菜鸟请教STM32TIM1和TIM2PWM输出配置有什么不同?
 楼主| csuzzp 发表于 2012-11-20 21:49 | 显示全部楼层 |阅读模式
为什么我的TIM2能输出而TIM1没有输出?
void GPIO_Configuration(void)
/* 定义 GPIO 初始化结构体 GPIO_InitStructure */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
void TIM_Configuration(void)
/* 定义 TIM_TimeBase 初始化结构体 TIM_TimeBaseStructure */
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
/* 定义 TIM_OCInit 初始化结构体 TIM_OCInitStructure */
TIM_OCInitTypeDef  TIM_OCInitStructure;
TIM_TimeBaseStructure.TIM_Period = 60000;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM1 , &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_Pulse = 30000;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_OC2Init(TIM1, &TIM_OCInitStructure);
TIM_OC3Init(TIM1, &TIM_OCInitStructure);
TIM_OC4Init(TIM1, &TIM_OCInitStructure);
/* 使能预装载寄存器 */
TIM_OC1PreloadConfig(TIM1 , TIM_OCPreload_Enable);
TIM_OC2PreloadConfig(TIM1 , TIM_OCPreload_Enable);
TIM_OC3PreloadConfig(TIM1 , TIM_OCPreload_Enable);
TIM_OC4PreloadConfig(TIM1 , TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM1, ENABLE);
/* 启动 TIM 计数 */
TIM_Cmd(TIM1 , ENABLE);
TIM_TimeBaseInit(TIM2 , &TIM_TimeBaseStructure);
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
TIM_OC4Init(TIM2, &TIM_OCInitStructure);
/* 使能预装载寄存器 */
TIM_OC1PreloadConfig(TIM2 , TIM_OCPreload_Enable);
TIM_OC2PreloadConfig(TIM2 , TIM_OCPreload_Enable);
TIM_OC3PreloadConfig(TIM2 , TIM_OCPreload_Enable);
TIM_OC4PreloadConfig(TIM2 , TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM2, ENABLE);
/* 启动 TIM 计数 */
TIM_Cmd(TIM2 , ENABLE);
caoyonglu 发表于 2012-12-20 10:53 | 显示全部楼层
时光宙宇 发表于 2018-5-10 15:51 | 显示全部楼层
楼主找到问题了吗?菜菜鸟也遇到这个问题了
gejigeji521 发表于 2018-5-10 19:37 来自手机 | 显示全部楼层
你看这两个结构一样不
