- File: main.c
- Copyright 2016 Marcos Mori de Siqueira <mori.br@gmail.com>
- Licensed under the Apache License, Version 2.0 (the "License");
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an "AS IS" BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
- //#include <p18cxxx.h>
- #include <p18f2520.h>
- #include <delays.h>
- #include <usart.h>
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #include <i2c.h>
- #include <timers.h>
- #include "rda5807.h"
- #include "hardwareprofile.h"
- #include "LCDBlocking.h"
- #include "TimeDelay.h"
- #include "keypad.h"
- #include "log.h"
- #include "eeprom.h"
- #include "rds.h"
- #include "options.h"
- #include "test.h"
- #include <math.h>
- #pragma config OSC = HS
- #pragma config WDT = OFF
- #pragma config LVP = OFF
- #pragma config MCLRE = ON
- #pragma config PWRT = ON
- #pragma config PBADEN = OFF
- #define MAX_VOLUME 0x0C //0x0F
- #define SAVE_TIMEOUT 5000
- #define BACK2IDLE_TIMEOUT 1000
- #define MENU_TIMEOUT 50000
- #define STATE_IDLE 0
- #define STATE_VOLUME 1
- #define STATE_MEMORY 2
- #define STATE_MENU 3
- #define STATE_LAST_BASIC 3
- #define STATE_LAST 4
- static BYTE mem_idx = 0;
- static BYTE state = STATE_IDLE;
- static LONG state_timeout = 0;
- extern volatile RDSINFO rds;
- static RDAINFO info;
- typedef struct
- RDA_MEMORY mem;
- LONG mem_save_timeout;
- BYTE enabled;
- } SAVEINFO;
- static SAVEINFO save_info = {{0},0,0};
- static void update_lcd(void);
- static void process_dn(void);
- static void process_up(void);
- static BYTE setup_memory(void);
- void main(void)
- char *c = 0;
- DWORD counter = 0, read = 0;
- BYTE evt;
- DWORD ellapsed = 0;
- BYTE btn_ok_pressed = 0;
- CMCON = 0x07; // Comparators Off
- CVRCON = 0; // voltage reference=off
- ADCON1 = 0x0F; // Disable ALL adc channels, PDF page 226
- LED1_TRIS = OUTPUT_PIN;
- I2C_SCL_TRIS = OUTPUT_PIN;
- I2C_SDA_TRIS = OUTPUT_PIN;
- // Uart
- OpenUSART(USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 10);
- LOG((ROMCHAR)"\r\n-------------------------------------------------\r\n");
- KeypadInit();
- LCDInit();
- // Setup I2C
- OpenI2C(MASTER, SLEW_OFF);
- //SSPADD = 0x32; //100kHz Baud clock @20MHz
- SSPADD = 0x0B;//400kHz Baud clock @20MHz
- LCDErase();
- strcpypgm2ram(c, (ROMCHAR)" STARTING ");
- LCDWriteLine(1, c);
- memset(save_info.mem.data, 0, sizeof(RDA_MEMORY));
- //TEST_eeprom_reset();
- if(!EEPROM_load_data(&save_info.mem))
- LOG((ROMCHAR)"loading default config\r\n");
- save_info.mem.flags = RDA_FLAG_RDS|RDA_FLAG_BASS;
- save_info.mem.channel = 101.7;
- save_info.mem.volume = 1;
- //save_info.mem.memory[0] = 97.7;
- //save_info.mem.memory[3] = 103.3;
- //save_info.mem.memory[4] = 90.5;
- LOG((ROMCHAR)"init\r\n");
- RDA5807M_init();
- RDA5807M_PowerON();
- DelayMs(200);
- // Setup radio
- RDA5807M_SetVolume(save_info.mem.volume);
- RDA5807M_SetFrequency(save_info.mem.channel);
- RDA5807M_BassBoost(save_info.mem.flags & RDA_FLAG_BASS);
- RDA5807M_Mono(save_info.mem.flags & RDA_FLAG_MONO);
- RDA5807M_RDS(save_info.mem.flags & RDA_FLAG_RDS);
- while(1)
- LED1 = 0;
- if(counter++ > 3000)
- counter = 0;
- LED1 = 1;
- DelayMs(10);
- evt = GetButtonsEvents();
- if(evt != EVENT_NOTHING)
- if(evt == EVENT_UP_BUTTON_PUSHED)
- if(state != STATE_MENU)
- //LOG((ROMCHAR)"up %d\r\n", state);
- if(++state >= STATE_LAST_BASIC)
- state = STATE_IDLE;
- if(state == STATE_MEMORY)
- mem_idx = setup_memory();
- if(state > STATE_IDLE)
- state_timeout = BACK2IDLE_TIMEOUT;
- else
- state_timeout = 0;
- rds.ps_valid = 1;
- rds.rt_valid = 1;
- else
- state_timeout = MENU_TIMEOUT;
- MENU_run(MENU_UP);
- else if(evt == EVENT_DN_BUTTON_PUSHED)
- //LOG((ROMCHAR)"dn %d\r\n", state);
- if(--state >= 0xFF)
- else
- rds.ps_valid = 1;
- rds.rt_valid = 1;
- else
- MENU_run(MENU_DOWN);
- else if(evt == EVENT_LEFT_BUTTON_PUSHED)
- //LOG((ROMCHAR)"left\r\n");
- if(state == STATE_MENU)
- MENU_run(MENU_LEFT);
- else
- process_dn();
- else if(evt == EVENT_RIGHT_BUTTON_PUSHED)
- //LOG((ROMCHAR)"right\r\n");
- MENU_run(MENU_RIGHT);
- else
- process_up();
- else if(evt == EVENT_OK_BUTTON_PUSHED)
- btn_ok_pressed = 1;
- ellapsed = 0;
- else if(evt == EVENT_MENU_BUTTON_PUSHED)
- LOG((ROMCHAR)"menu\r\n");
- state_timeout = 1; // change to idle
- else
- MENU_init(&save_info.mem);
- state = STATE_MENU;
- else if(evt == EVENT_OK_BUTTON_RELEASED)
- LOG((ROMCHAR)"OK released\r\n");
- btn_ok_pressed = 0;
- if(ellapsed < 250)
- if(MENU_run(MENU_OK))
- save_info.enabled = 1;
- state_timeout = 400;
- else
- else
- switch(state)
- case STATE_IDLE:
- RDA5807M_Mute();
- break;
- case STATE_MEMORY:
- if(save_info.mem.memory[mem_idx] > 0)
- RDA5807M_SetFrequency(save_info.mem.memory[mem_idx]);
- break;
- if(read++ > 1)
- read = 0;
- RDA5807M_Read(&info);
- update_lcd();
- if(save_info.mem_save_timeout > 0)
- if(--save_info.mem_save_timeout <= 0)
- save_info.mem_save_timeout = 0;
- LOG((ROMCHAR)"SAVE DATA EEPROM\r\n");
- LOG((ROMCHAR)"chann %d\r\n", (int)save_info.mem.channel);
- EEPROM_save_data(&save_info.mem);
- // Dont back to IDLE while pressing memory saving button
- if(!btn_ok_pressed && state_timeout > 0)
- if(--state_timeout <= 0)
- LOG((ROMCHAR)"IDLE\r\n");
- rds.ps_valid = 1;
- rds.rt_valid = 1;
- ellapsed++;
- if(btn_ok_pressed && ellapsed > 250)
- save_info.mem.memory[mem_idx] = save_info.mem.channel;
- switch(state)
- case STATE_IDLE:
- RDA5807M_SeekUp();
- break;
- case STATE_VOLUME:
- if(++save_info.mem.volume >= MAX_VOLUME)
- save_info.mem.volume = MAX_VOLUME;
- break;
- if(++mem_idx >= MAX_CHANNEL_MEM)
- mem_idx = MAX_CHANNEL_MEM-1;
- break;
- switch(state)
- case STATE_IDLE:
- RDA5807M_SeekDown();
- break;
- if(--save_info.mem.volume >= 0xFF)
- save_info.mem.volume = 0;
- break;
- if(--mem_idx >= 0xFF)
- mem_idx = 0;
- break;
- static void update_volume(void)
- BYTE i = 0;
- strcpypgm2ram(LCDText[1], (ROMCHAR)"VOL ");
- for(; i < save_info.mem.volume; ++i)
- strcatpgm2ram(LCDText[1], (ROMCHAR)"\xFF");
- BYTE i = 0;
- for(; i < MAX_CHANNEL_MEM; ++i)
- if(save_info.mem.memory[i] > 0 && save_info.mem.memory[i] == info.freq)
- return i;
- return 0xFF;
- int num, dec;
- char c[17] = {0};
- BYTE memidx = 0;
- char m[1] = {' '};
- char m1[3] = {' ',' ', 0};
- static BYTE size = 0;
- static BYTE pos = 0;
- static WORD ps = 0;
- if(state < STATE_LAST_BASIC)
- // Draw line 1
- // Display current memory station
- strncpypgm2ram(LCDText[0], (ROMCHAR)" FM ---.- ", 16);
- num = save_info.mem.memory[mem_idx];
- dec = (int)floor(((save_info.mem.memory[mem_idx] - num) * 100)/10);
- if(dec % 2 == 0) dec += 1;
- sprintf(c, (ROMCHAR)" FM %3d.%1d ", num, dec);
- strncpy(LCDText[0], c, 16);
- else
- // Display station currently tunned
- strncpypgm2ram(LCDText[0], (ROMCHAR)" \xA5\xA5 SCANNING \xA5\xA5 ", 16);
- //if(info.fmtrue && info.tuneok)
- num = info.freq;
- dec = (int)floor(((info.freq - num) * 100)/10);
- memidx = setup_memory();
- if(memidx != 0xFF) {
- itoa(memidx+1, m);
- m1[0] = 'M';
- m1[1] = m[0];
- if(info.stereo)
- sprintf(c, (ROMCHAR)"%1d %s FM %3d.%1d\xA5", info.rssi, m1, num, dec);
- else
- sprintf(c, (ROMCHAR)"%1d %s FM %3d.%1d ", info.rssi, m1, num, dec);
- if(info.fmtrue && info.tuneok)
- // Start save timer
- if(save_info.enabled)
- save_info.mem.channel = info.freq;
- save_info.mem_save_timeout = SAVE_TIMEOUT;
- save_info.enabled = 0;
- switch(state)
- case STATE_IDLE:
- if(!rds.use_rt && rds.ps_valid)
- rds.ps_valid = 0;
- memset(LCDText[1], ' ', 16);
- strncpy(&LCDText[1][4], rds.ps_copy, 8);
- else
- if(rds.rt_valid)
- rds.rt_valid = 0;
- size = strlen(rds.rt_copy);
- pos = 0;
- ps = 0;
- strncpy(LCDText[1], rds.rt_copy, size > 16 ? 16 : size);
- else
- if(rds.use_rt && ps++ > 30)
- ps = 0;
- if(size < 16)
- else
- strncpy(LCDText[1], &rds.rt_copy[pos++], (size - pos) > 16 ? 16 : size);
- break;
- update_volume();
- break;
- switch(mem_idx)
- case 0:
- strncpypgm2ram(LCDText[1], (ROMCHAR)"MEM \x0A51 2 3 4 5 6", 16);
- break;
- case 1:
- strncpypgm2ram(LCDText[1], (ROMCHAR)"MEM 1 \x0A52 3 4 5 6", 16);
- break;
- case 2:
- strncpypgm2ram(LCDText[1], (ROMCHAR)"MEM 1 2 \x0A53 4 5 6", 16);
- break;
- case 3:
- strncpypgm2ram(LCDText[1], (ROMCHAR)"MEM 1 2 3 \x0A54 5 6", 16);
- break;
- case 4:
- strncpypgm2ram(LCDText[1], (ROMCHAR)"MEM 1 2 3 4 \x0A55 6", 16);
- break;
- case 5:
- strncpypgm2ram(LCDText[1], (ROMCHAR)"MEM 1 2 3 4 5 \x0A56", 16);
- break;
- default:
- LOG((ROMCHAR)"ERR %d\r\n", mem_idx);
- mem_idx = 0;
- break;
- break;
- else
- MENU_draw();
- LCDUpdate();
