Follow one of the below step to load your project:[size=0.8]Option1: If you have not enabled offline mode, please ensure that you are connected to the internet and restart MCC.
Option2: If you do not have an internet connection or if you want to run MCC and Content Manager in offline mode, then please export required content from another machine using export option of Content Manager and import the exported content in your computer using the import option of Content Manager.
