//串口0接收到数据 //与从机通信 UCOSISR(SIG_UART0_RECV) { INT8U check=0; INT8U i=0; INT8U uart1RxLength = 0; PushRS(); OSIntEnter(); if (1 == OSIntNesting) OSTCBCur->OSTCBStkPtr = (OS_STK *)SP; uart0TimeOutCounter = 0; uart0Action = 1; uart1RxLength = uart0RxCounter; uart0RxBuf[uart1RxLength++] = UDR0; if(1 == uart1RxLength) { if(0X48 != uart0RxBuf[0]) { uart1RxLength = 0; uart0Action = 0; } } else if(2 == uart1RxLength) { if(0X54 != uart0RxBuf[1]) { uart1RxLength = 0; uart0Action = 0; } } else if(uart1RxLength >3) { if(uart1RxLength >= UART0_RX_BUF_SIZE - 1) { uart1RxLength = 0; uart0Action = 0; uart0TimeOutCounter = 0; } else if((0x48 == uart0RxBuf[0]) && (0x54 == uart0RxBuf[1]) && (uart1RxLength == uart0RxBuf[3])) { check = 0; for(i = 0; i < (uart1RxLength - 1); i++) { check ^= uart0RxBuf; }
if(check == uart0RxBuf) { if(slaveUpdateFlag) { OSSemPost(updateSem); } else { OSSemPost(uart0RxSem); } } else { sendChar1(uart1RxLength); sendChar1(check); sendChar1(i); for(uart1RxLength=0; uart1RxLength<uart0RxBuf[3]; uart1RxLength++) sendChar1(uart0RxBuf[uart1RxLength]); RELAY3_ON; } uart1RxLength = 0;//传输出错 uart0Action = 0; uart0TimeOutCounter = 0; } } uart0RxCounter = uart1RxLength; OSIntExit(); PopRS(); }
数据的传输格式:0x48 + 0x54 + addr + Length + data + check(异或和)
问题出现在校验一节: check = 0; for(i = 0; i < (uart1RxLength - 1); i++) { check ^= uart0RxBuf; }
平时,一般情况下计算的if(check == uart0RxBuf)都会成立,偶尔不等的时候,观察发送出来的数据又是正确的,如:0x07 0x00 0x00 0x48 0x54 0x05 0x07 0x00 0x00 0x1E 分析上面发出来的数据,长度为7,check和i的值都为0,而uart0RxBuf中的数据是正确的,猜测程序跳过了for循环引起。局部变量i,check前加volatile后,程序的执行结果不可预测,可能造成系统崩溃。 恳请高人指点,谢谢。 系统为mega64外扩64K RAM。 |
