求各位大侠指点,
调试现象:串口一收发均正常;串口二调试时当接收到数据如13时触发中断,但自动发送13给串口调试助手.接收误码(本来接收到的应是13,但却是其他数据如F3),发送正常;
为什么串口2接收误码吖?源代码如下,求高手帮忙分下下:
#include "stm32f10x.h"
#include <stdio.h>
函数: void RCC_Configuration(void)
功能: 复位和时钟控制 配置
参数: 无
返回: 无
ErrorStatus HSEStartUpStatus; //定义外部高速晶体启动状态枚举变量
RCC_DeInit(); //复位RCC外部设备寄存器到默认值
RCC_HSEConfig(RCC_HSE_ON); //打开外部高速晶振
HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待外部高速时钟准备好
if(HSEStartUpStatus == SUCCESS) //外部高速时钟已经准别好
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //开启FLASH预读缓冲功能,加速FLASH的读取。所有程序中必须的用法.位置:RCC初始化子函数里面,时钟起振之后
FLASH_SetLatency(FLASH_Latency_2); //flash操作的延时
RCC_HCLKConfig(RCC_SYSCLK_Div1); //配置AHB(HCLK)时钟等于==SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); //配置APB2(PCLK2)钟==AHB时钟
RCC_PCLK1Config(RCC_HCLK_Div2); //配置APB1(PCLK1)钟==AHB1/2时钟
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //配置PLL时钟 == 外部高速晶体时钟 * 9 = 72MHz
RCC_PLLCmd(ENABLE); //使能PLL时钟
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) //等待PLL时钟就绪
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //配置系统时钟 = PLL时钟
while(RCC_GetSYSCLKSource() != 0x08) //检查PLL时钟是否作为系统时钟
* Function Name : NVIC_Configuration
* Description : Configures NVIC and Vector Table base location.
* Input : None
* Output : None
* Return : None
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //通道设置为串口1中断
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //中断响应优先级0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //打开中断
NVIC_Init(&NVIC_InitStructure); //初始化
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //通道设置为串口2中断
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //中断响应优先级1
函数名:GPIO_Configuration
输 入:
输 出:
功能说明:
初始化GPIO,启用中断
配置步骤:
(1)
(2)设置USART1/USART2两个管脚GPIO模式
(3)配置USART1/USART2数据格式、波特率等参数
(4)使能USART1/USART2接收中断功能
(5)最后使能USART1/USART2功能
void GPIO_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
函数名:USART1_Configuration
输 入:
输 出:
功能说明:
初始化串口硬件设备,启用中断
配置步骤:
(1)打开GPIO和USART1/USART2的时钟
void USART1_Configuration(void)
USART_InitTypeDef USART_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
/* 若接收数据寄存器满,则产生中断 */
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
/* 第5步:使能 USART1, 配置完毕 */
USART_Cmd(USART1, ENABLE);
/* 如下语句解决第1个字节无**确发送出去的问题 */
USART_ClearFlag(USART1, USART_FLAG_TC); // 清标志
void USART2_Configuration(void)
/* 打开USART部件的时钟 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
USART_Init(USART2, &USART_InitStructure);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
/* 第5步:使能 USART2, 配置完毕 */
USART_Cmd(USART2, ENABLE);
USART_ClearFlag(USART2, USART_FLAG_TC); // 清标志
/* STM32向串口1发送1字节 */
/*void Uart_PutChar(USART_TypeDef* USARTx,u8 ch)
USART_SendData(USART_TypeDef* USARTx, (u8) ch);
while(USART_GetFlagStatus(USART_TypeDef* USARTx, USART_FLAG_TXE) == RESET);
/* STM32在串口1接收1字节 */
/* 说明:串口1接收中断 */
void USART1_IRQHandler(void) //在中断服务程序中,由于主机响应中断时并不知道是哪个中断源发出中断请求,因此必须在中断服务程序中对中断源进行判别,然后分别进行处理。当然,如果只涉及到一个中断请求,是不用做上述判别的。但是无论什么情况,做上述判别是个好习惯
u8 dat1;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //若接收数据寄存器满
dat1 = USART_ReceiveData(USART1);
//Uart_PutChar(USART1,dat);
USART_SendData(USART1, dat1);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); //为什么要有这句话
if(dat1 == 0x62)
dat1 = 0;
USART_SendData(USART1, 0x38);
void USART2_IRQHandler(void) //在中断服务程序中,由于主机响应中断时并不知道是哪个中断源发出中断请求,因此必须在中断服务程序中对中断源进行判别,然后分别进行处理。当然,如果只涉及到一个中断请求,是不用做上述判别的。但是无论什么情况,做上述判别是个好习惯
u8 dat2;
if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) //若接收数据寄存器满
dat2 = USART_ReceiveData(USART2);
//Uart_PutChar(USART2,dat);
USART_SendData(USART2, dat2);
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET); //为什么要有这句话
if(dat2 != 0x13)
dat2 = 0;
USART_SendData(USART2, 0x87);
函数: int main(void)
功能: main主函数
参数: 无
返回: 无
int main(void)
RCC_Configuration();
NVIC_Configuration();
GPIO_Configuration();
USART1_Configuration();
USART2_Configuration();
while(1);
