如题,固件库是3.5的
程序很庞大,我就不全贴出来了
但我处理flash存储的程序是这样的- void SaveFlashData()
- unsigned char FunctionStatusReturn;
- unsigned char ReSaveTimes=0;
- do
- ReSaveTimes++;
- FunctionStatusReturn=0;
- delay_ms(2);
- __disable_irq();
- UnlockFlash();
- FLASH_ErasePage(_USER_MSG_PAGE_ADDr);
- FunctionStatusReturn+=SaveFlashChar(pID, pID_Flash_ADDr, 22);
- FunctionStatusReturn+=SaveFlashChar(pPass, pPass_Flash_ADDr, 16);
- FunctionStatusReturn+=SaveFlashChar(pURL, pURL_Flash_ADDr, pURLlen[0]);
- FunctionStatusReturn+=SaveFlashshort(pPort, pPort_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashshort(pWeek0, pWeek0_Flash_ADDr, 7);
- FunctionStatusReturn+=SaveFlashshort(pWeek1, pWeek1_Flash_ADDr, 7);
- FunctionStatusReturn+=SaveFlashshort(pSTimer, pSTimer_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashChar(pSwitch, pSwitch_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashChar(pWeek0Action, pWeek0Action_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashChar(pWeek1Action, pWeek1Action_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashChar(pSTimerAction, pSTimerAction_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashChar(pURLlen, pURLlen_Flash_ADDr, 1);
- FunctionStatusReturn+=SaveFlashChar(&ulSmartConfigSatus, ulSmartConfigSatus_Flash_ADDr, 1);
- LockFlash();
- __enable_irq();
- }while( FunctionStatusReturn!=0 && ReSaveTimes<=3 );
- if(ReSaveTimes>3)
- #ifdef DEBUG_WU
- UartSendPacket("SAVE Fail\r\n",11);
- UartSendPacketInt(ReSaveTimes,"ReSaveTimes");
- #endif
- }else
- #ifdef DEBUG_WU
- UartSendPacket("-->SAVE DONE\r\n",11);
- #endif
其中,编程成功则返回0
因为每次重新编程会要先擦出,所以只能批量重写,按理来说编写3次都写不正确这几率也太小了,但我在调试程序的时候,在程序的特定位置出错几率特别高
(也就是软件自动复位,置标志位,然后再main函数中判断flash编程是否完成,在判断复位标志位是否置起,这样便重启系统,就是在这里进行flash编程很容易出错)-
- if(!(FLASHOperatStatus&FLASH_UPDATA_SAVE))
- __disable_irq();
- //__enable_irq();
- NVIC_GenerateSystemReset();
- while(1);
