请问如何在pc端获取USB读卡器里SD卡的CID 信息???用VC++的。
下面的代码是否可以获取sd卡cid信息??
为什么 DeviceIoControl()返回0,GetLastError();返回为50,不支持请求。错在哪里了。跪求指导。。。- void GetSD_CID()
- // TODO: Add your control notification handler code here
- //CComboBoxEx * pComBox = (CComboBoxEx *) GetDlgItem(IDC_COMBO1);
- TCHAR StrDeviceName[64] = {0};
- wsprintf(StrDeviceName,_T("\\\\.\\%C:"),'G'/*pComBox->GetCurSel()*/);
- // Create device handle
- HANDLE hVol = CreateFile(StrDeviceName,
- GENERIC_READ|GENERIC_WRITE, // no access to the drive
- FILE_SHARE_READ | // share mode
- FILE_SHARE_WRITE,
- NULL, // default security attributes
- OPEN_EXISTING, // disposition
- 0, // file attributes
- NULL); // do not copy file attributes
- //CString strOutputMsg;
- UCHAR ucSDCID[SD_CID_LENGTH] = {0};
- if(INVALID_HANDLE_VALUE != hVol && NULL != hVol){
- // Structure used in IOCTL_SFFDISK_DEVICE_COMMAND
- // The layout of the buffer passed to this IOCTL is as follows:
- // | header (this structure) |
- // | protocol arguments |
- // | device data buffer |
- // The actual layout of the protocol arguments depends on the protocol of
- // the target device. So as an example, if the target device an SD (Secure Digital)
- // storage device, then the protocol arguments would consist of an SDCMD_DESCRIPTOR,
- // which is defined in SDDEF.H. The SD argument for the command should be stored
- // in the "Information" field of this structure. In that case, ProtocolArgumentSize
- // would be sizeof(SDCMD_DESCRIPTOR).
- // The three size fields in the structure (HeaderSize, ProtocolArgumentSize,
- // DeviceDataBufferSize) each hold the length in bytes of each respective area as
- // described by the diagram above. Thus, the entire length of the buffer must be
- // at least as large as the sum of these three fields.
- int nSizeOfCmd = sizeof(SFFDISK_DEVICE_COMMAND_DATA) + sizeof(SDCMD_DESCRIPTOR) + SD_CID_LENGTH;
- SFFDISK_DEVICE_COMMAND_DATA *pCmdBuf = (SFFDISK_DEVICE_COMMAND_DATA*) new BYTE[nSizeOfCmd];
- SFFDISK_DEVICE_COMMAND_DATA *pCmdBufout = (SFFDISK_DEVICE_COMMAND_DATA*) new BYTE[nSizeOfCmd];
- ULONG_PTR info = 0;
- memset(pCmdBuf, 0, nSizeOfCmd);
- pCmdBuf->HeaderSize = sizeof (SFFDISK_DEVICE_COMMAND_DATA);
- pCmdBuf->Command = SFFDISK_DC_DEVICE_COMMAND;
- pCmdBuf->ProtocolArgumentSize = sizeof (SDCMD_DESCRIPTOR);
- pCmdBuf->DeviceDataBufferSize = SD_CID_LENGTH;
- pCmdBuf->Information = info;
- ///Command protocol
- SDCMD_DESCRIPTOR sdCmdDescriptor = { 0 };
- sdCmdDescriptor.Cmd = SFFDISK_SC_GET_CARD_VERSION; // Issue CMD10 to driver
- sdCmdDescriptor.CmdClass = SDCC_STANDARD;
- sdCmdDescriptor.TransferDirection = SDTD_READ;
- sdCmdDescriptor.TransferType = SDTT_CMD_ONLY;
- sdCmdDescriptor.ResponseType = SDRT_1;
- /* memcpy((BYTE *)(&(pCmdBuf->Data[0])), &sdCmdDescriptor, sizeof(SDCMD_DESCRIPTOR)); */
- memcpy(pCmdBuf->Data, &sdCmdDescriptor, sizeof(SDCMD_DESCRIPTOR));
- DWORD dwBytesReturned = 0;
- BOOL bResult = DeviceIoControl(hVol,
- IOCTL_SFFDISK_DEVICE_COMMAND,
- pCmdBuf,
- nSizeOfCmd,
- pCmdBufout,
- nSizeOfCmd,
- &dwBytesReturned,
- NULL);
- DWORD dwErr = GetLastError();
- CloseHandle(hVol);
- int nCIDBaseIndex = sizeof(SDCMD_DESCRIPTOR);
- if(!bResult){
- printf("Failed to get CID, err code is |%d|",dwErr);
- }else{
- delete [] pCmdBuf;
- }else{
- //strOutputMsg.Format(L"Failed to open device handle |%s|", StrDeviceName);
