t i=0; i<6; i++ ) {
- uint8_t line;
- if (i == 5)
- line = 0x0;
- else
- line = pgm_read_byte(font1+(c*5)+i);
- for (int8_t j = 0; j<8; j++) {
- if (line & 0x1) {
- if (font_size == 1) // default size
- drawPixel(x+i, y+j, color);
- else { // big size
- fillRect(x+(i*font_size), y+(j*font_size), font_size, font_size, color);
- } else if (bg != color) {
- drawPixel(x+i, y+j, bg);
- fillRect(x+(i*font_size), y+(j*font_size), font_size, font_size, bg);
- line >>= 1;
- int16_t offset;
- offset = size*6;
- for(uint16_t i=0; i<40 && text[i]!=NULL; i++)
- drawChar(x+(offset*i), y, text[i],color,bg,size);
- unsigned long start, t;
- int x1, y1, x2, y2, w = width, h = height;
- fillScreen(ILI9488_BLACK);
- x1 = y1 = 0;
- y2 = h - 1;
- for (x2 = 0; x2 < w; x2 += 6)
- drawLine(x1, y1, x2, y2, color);
- x2 = w - 1;
- for (y2 = 0; y2 < h; y2 += 6)
- x1 = w - 1;
- y1 = 0;
- y2 = h - 1;
- x2 = 0;
- x1 = 0;
- y1 = h - 1;
- y2 = 0;
- x2 = w - 1;
- x1 = w - 1;
- y1 = h - 1;
- y2 = 0;
- x2 = 0;
- uint8_t data[3] = {r, g, b};
- ILI9488_SendData_Multi(data, 3);
- //HAL_SPI_Transmit(&hspi1, (uint8_t *)&r, 1, 10);
- //HAL_SPI_Transmit(&hspi1, (uint8_t *)&g, 1, 10);
- //HAL_SPI_Transmit(&hspi1, (uint8_t *)&b, 1, 10);
3、添加测试函数如下:
- /* USER CODE BEGIN 2 */
- ILI9488_Init();
- HAL_Delay(1000);
- setRotation(0);
- char badmpu[] = "HELLO 21IC";
- fillScreen(ILI9488_WHITE);
- ILI9488_printText(badmpu,10,10,ILI9488_BLACK,ILI9488_WHITE,1);
- ILI9488_printText(badmpu,10,20,ILI9488_BLUE,ILI9488_WHITE,2);
- ILI9488_printText(badmpu,10,50,ILI9488_GREEN,ILI9488_WHITE,3);
- ILI9488_printText(badmpu,10,50,ILI9488_RED,ILI9488_WHITE,4);
- testLines(ILI9488_BLUE);
- /* USER CODE END 2 */
【实验效果】
【总结】
1.stm32u5系列拥有高频率、大内存,运行速超级快.
2. stm32拥有超级好用的stm32CubeIDE,配置、只要运行在hal库下面的驱动,可以实现少量代码的修改后,轻松移植到不同的芯片上的工程中。
3. 在实现LCD的驱动后,我们运行ADC、PWM、UART等信息,可以实时的显示到LCD屏上,实现交互信息的方便查看等。
【工程源码】
U5A5ZQ_tft.zip
(1.53 MB, 下载次数: 12)
