- * @file STM32LowPower.cpp
- * @author Frederic Pillon
- * @brief Provides a STM32 Low Power interface with Arduino
- * @attention
- * <h2><center>© COPYRIGHT(c) 2020 STMicroelectronics</center></h2>
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- #include "STM32LowPower.h"
- STM32LowPower LowPower;
- STM32LowPower::STM32LowPower()
- _configured = false;
- _serial = NULL;
- _rtc_wakeup = false;
- * @brief Initializes the low power mode
- * @param None
- * @retval None
- void STM32LowPower::begin(void)
- LowPower_init();
- _configured = true;
- * @brief Enable the idle low power mode (STM32 sleep). Exit this mode on
- * interrupt or in n milliseconds.
- * @param ms: optional delay before leave the idle mode (default: 0).
- * @retval None
- void STM32LowPower::idle(uint32_t ms)
- if ((ms != 0) || _rtc_wakeup) {
- programRtcWakeUp(ms, IDLE_MODE);
- LowPower_sleep(PWR_MAINREGULATOR_ON);
- * @brief Enable the sleep low power mode (STM32 sleep). Exit this mode on
- * @param ms: optional delay before leave the sleep mode (default: 0).
- * @retval None
- void STM32LowPower::sleep(uint32_t ms)
- programRtcWakeUp(ms, SLEEP_MODE);
- #if defined(PWR_LOWPOWERREGULATOR_ON)
- LowPower_sleep(PWR_LOWPOWERREGULATOR_ON);
- #else
- #endif
- * @brief Enable the deepsleep low power mode (STM32 stop). Exit this mode on
- * @param ms: optional delay before leave the deepSleep mode (default: 0).
- * @retval None
- void STM32LowPower::deepSleep(uint32_t ms)
- programRtcWakeUp(ms, DEEP_SLEEP_MODE);
- LowPower_stop(_serial);
- * @brief Enable the shutdown low power mode (STM32 shutdown or standby mode).
- * Exit this mode on interrupt or in n milliseconds.
- * @param ms: optional delay before leave the shutdown mode (default: 0).
- * @retval None
- void STM32LowPower::shutdown(uint32_t ms)
- programRtcWakeUp(ms, SHUTDOWN_MODE);
- /* Get the rtc object to know if it is configured */
- STM32RTC &rtc = STM32RTC::getInstance();
- LowPower_shutdown(rtc.isConfigured());
- * @brief Enable GPIO pin in interrupt mode. If the pin is a wakeup pin, it is
- * configured as wakeup source.
- * @param pin: pin number
- * @param callback: pointer to callback function.
- * @param mode: pin interrupt mode (HIGH, LOW, RISING, FALLING or CHANGE)
- * @param LowPowerMode: Low power mode which will be used
- * (IDLE_MODE, SLEEP_MODE, DEEP_SLEEP_MODE, SHUTDOWN_MODE)
- * In case of SHUTDOWN_MODE only, Wakeup pin capability is activated
- * @retval None
- void STM32LowPower::attachInterruptWakeup(uint32_t pin, voidFuncPtrVoid callback, uint32_t mode, LP_Mode LowPowerMode)
- attachInterrupt(pin, callback, mode);
- if (LowPowerMode == SHUTDOWN_MODE) {
- // If Gpio is a Wake up pin activate it for shutdown (standby or shutdown stm32)
- LowPower_EnableWakeUpPin(pin, mode);
- * @brief Enable a serial interface as a wakeup source.
- * @param serial: pointer to a HardwareSerial
- * @param callback: pointer to callback function called when leave the low power
- * mode.
- * @retval None
- void STM32LowPower::enableWakeupFrom(HardwareSerial *serial, voidFuncPtrVoid callback)
- if (serial != NULL) {
- _serial = &(serial->_serial);
- // Reconfigure serial for low power mode (using HSI as clock source)
- serial->configForLowPower();
- LowPower_EnableWakeUpUart(_serial, callback);
- * @brief Attach a callback to a RTC alarm.
- * @param rtc: pointer to a STM32RTC. Can be NULL as RTC is a Singleton.
- * mode.
- * @param data: optional pointer to callback data parameters (default NULL).
- * @retval None
- void STM32LowPower::enableWakeupFrom(STM32RTC *rtc, voidFuncPtr callback, void *data)
- if (rtc == NULL) {
- rtc = &(STM32RTC::getInstance());
- _rtc_wakeup = true;
- rtc->attachInterrupt(callback, data);
- * @brief Configure the RTC alarm
- * @param ms: time of the alarm in milliseconds.
- * @param lp_mode: low power mode targeted.
- * @retval None
- void STM32LowPower::programRtcWakeUp(uint32_t ms, LP_Mode lp_mode)
- STM32RTC::Source_Clock clkSrc = rtc.getClockSource();
- switch (lp_mode) {
- case IDLE_MODE:
- case SLEEP_MODE:
- break;
- // LSI or LSE must be selected as clock source to wakeup the device.
- case DEEP_SLEEP_MODE:
- clkSrc = (clkSrc == STM32RTC::HSE_CLOCK) ? STM32RTC::LSI_CLOCK : clkSrc;
- break;
- default:
- case SHUTDOWN_MODE:
- #if defined(PWR_CR1_LPMS)
- // For shutdown mode LSE have to be used
- clkSrc = STM32RTC::LSE_CLOCK;
- #else
- // LSE or LSI
- #endif
- break;
- rtc.configForLowPower(clkSrc);
- setAlarmTime(ms, rtc);
- static bool isLeapYear(uint8_t year2k)
- int year = year2k + 2000;
- // if year not divisible by 4 - not a leap year
- // else if year divisible by 4 and not by 100 - a leap year
- // else if year divisible by 400 - a leap year
- return (year % 4 != 0) ? false : (year % 100 != 0) ? true : year % 400 == 0;
- void STM32LowPower::setAlarmTime(uint32_t ms, STM32RTC &rtc)
- if (ms != 0) {
- uint16_t subSecondsToAdd = ms % 1000;
- ms = ms / 1000;
- uint8_t daysToAdd = ms / 86400;
- uint8_t hoursToAdd = (ms - daysToAdd * 86400) / 3600;
- uint8_t minutesToAdd = (ms - daysToAdd * 86400 - hoursToAdd * 3600) / 60;
- uint8_t secondsToAdd = (ms - daysToAdd * 86400 - hoursToAdd * 3600 - minutesToAdd * 60);
- uint8_t hrCurrent, minCurrent, secCurrent;
- uint32_t subSecondsCurrent;
- STM32RTC::AM_PM period;
- rtc.getTime(&hrCurrent, &minCurrent, &secCurrent, &subSecondsCurrent, &period);
- uint8_t weekDay, currentDay, currentMonth, currentYear;
- rtc.getDate(&weekDay, ¤tDay, ¤tMonth, ¤tYear);
- uint32_t ss = subSecondsCurrent + subSecondsToAdd;
- if (ss >= 1000) {
- ss -= 1000;
- secondsToAdd++;
- if (secondsToAdd >= 60) {
- secondsToAdd = 0;
- minutesToAdd++;
- uint8_t s = secCurrent + secondsToAdd;
- if (s >= 60) {
- s -= 60;
- minutesToAdd++;
- if (minutesToAdd >= 60) {
- minutesToAdd -= 60;
- hoursToAdd++;
- uint8_t m = minCurrent + minutesToAdd;
- if (m >= 60) {
- m -= 60;
- hoursToAdd++;
- if (hoursToAdd >= 24) {
- hoursToAdd -= 24;
- daysToAdd++;
- uint8_t h = hrCurrent + hoursToAdd;
- if (rtc._format == STM32RTC::Hour_Format::HOUR_12) {
- if (h >= 24) {
- h -= 24;
- daysToAdd++;
- } else if (h >= 12) {
- if (period == STM32RTC::AM_PM::AM) {
- period = STM32RTC::AM_PM::PM;
- } else {
- period = STM32RTC::AM_PM::AM;
- daysToAdd++;
- if (h > 12) {
- h -= 12;
- } else if (h >= 24) {
- h -= 24;
- daysToAdd++;
- // numbers of days in each month (february is calculated based on leap year)
- static uint8_t daysInMonths[] = {31, 0, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
- uint8_t endDay;
- if (currentMonth == 2) {
- endDay = isLeapYear(currentYear) ? 29 : 28;
- } else {
- endDay = daysInMonths[currentMonth - 1];
- uint8_t d = currentDay + daysToAdd;
- if (d > endDay) {
- d -= endDay;
- // month-year overflow isn't handled because its not supported by RTC's alarm
- rtc.setAlarmTime(h, m, s, ss, period);
- rtc.setAlarmDay(d);
- rtc.enableAlarm(STM32RTC::Alarm_Match::MATCH_DHHMMSS);
