我将PWM的程序下载之后想过示波器观察PWM波形。但是当我将示波器的两条线接到板子上面的PWM输出脚的时候却出现了这个问题。Power Failure on Target CPU: Error 0x00001020/-1145 Error during: Execution, Target, Unrecoverable emulation error Sequence ID: 16 Error Code: -1145 Error Class: 0x00001020
Failed to remove the debug state from the target before disconnecting. There may still be breakpoint opcodes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.这是什么原因啊
